Error message. Lens or body?
Started May 29, 2019 | Discussions
egruber Regular Member • Posts: 103
I have a canon t4i body and tamron zoom lens. I keep getting this error. I tried cleaning the contacts with a small pencil eraser on both body and lens and it keeps intermittently coming up. Any ideas?
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
Ray UK Contributing Member • Posts: 977
Re: Error message. Lens or body?
Common error message when you have a broken flexible cable within the lens, the fact that it is intermittent also suggests a cable fault.
By the way, a pencil eraser is the wrong thing to use on the contacts, it is too abrasive and can damage the gold plating, only a soft cloth should be used.
OP egruber Regular Member • Posts: 103
If I turn   it off and then  just twist the lens back and forth on the mount once and turn it back on the error clears. Still think it’s the cable?
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Yes.
Do you have another lens to try on the camera?  If it happens with other lenses then it may be the body.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
I do. The problem is it is so intermittent it will be hard to tell. Sometimes it works fine for a while.
