Fuji XP130 - Dissapointing
Started May 29, 2019 | Discussions
Chris Sargent
Chris Sargent Senior Member • Posts: 1,213
I recently bought a Fuji XP130 as I planned on doing some SCUBA diving. I generally don't have a use case for under water photography so I 'cheaped' out on this model.
I was very disappointed in the XP130.. it struggled to focus most of the time and the images it produces are worse than those taken with a camera phone. I had expected something a little better.
I would not recommend it
 Chris Sargent's gear list:Chris Sargent's gear list
Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +3 more
Fujifilm XP130
Barmaglot_07 Contributing Member • Posts: 633
Re: Fuji XP130 - Dissapointing
Care to post some samples? While I doubt that XP130 is a technological marvel, one should also keep in mind that water is an extremely challenging environment to shoot in, and much of the conventional wisdom about land photography does not apply when diving.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
Chris Sargent
OP Chris Sargent Senior Member • Posts: 1,213
Yes, I think that has a lot to do with it.. that said, this is touted as an underwater camera so I would have hoped it could cope better with low-light focusing?
The images are OK.. but struggling with focus lock was annoying.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Grenada?
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Fast and accurate autofocus in low light requires PDAF. To the best of my knowledge, there are only a handful of compact cameras on the market that implement it, and none of them are in the XP130's price bracket - Sony RX100 V/VA/VI and RX1R II, Canon G1 X III, Ricoh GR III, Fujifilm XF10, and... I think that's it.
Looks pretty much par the course with iffy visibility and natural light. Getting closer generally helps, but as far as I can see, there is no obvious way to mount a wet wide lens on this camera.
Chris Sargent
PHXAZCRAIG wrote:
Grenada?
Yes, well Spotted...
andreribeiro New Member • Posts: 3
As far as I understood, these rugged cameras like the XP130 do not have the awful fisheye effect of the action cameras correct?
Chris Sargent
Correct. This camera has a regular field of view rather than the distorted Fish Eye of a Go-Pro type camera.
WildImages
WildImages Contributing Member • Posts: 741
I have found that if I do some remedial post processing, these small point and shoots sit better on the appreciate side.  I took the liberty of capturing one of your images and only adjusted the color using curves on my smartphone.  I really don't think that Fuji is too bad for what it is.
What do you think?
