Question, E-M10 III and E-PL9 have pro capture mode? thanks
Started May 29, 2019 | Discussions
Jefftan Veteran Member • Posts: 3,501
i like my TG-5 pro capture mode a lot
is it available in E-M10 III and E-PL9 or only in E-M1 II?
Olympus E-M1 Olympus E-PL9 Olympus OM-D E-M10 Olympus TG-5
techie takes pics Senior Member • Posts: 1,730
Re: Question, E-M10 III and E-PL9 have pro capture mode? thanks
Not on the E-M10 (all models) or the PL9 (consumer level).
I believe not even the M5.2 has it.
 techie takes pics's gear list:techie takes pics's gear list
Olympus PEN E-P5 Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +8 more
OP Jefftan Veteran Member • Posts: 3,501
strange
TG-5 and TG-6 have it
bluevellet Veteran Member • Posts: 4,172
strange
Pro Capture started with the EM1 mark II, released in late 2016. Your TG-5 was released in 2017.
Although the E-PL9 and the EM10III were released after the EM1II, I suspect Olympus omitted Pro Capture in these models to protect their lucrative EM1 sales. The TG series is seen as a complete different camera segment and thus no threat to the EM1.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
i just found a new use with pro capture on my TG-5
it is for night (low light) photography
in pro capture under low light it will use a long shutter speed of 1/10
now normally if i use 1/10, all pics will be blur
but i found out in pro capture which capture a burst of photo, it will often turn out ok
i think probably because it start buffering as soon as i half press shutter
this enable me to use no more than ISO 400 in most dark situation and together with DXO PRIME, low light IQ suddenly become OK
before that, bad IS on TG-5 so have to push up ISO, than IQ of course is really bad
too bad this feature not in E-M10 III and E-PL9
Till Kamppeter
Till Kamppeter Regular Member • Posts: 159
But on E-M10 III and E-PL9 you have S and M mode which are not available on TG-X. In these modes you set the shutter speed to 1/10s and set the drive mode to continuous shooting (the slow one is good enough and conserves live view, diamond variations for EFCS). Aim and half-press normally, then keep the shutter full-pressed for 4 or 5 clicks, at least one of these pictures will be sharp.
Should work better than pro-capture on the TGs, as the m43 cameras have better stabilizers (even the 3-axis of the E-PL9) and you shoot with mechanical shutter.
Till
 Till Kamppeter's gear list:Till Kamppeter's gear list
Olympus PEN-F Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +11 more
Till
What u said may work, i guess
but not exactly the same as pro capture as it start the buffering as soon as half press
i don't have E-M10 III and E-PL9 so not sure if it will work as u said
Till Kamppeter
It is only a way to get more sharp images with slow shutter speed, as you mentioned Pro Capture as workaround for the missing S/M modes on the TG. It naturally does not provide the original functionality of Pro Capture to capture already before the full press.
In terms of getting sharp images with slow shutter speed you can expect the best picture with the TG and Pro Capture in the middle between half and full press, for the m43 with S/M modes in the middle of the time after full press and taking the finger off the shutter button.
Till
joeletx Veteran Member • Posts: 4,127
Very interesting. Do you mind to show some examples?
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 +10 more
i will try to do so later but i just have an important observation
for each pro capture shot one will get either 6 or 7 burst shot (6 jpeg and 6 RAW or 7 jpeg and 7 RAW)
one need to pick out the sharpest one out of the them and process the sharpest one RAW file with DXO PRIME
right now it seem to me that I can be pick out the sharpest one base on the jpeg file size
the largest jpeg file size (out of the 6 or 7 jpeg file) seem to be the sharpest and the smallest jpeg file size seem to be most blur
please give me some time to confirm this. If it is really so it would be easy (otherwise just find out which is the sharpest one is a difficult task)
I got to sleep now
