A great value when speed is not essential.
Started May 28, 2019 | User reviews
tcphoto1
tcphoto1 Senior Member • Posts: 1,408
I bought this lens when I started shooting more architectural and interior projects and the 24LII just wasn't wide enough. Odds are, if you're on a tripod and mixing light sources the 16-35/4LIS is a great alternative to the 16-35/2.8L or T/S lenses. I find that CaptureOne allows me to adjust lines and other corrections. Overall, I'm very happy with the lens.
 tcphoto1's gear list:tcphoto1's gear list
Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon 85mm F1.4L IS USM +10 more
Wideangle zoom lens • Canon EF • 9518B002
Announced: May 13, 2014
tcphoto1's score
3.5
Average community score
4.6
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: A great value when speed is not essential.
9
Odd that you only gave the 16-35 f/4L IS 3-1/2 stars. This is one of the finest wide angle zooms ever made. Unless there is an overriding need for the f/2.8 III, I can't imagine how to realistically improve this lens. The IS is solid and surprisingly useful and there is no comparison to the earlier 16-35 f/2.8 versions 1 and 2.
I've tested it side by side against the superb 24-70 f/2.8L II at f/4 on the overlapping focal lengths and the two are nearly indistinguishable. As a photojournalist this thing is a solid workhorse delivering excellent results.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
You are very happy with a lens  you rated 3.5 out of 5? That's like a C.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
tcphoto1
OP tcphoto1 Senior Member • Posts: 1,408
It's not a 16-35/2.8 or a 17-TSE but it's a good lens. How about posting your own reviews and grade it on your experience with it.
Dale Garman Senior Member • Posts: 1,025
I guess we all have different reference points when evaluating how well a lens works. I find it no surprise that it doesn't act like a tilt shift lens since it wasn't designed to be one, so that is not part of my evaluation at all.
So yes the f4 is not a 2.8 lens, but in my experience it is extremely sharp wide open at f4. If you look at a detailed review of the f 2.8 lens it is given very high marks
https://www.the-digital-picture.com/Reviews/Canon-EF-16-35mm-f-2.8L-III-USM-Lens.aspx
But, the f2.8 is bigger and heavier and 2x the price of the f4 and doesn't have IS. So for most subjects, I find the f4 a more useful lens since the IS gives at least 3 stops benefit IMHO and according to controlled tests I have seen. I tend to use telephotos for action, but rarely use a 16-35 for action, so the IS turns out to be very useful in my use.
So for me the 16-35 f4 IS is a 5 star lens that is hard to beat, especially consider price, weight, and IS help. I continue to be amazed at this lens.
One last thought, when you say in review when speed is not essential I assume you are not referring to AF speed but rather to aperture?  With IS, I actually find the f4 highly preferable for how much useful light it lets in.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
Steve Balcombe Forum Pro • Posts: 15,582
I'm with the others, that's a very low score for such a superb lens. The 16-35/2.8L III is bigger, heavier, much more expensive and has no IS. On a tripod the extra stop is largely irrelevant and off the tripod IS is more effective than one stop of aperture for most situations. So at best it would be a 2.5?
gium Senior Member • Posts: 1,651
It's also not a 100-400mm or an 85mm prime. How about rating the lens for what it is?
I don't have this lens, but you rating it at 3,5 stars: the general assumption for 3,5 stars is that it's a reasonably good lens with flaws (as in distortion, vignetting, CA. Not as in 'it's not f/2.8').
 gium's gear list:gium's gear list
Canon EOS M5 Canon EOS RP Canon EOS R5 Canon EF 85mm F1.2L II USM Canon EF 24-85mm f/3.5-4.5 USM +9 more
JerryriggedTECH
JerryriggedTECH Senior Member • Posts: 1,098
Yep... this is the only lens I own that is slower than f/4. Indeed very nice lens and a real bargain!
 JerryriggedTECH's gear list:JerryriggedTECH's gear list
Canon EOS 5D Mark IV Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +5 more
BlueRay2 Forum Pro • Posts: 14,816
a 3.5 star?....how embarrassing
You miss 100 percent of the shots you didn't take!!! "Wayne Gretzky"
