Will the new TG-6 have the same lens "flare" or "halo" effect as TG-5?
Started May 27, 2019 | Discussions
Neptis New Member • Posts: 1
I have a TG-5 which displays a purple halo in pictures taken at maximum zoom, as reported by other users and discussed in the following two threads:
https://www.dpreview.com/forums/thread/4193624
https://www.dpreview.com/forums/thread/4287370
Wonder if this problem would be rectified in the new TG-6?
Olympus TG-5 Olympus TG-6
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
Re: Will the new TG-6 have the same lens "flare" or "halo" effect as TG-5?
I haven't seen the purple orb in any of the available TG-6 samples. But, that doesn't mean the problem has been corrected. It's a lens design problem that goes back through several generations of the TG line. Under the right lighting conditions, my TG-3 will produce that spot. The TG-6 is mostly a firmware update, so it's questionable if the issue was addressed.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
Linnin
Linnin Regular Member • Posts: 206
We'll be finding out shortly as the more enthusiastic early adopters romp on the new TG-6. There is/are new lens coating(s) on the TG-6.
My Best Days Are Still In Front Of Me
 Linnin's gear list:Linnin's gear list
Olympus TG-5
