diy lens hood
Started May 27, 2019 | Discussions
SmoothOperator Regular Member • Posts: 386
diy lens hood
I made a makeshift lens hood for my 400mm telephoto lens this weekend.  The lens has a built in hood, but it isn't very long.  I used corrugated cardboard with the corrugations running parallel to the  line of sight.  Other than being well cardboard, it worked really well.
I want a more permanent solution.  That doesn't look so ugly.  I am thinking about getting a piece of camouflage neoprene(this way I can make matching covers, and maybe reinforcing it a little bit.  I am stuck on what to reinforce it with, other than basically just using cardboard itself.  The card board was nice, because it would roll up
petrochemist Veteran Member • Posts: 3,619
Re: diy lens hood
I made one using black craft foam which rolled up nicely but was really a bit small for the mirror lens I made it for, and then the velcro came unstuck...
perhaps I'll have another go sometime.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
OP SmoothOperator Regular Member • Posts: 386
Re: diy lens hood
foam is good idea, maybe it needs to be cloth backed for sewing:
https://www.rockywoods.com/Camouflage-printed-foam-backed-headliner-fabric
CarmelSoul Regular Member • Posts: 281
Re: diy lens hood
Here is repository of patterns for most manufacturers
http://www.lenshoods.co.uk/olympus.php
Re: diy lens hood
Thanks that is interesting, for long telephotos the shape isn't as important though.  I wasn't anywhere near vignetting with a 16" hood.  I might try it on other lenses.
Re: diy lens hood
I ended up making one out of 1/8 in neoprene camouflage, with a lining of a fiber based dining placemat from the dollar store, with some Velcro and a strapped clip.  Works out pretty well, light and flexible.  I also made a neoprene lens cover for my mirror lens.
It cleans up the light very much, but I wonder about the light falloff.  Is that vignetting, or just natural light fall off I didn't notice before.
Richmcqueenphoto Regular Member • Posts: 191
Re: diy lens hood
buy a neoprene/memory foam cup holder from dollar tree if you have that sure in your area. Already well put together and collapsable for travel. They have camo prints as well.
I use them for snoots on speedlites
Just incase you need any more, i see that you found a solution months ago
 Richmcqueenphoto's gear list:Richmcqueenphoto's gear list
Nikon D800 Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Nikon AF-Nikkor 80-200mm f/2.8D ED +2 more
Scantrack New Member • Posts: 3
Re: diy lens hood
Hi.I made a hood for my sigma 150 600.
Here::
Works really well.and cost less than £10: .
Re: diy lens hood
Your post would be MUCH more interesting if you disclosed what you used...
Re: diy lens hood
Re: What I used to make my hood
6" diamiter white plastic  drain pipe.(which I had in workshop)6"1/2 long.
Box of various sized hex fittings.(used to fix new hood to original hood.
Hope this helps .
If you need anymore info please message me.
Regards
Length of neoprene to cover hood.(which I had from another project.
Camo tape £8:00 to cover inside of hood.
See attached photos.
