Some Bees & Bumblebees Macro with X-T3
Started May 21, 2019 | Photos
edorf_71
edorf_71 Regular Member • Posts: 236
19
Some 'half-macro's' with the 60mm + 50-140mm. Severe crops. All handheld.
Guess the 80mm macro would yield better results or extension rings.
Thanks for looking!
edorf_71
 edorf_71's gear list:edorf_71's gear list
Nikon Z9 Nikon AF-S Nikkor 800mm f/5.6E FL ED VR Tamron 15-30mm F2.8 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon 500mm F5.6E PF +3 more
Comment & critique:
Fujifilm XF 50-140mm F2.8 Fujifilm XF 60mm F2.4 R Macro Fujifilm X-T3
boomerm3 Regular Member • Posts: 380
Re: Some Bees & Bumblebees Macro with X-T3
Very nice. The hovering bee is tack sharp. I can never get the bees to stay still for me.
www.psblock.photos
 boomerm3's gear list:boomerm3's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR
4thnebula Senior Member • Posts: 2,418
Nice photos.  Love the bottom one with the bee in the air.
 4thnebula's gear list:4thnebula's gear list
Canon EF 35mm F2 IS USM Sony a7 III Canon EF 28mm f/2.8 IS USM Canon EF 40mm f/2.8 STM +1 more
edorf_71
OP edorf_71 Regular Member • Posts: 236
Thanks!
It's almost tack sharp. Very few keepers so it's not easy to get them. Constantly moving very erratic.
edorf_71
edorf_71
Thanks Got lucky there. Here's another one. Not that sharp but ok.
edorf_71
BlueJakester
BlueJakester Veteran Member • Posts: 3,415
Excellent images. I recently tried photographing bees and know it’s difficult. Nice shooting!
 BlueJakester's gear list:BlueJakester's gear list
Nikon D7100 Fujifilm X-T1 Fujifilm X-H1 Sony a7R IV Sony FE 85mm F1.8 +4 more
edorf_71
Thanks!
edorf_71
notchy
notchy Contributing Member • Posts: 713
These are wonderful shots edorf_71.
I wouldn't worry about that. I have the 80mm and it is indeed a special lens, but some of my favourite close up [sic] shots to date were taken with the 100-400mm:
Four-spotted Chaser dragonfly, Dorset, England, 2018
Female Emperor dragonfly laying her eggs in a water meadow drainage ditch, Dorset, England, 2018
I've also taken very pleasing shots with the 50mm f2 and the mcex-11 extension ring, and the 55mm-200mm zoom as well. The shot below was taken handheld at the "soft" end of the 55-200mm:
Emperor dragonfly, Dorset, England, 2018
 notchy's gear list:notchy's gear list
Fujifilm X100V Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-Pro3
edorf_71
Wow, those are amazing! Do you get close enough with the zooms or did you use extension rings? Very nice shots.
edorf_71
notchy
Thanks! I enjoyed yours too, particularly given that they feature bees
None of the dragonfly shots above were taken using an extension ring, although I have used the MCEX-11 many times with the 55-200mm and the 50mm f2. With those lenses it works well, albeit with the inevitable shallow depth of field. Like most people I suspect, I just adjust it to the minimum or other required focus distance and move backwards and forwards until I achieve focus, allowing the OIS (in the case of the zoom) to make up for my wobbling about or else resting my supporting arm or hand on a tripod.
I really like using the 55-200mm for small animals and insects at relatively close ranges. It is relatively light weight and very flexible, giving me extra reach when things are out of range of the 80mm, which they often are. It's great for shooting things on the other side of a small stream, at the top of a tall bush, in amongst long grass, etc. It's also invaluable for getting usable shots of creatures that rarely allow you to come within a few metres before taking flight or running off. Still, for all I know you have the lens and know all about its advantages!
I've often contemplated getting a copy of the 60mm, particularly given its compact size and weight. I've seen the results and read its many glowing testimonies here and elsewhere. It seems it would be just perfect as a grab and go solution for insects and flowers, particularly here at home in the garden and as a general carry-around lens for casual trips out with my X-E3 and a Fujicron or two. I know how light and compact it is. I tried it out attached to an X-Pro2 at a local photography fair just last week. The thing is, I've spent rather a lot on Fuji kit over the last year or so, and so realistically any further purchases will now have to wait
baobob
baobob Forum Pro • Posts: 18,248
Some Bees & Bumblebees with X-T3 some others...
5
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Yeah, the 55-200 (no extension tube here) does great with dragon flies.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
notchy
Beautiful colours on that dragonfly! Which species is that?
edorf_71
Thanks for your info reg lenses. Im seriously considering getting the 80mm but its a bit expensive here in Norway. Would like to try the MCEX-16/11 on the 50-140/60mm before I decide.
Thanks.
edorf_71
edorf_71
Re: Some Bees & Bumblebees with X-T3 some others...
baobob wrote:
Those look great Bob! Works well with a zoom. Were these cropped alot?
edorf_71
edorf_71
Great shot Darn! That is seriously sharp
edorf_71
baobob
yes quite a lot at 135mm They wzere moving very quickly so that a macro lens or my 100-400mm would have been difficult to use the 18-135mm though not the perfect one is very good for changing frame very quickly
North American Yard Something. 😁
notchy
Thanks.
You're very welcome. By the way, if you want inspiration for macro photography, look no further than the flickr account of Gilles San Martin. He uses old lenses reversed, free and open source software, and has created some of the most stunning shots of insects I've ever seen. His work is so good that instead of acting as inspiration, it made me want to give up and sell my XF 80mm!
https://www.flickr.com/photos/sanmartin/
Oh, and if you view only one thing from his account, it has to to be this:
https://www.flickr.com/photos/sanmartin/7404132344/
(Watch at your own risk... don't blame me if you have resulting nightmares
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Ugh... one of these days, I’ll pay attention to the warnings.  Can’t unsee that.
Awesome photography though.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
