Panasonic HDR: the auto-alignment that doesn't.
Started May 21, 2019 | Discussions
timo Veteran Member • Posts: 5,927
From time to time posters (including me) have complained that the HDR setting on the Panasonic GX7 and GX8 is useless, because the camera doesn't align the constituent images properly. Those are the two Pannies I have; others have made the same point about other models. Some people have been sceptical.
Here are a couple of crops of shots I took of my computer screen, using the HDR setting on my GX8. This must surely be one of the easiest of images to align.
Sometimes the camera gets it right, more often it doesn't - and this applies just as much to conventional shots outdoors as it does to silly screen shots. It seems amazing to me that Panasonic has not sorted this problem, given that my humble Fuji X30 and ageing Pentax DSLRs do a perfect job.
Just making the point. Again.
Tim
'If I were you, I wouldn't start from here ... '
http://timauger.smugmug.com
http://timauger.blogspot.sg/
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Fujifilm X30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
AndyH44
AndyH44 Veteran Member • Posts: 3,110
Re: Panasonic HDR: the auto-alignment that doesn't.
Just tried the same with my GX8 / 12-60 f3.5 combo.  7 tries later and still perfect images.  No problemo!
"The world doesn't exist to satisfy your expectations."
(unknown member) Forum Pro • Posts: 12,354
Were these shot on a tripod?
OP timo Veteran Member • Posts: 5,927
No. And that’s the point. ‘Auto-align’ means that within reason you shouldn’t need a tripod. Just as HDR and pano merge in Lightroom don’t require a tripod. And my other cameras don’t require a tripod.
Tim
Have you tried shooting with IBIS off to see if the results are any different?
alcelc
alcelc Forum Pro • Posts: 19,003
I use AEB and do HDR merging in PP. Auto alignment of the in-camera HDR is far from perfect yet.
Albert
ahaslett
ahaslett Forum Pro • Posts: 12,654
My EM1.1 does a fantastic job on everything except dense arrays of branches.  Maybe the algorithm needs a certain pattern to get alignment, and text on its own is too hard?
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
I have, and it doesn’t solve the problem. It was one of the first things I thought of.
Tim
AndyH44
Is your firmware up to date?
Max Polonski
Max Polonski Regular Member • Posts: 324
On GX85\GX9 HDR is totally useless.
 Max Polonski's gear list:Max Polonski's gear list
Fujifilm X-T20 Sony a7R III Panasonic Lumix DC-GX9
vallhall Senior Member • Posts: 1,086
Maybe for text, but not for normal shooting!
 vallhall's gear list:vallhall's gear list
Sony RX100 VI Samsung NX500 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 +2 more
Max Polonski
Really ?
Mark Thornton Veteran Member • Posts: 4,570
OK, so it doesn't always work. The only failures I have had to date with my GX9 have been due to subject movement.
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Max Polonski wrote:
Really?
I have no problem with HDR. i took some inside and it did what was supposed to, prevent blown out areas
stateit
stateit Senior Member • Posts: 1,741
timo wrote:
Fantastic examples. If I wore a hat I'd doff it to you.
_vlad Veteran Member • Posts: 3,213
To put it mildly - it is quite unreliable, More often than not it fails - but sometimes I get fine result. This is for GH5. It is safer (not very convenient though) to make 3-4 tries and choose the best.
Vlad
 _vlad's gear list:_vlad's gear list
Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH +6 more
ToxicTabasco
ToxicTabasco Senior Member • Posts: 2,549
Re: Was a tripod used?
I suspect a tripod would be needed if you have those results hand held.
The newer Lumix cameras have DUAL IS which in conjunction with exposure bracketing can do hand held bracket exposure shots for HDR editing in a computer.  I know it's not the same as auto HDR or auto exposure.  But exposure merging is super easy, and you get more control over the exposure.  And if a good photo is worth working for I'll go the extra to get the better shot.
This is a 2 shot HDR panorama with two bracketed (5 shot each) exposures using exposure bracket, and merging in software.
 ToxicTabasco's gear list:ToxicTabasco's gear list
Nikon D5500 Nikon D7200 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
KenTel
KenTel Senior Member • Posts: 2,567
OK here are two shots of my screen, #1 a standard jpg, second HDR. And I get same results all the time. These are both SOOC. Full Size.
Handheld normal jpg
Handheld HDR................
Cheers. Ken.
 KenTel's gear list:KenTel's gear list
Fujifilm FinePix Real 3D W1 Panasonic LX100 Panasonic FZ2500 Panasonic G85 Panasonic Lumix DC-S5 +8 more
lescrane Contributing Member • Posts: 904
HDR on gx9 or g80 never worked for me. Even fast shutter speed, very steady camera(no tripod) would yield fuzzy images due to misalignment. Tried everything.
Why every cellphone can do HDR flawlessly.and Panny cannot is beyond me.
 lescrane's gear list:lescrane's gear list
Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus M.Zuiko 300mm F4 IS Pro +4 more
KenTel
I just wonder if this may help....
Cheers. Ken.
