In camera hdr vs post RX10IV
Started 2 months ago | Questions
ChiJeff5 Regular Member • Posts: 121
How well does Sony in camera HDR work against common independent HDR options?  I took a few a couple days ago.  It sounded like my RX10 IV took two exposures for the HDR shots.  If that's the case then obviously maybe more exposures precessed on a computer would be significantly better. Below is an example.  I think the camera saves one as a single and one as an HDR.
 ChiJeff5's gear list:ChiJeff5's gear list
Sony Mavica FD-91 Olympus XZ-2 iHS Sony RX10 IV Panasonic Lumix DC-GX9 Pentax smc DA 35mm F2.4 AL +2 more
Sony Cyber-shot DSC-RX10 Sony RX1 Sony RX10 IV
OP ChiJeff5 Regular Member • Posts: 121
Re: In camera hdr vs post RX10IV
The two pics here
Digital Nigel Veteran Member • Posts: 8,524
It takes three shots, and saves the middle and HDR shots.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +15 more
So if it saves the middle, and these two are so close, does that mean I might have done something wrong, like had spot metering on something bright?
Or do these two look different enough?
You need a wider range of HDR exposures. I seldom use HDR, as I shoot raw, but if I do feel the need for it, I use the widest aperture range. You can always add contrast back in post-processing.
Bill Borne
Bill Borne Forum Pro • Posts: 38,946
I usually shoot .3ev bracketed exposures and shoot 9 exposures and use maybe the bottom 6 of them. bottom being darkest, middle base and top lightest/
Raw or jpg..your preference
Bill
"Life's Too Short to Worry about the BS!"
So I Choose my Battles
Click for Wild Man's Photos
Using Rx10 IV at Present
 Bill Borne's gear list:Bill Borne's gear list
Sony Cyber-shot DSC-R1 Sony Cyber-shot DSC-HX400V Sony Cyber-shot DSC-H5 Sony Cyber-shot DSC-F828 Sony RX100 III +4 more
redtailboas Regular Member • Posts: 336
which is which? It's a very subtle result if that's HDR. A $100 for phone would do a better job. Try metering for the shadows and do it again?
sybersitizen Forum Pro • Posts: 12,861
EXIF says you had it on the Auto setting. You'll almost always get better results by choosing the HDR level yourself (1 through 6) according to the scene.
