Digital Card
Started May 19, 2019 | Questions
Engine1944
Engine1944 New Member • Posts: 6
Digital Card
Hello,
I just got my G9X MarkII.  Can I use a digital card from another digital camera (Panasonic)?  Does it have to be reformatted?  Thanks.
Canon G9 X Canon G9 X II
John McCormack
John McCormack Veteran Member • Posts: 7,101
Re: Digital Card
Engine1944 wrote:
Hello,
Yes. The make of the SD card doesn't matter, but format the card in the G9X camera before using it.
DonA2
DonA2 Veteran Member • Posts: 3,720
Re: Digital Card
As john stated, definitely format in camera, not on the computer.  Also you may be best off to look at buying a new card if the old one is of low capacity.  8 gb is good if not doing a lot of video.  Newer SD cards tend to be a bit faster and they are relatively cheap.
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +2 more
Engine1944
OP Engine1944 New Member • Posts: 6
Re: Digital Card
Thank you
John McCormack wrote:
Engine1944 wrote:
Hello,
Engine1944
Re: Digital Card
Thank you
