Nikon Z6 and Z7 Service Advisory
visualenvy Regular Member • Posts: 167
Re: Nikon Z6 and Z7 Service Advisory
Dang.. mine is affected.. but until I read this I wouldn't have even known.
VR appears to work fine for me so far.
Should I bother?
 visualenvy's gear list:visualenvy's gear list
Nikon D40X Nikon D700 Nikon D5200 Sony a6000 Nikon D500 +13 more
tlittlefield Regular Member • Posts: 248
Should I bother?
Issue
While Nikon has taken great measures to assure the high quality expected of Nikon products, it has come to our attention that the vibration reduction (VR) feature in some Nikon Z 6 and Z 7 cameras may not function fully. We sincerely apologize for any inconvenience this may have caused.
I think that the "may not function fully" is the key here..
 tlittlefield's gear list:tlittlefield's gear list
Nikon Z6 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 14-30mm F4 +1 more
fpessolano
fpessolano Veteran Member • Posts: 3,172
Mi è worked also well ... but I decided to sent it in as requested.
 fpessolano's gear list:fpessolano's gear list
Nikon 1 V1 Nikon Z7 Fujifilm X-T3 +1 more
Oh lovely.. I'm not US resident so no option for me
fpessolano
Sure there is
Not sure where you live but it's an issue with all Z series and Nikon will take care of it.
Just looked the the Nikon UK site and the service advisory is there as well.
avatar77 Regular Member • Posts: 100
jhde wrote:
fpessolano wrote:
And the check serial link does not work …. typical nikon
Worked just fine for me. Used Firefox.
Worked fine for me too on Safari iOS. My Z6 is unaffected.
 avatar77's gear list:avatar77's gear list
Nikon Z6 Apple iPhone XS Max
FujLiver
FujLiver Contributing Member • Posts: 687
whats your serial number
 FujLiver's gear list:FujLiver's gear list
Nikon Z6 Nikon Z 50mm F1.8 Nikon Z 35mm F1.8
Russell Proulx Contributing Member • Posts: 896
SaltyPeanut wrote:
Is there a way to get on some emailing list for these service advisories?
I don't think so. But the news spreads so quickly to the photography websites that it's pretty hard to miss. That's one huge advantage of the Web.
 Russell Proulx's gear list:Russell Proulx's gear list
Nikon D3S Nikon 1 V1 Nikon D800E Nikon Z7
SaltyPeanut
SaltyPeanut Senior Member • Posts: 1,012
Yea just checked my Nikon act and the updates about products you own is on. I got a marketing email this morning about the new FW update, but nothing about a service advisory. Either way I'll check periodically, not the end of the world.
 SaltyPeanut's gear list:SaltyPeanut's gear list
Nikon Z6 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 58mm f/1.4G
fpessolano
I Find they did it in a sneaky way, but eventually it comes out anyhow.
daveyjoneslocker New Member • Posts: 6
Z7 3001xxx is unaffected. Lucked out for once.
olyflyer
olyflyer Forum Pro • Posts: 26,429
Re: Just sent back
fpessolano wrote:
First batch in Belgium, serial 600xyz affected
Not really...
Mine starts with 600 and is uneffected. OK, bought in Sweden, but I think they are distributed from Japan globally as "Western Europe" not country wise.
 olyflyer's gear list:olyflyer's gear list
Nikon Z7
fpessolano
Re: Just sent back
I meant mine serial 600xxx from the first batch is affected
What might the defect be?
As affected owners have stated, the problem is not obvious. My IBIS seems to work ok and I've not considered that there was anything wrong with it
It would be interesting to find a site (Dpreview?) that shows an A/B comparison test of an affected body vs one that is not.
Lisa Kiehls Regular Member • Posts: 109
madecov wrote:
My Z7 shows unaffected. I've had it about 3 weeks.
Mine is not on the list either - BUT my camera is definitely sharper with VR turned off...so I believe Nikon will be expanding the list of affected serial numbers pretty soon...
Re: What might the defect be?
You should test it for yourself.
Do you have any relatively long VR lenses? Take some shots of a tree for example, with VR on and off and see which is sharper at 100% zoom. My camera yields some weird motion blur due to strange sh*t happening with the IBIS/VR. It looks like the camera was jolted, when it was not.
My 24-120mm showed this issue...
SteveCooper
SteveCooper Senior Member • Posts: 1,133
I got lucky too, my serial # said no need to send back
(that "thing" I'm playing is called an EVI, short for Electronic Valve Instrument
 SteveCooper's gear list:SteveCooper's gear list
Sony Cyber-shot DSC-F828 Nikon D500 Nikon Z7 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +14 more
olyflyer
Should I bother?
I would if mine was on the list. Something must be wrong, even if you didn't notice so far, so there is no reason not to get it fixed. They won't issue a service advisory without any reason.
Nikon Z7
