FT to MFT?
Started May 15, 2019 | Discussions
BryanJ
BryanJ Regular Member • Posts: 151
FT to MFT?
I accidentally ordered a four thirds mount Olympus 40-150 f4-5.6, I don't have an adapter, and I wanted to use it on my new g7. Should I just return it, or is there some advantage to using the bigger lens? I do want to get the Panasonic 45-150 eventually, but this was my attempt to get a zoom on the cheap. I have some Nikon lenses, a 55-200 particularly, but it is very big on the g7 and the g compatable adapter itself is heavy. So, any advice will be appreciated. I'm freaking poor, this is probably not the best hobby considering my budget, but anyway, Thanks in advance.
 BryanJ's gear list:BryanJ's gear list
Fujifilm FinePix HS50 EXR Nikon D40 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Nikon AF Nikkor 50mm f/1.8D Nikon AF Nikkor 70-300mm f/4-5.6G
Panasonic Lumix DMC-G7 Panasonic Lumix G 14mm F2.5 II ASPH
Garry Schaefer Veteran Member • Posts: 3,349
Re: FT to MFT?
14
My thought would be to return it. I believe that you would be much more pleased with the Oly MFT version of the lens (sometimes called the plastic fantastic) which can often be found at a quite low price.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
Skeeterbytes Forum Pro • Posts: 23,186
Re: FT to MFT?
Yep, it's the same lens, slightly modified optically when converted to m4/3 and definitely not worth adapting. There's an earlier, faster 4/3 40-150 that's perhaps worth the bother but this isn't the one.
The m4/3 edition is very nice to have, especially when on sale.
Rick
BryanJ
OP BryanJ Regular Member • Posts: 151
Re: FT to MFT?
Ah, well darn. Ok, I'll return it once it arrives. Incidentally, would anyone have suggestions on really low budget lens options for the G7? I think I will go with the Panasonic 45-150 since it has OIS. Like I said, I have the Nikon g adapter, using if with a 50mm 1.8 mostly though. I have a Fujian 35mm 1.7 cctv lens coming in the mail at some point, so I will have a c mount adapter FWIW. But most of my photos are of insects and spiders actually. I have a Raynox dcr-250 and some various other diopters, and mft macro tubes. The kit lens actually does an admirable job, all things considered, with the Raynox and a 10 diopter. I want to get much more magnification, but using my Nikon lenses with the Raynox just is unwieldy, and I'm afraid I'll damage something. Here's an example from today.
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Re: FT to MFT?
It seems Olympus sells that lens for $99 once or twice a year.  That's what I paid for mine.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Re: FT to MFT?
you can get a cheap electric adapter for 4/3 mounts, it is mediocre.
want dummy adapter, now you have even more mounts to choose from.
I see lots of 80-200 lenses out there really cheep.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
deep7 Senior Member • Posts: 1,083
Re: FT to MFT?
I used the older 40-150 4/3 lens on an EM1 and it worked well.  However, that's because the EM1 series have phase-detect autofocus, which the 4/3 lenses really need.  They don't work at all well on other Olympus bodies or Panasonic bodies.  Further, the genuine adaptors cost more than you can get the m4/3 lenses for!
One option is to find a second hand Panasonic 45-200.  It's not a good 200mm lens but it's a great 45-150, probably better than the other cheap options in that range.  Just be prepared for bitter disappointment if you go longer than that 150mm...
Don.
A Land Rover, a camera ... I'm happy!
(unknown member) Forum Pro • Posts: 12,354
Re: FT to MFT?
Are you using a tripod to take those kinds of shots? because if you are get the cheaper m.zuiko 40-150mm, it's an excellent little lens which will work very well for this kind of thing and the bokeh from it is actually pretty good.
Harold66
Harold66 Forum Pro • Posts: 12,002
Re: FT to MFT?
Yes i got one at that price a few years back and then misplaced it . And i got another new one at 59$ once
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
Re: FT to MFT?
Am I correct in thinking the G7 does not have IBIS? If so, I'd look for a well-priced Panny mid-range tele with OIS, because the longer the lens the more benefit IS provides, particularly as you either wish to stop down or the light is lacking.
Opinions on the Panny mid-tele zooms seem all over the map and I'll defer to those who have used them. There must be at least one that shines across the zoom range.
Rick
BryanJ
Re: FT to MFT?
I do mostly shoot handheld, so I do think I better look for a Panasonic on the cheap. For macro, I'm actually considering getting a Raynox msn-202 that is higher magnification than the 250. I am thinking that may actually work good with the kit lens, it doesn't have a huge zoom but I'm getting pretty close now, and I could remove a layer of glass, get closer, but because of the limited zoom range, I will probably still have decent dof for that diopter. I would then have time I think to get the zoom at my leisure. I have a 1000mm effective zoo on my Fuji, it isn't great in low light, but it has more range than I'll ever get with the g7 handheld, I can mostly stick to that for birding. The kit lens actually isn't terrible with a Cano 1.6x screw on teleconverter I have, that with the ezoom is ok for just running about. So, getting my macro rig as light as possible is most important. Any thoughts on the msn-202 idea?
