AF-mode selection button not working on Nikon D500
Started May 15, 2019 | Discussions
estemar20 New Member • Posts: 1
Hello,
I am referring to the button on the side of the camera where you switch between AF and M. Normally when pushing the button, you can switch between auto-focus modes while rotating the back wheel. When I press it now, there is no response. It this known to be an issue?
Thanks for your help, it is appreciated.
Nikon D500
Doug Haag Senior Member • Posts: 2,879
Re: AF-mode selection button not working on Nikon D500
estemar20 wrote:
Hello,
With the F4 custom setting you can change to operation of the main and sub-command dials.  What happens if you rotate the sub-command dial on the front of the camera?
lokatz
lokatz Veteran Member • Posts: 3,569
Doug, you would still see a response even if front- and back-wheel traded places. One changes Focus Mode and the other Focus Area Mode.
I cannot think of a reason why the AF button would not respond.  As always in life, the first thing I would try if nothing else seems to work is a factory reset. If the problem still exists, this may be a service issue.
 lokatz's gear list:lokatz's gear list
Sony RX100 VII Canon EOS R5 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +31 more
You are of course correct, lokatz,  I was wondering if both dials were unresponsive to a press of the mode button or just the main command dial.  If both were unresponsive it would seem to point to the mode button itself.
I have my camera set up so that you don't need to maintain pressure on any of the buttons for them to allow the control dials to adjust the relevant feature.  (F6 setting)  I assume that in factory default mode you have to maintain pressure on the button while rotating the control dial.
Alexander Meredith
Alexander Meredith Senior Member • Posts: 1,045
Check Custom setting A10 is set to "no restrictions".....
 Alexander Meredith's gear list:Alexander Meredith's gear list
Nikon D7500 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR Tamron 100-400mm F4.5-6.3 +1 more
Mick353 Forum Member • Posts: 86
There's a dial on the back of the camera where the L is located.. have you rotated it inadvertently?
briantilley
briantilley Veteran Member • Posts: 7,646
I can't see how that would have any influence over this particular issue.
 briantilley's gear list:briantilley's gear list
Nikon Df Nikon Z7 Nikon Z6 Nikon Z fc Nikon Z9 +26 more
I don't either.  It would affect whether you can move the focus point with the mulit-selector.  But should no affect which AF mode you are in.
But in any event, the original poster has not returned to the thread since the original post two days ago.  Note also this is OP's first ever post.  We may never know whether or not it really was a problem or if one of our suggestions turned out to be the solution.
arniebook
arniebook Senior Member • Posts: 2,454
Good call! That's got to be it.
Now if the OP will respond? ....
What we spend on this stuff is equal to the depth of our pockets squared ($²) times what we (j)ustify in our minds as to what we expect to do with our pictures plus (+) the (e)njoyment we experience from using our stuff and sharing the result ... $xxxx=$²(j+e )
 arniebook's gear list:arniebook's gear list
Nikon AF Nikkor 50mm f/1.4D Nikon 200-500mm F5.6E ED VR Nikon D300 Nikon D500 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +3 more
Sagittarius Veteran Member • Posts: 8,684
OP stated that when he/she pressed the button, there is no response. I take it that there is nothing shows up on the top LCD. Even if you set A10 to any mode other than "No restrictions" that AF mode and area modes supposed to show up.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z9 Nikon Z 14-30mm F4 Nikon Z 85mm F1.8 +4 more
arniebook
Yes, the current settings show, but there is "no response" (nothing changes) when the wheel is turned.
Since OP has "no response" on his/her thread there is no need for further discussion on my part.
Arnie
chrishhh New Member • Posts: 2
I had this problem today.  A9 was limited to single point AF.  Check all the options and it solved the problem.
I had this issue today. A9 was set only for single point. Check all of the options and hit OK … this solves the issue. A few years late but if anyone else experiences this issue hopefully this is their easy fix.
PINTIE New Member • Posts: 1
Displaying Autofocus Area Modes on NikonD500
Hello,
Same thing happened to me! After 20 mins of head scratching I finally found out the answer. My lens was on M (Manual) and camera Autofocus Mode Selecter button was on AF. After switching on lens to AF also, issue sorted and Autofocus Area Mode correctly indicated on LCD screen and viewfinder. In short both lens and camera should be on AF.
