GR lll Review
Alex Sarbu Forum Pro • Posts: 10,139
Re: GR lll Review
James Bligh wrote:
James Bligh wrote:
Alex Sarbu wrote:
Olifaunt wrote:
James Bligh wrote:
I think color issue at least in JPEG is established in dpreview GR3 review though color desaturation in RAW as ISO climbs up is not adequately addressed.
https://www.dpreview.com/reviews/ricoh-gr-iii/5
Hi James. I just looked carefully at the GRiii studio test scene. Even at ISO 100 something funky is going on in the test scene with the jpeg - there is indeed obvious desaturation in the color patches and they are very uneven and full of cross-hatching, worms, and other artifacts artifacts - for example, the cyan patch looks pretty wretched.
But I think this is jpeg sharpening and noise reduction settings (as well as sharpening and NR in whatever viewer DPR uses for the RAW file too).
Are you talking about this?
Something's fishy, as I downloaded the JPEGs - both the in-camera and the ACR generated one - and there's no such cross-hatching. Cyan is looking better, too. A display issue with the DPR widget, perhaps?
Alex
I see crosshatches or fine crossing lines and halos in cyan and pink squares in jpeg. I also find color of cyan dirty and that of pink muted in RAW. And it is in ISO 100.
I may be mistaken. I see fine crossing lines also in the picture Olifaunt uploaded.
https://www.dpreview.com/forums/post/62676964
What I saw may be a monitor thing though I don’t know the right term for what I see. BTW what exactly does crosshatch look?
Well, it's not real crosshatching - but how should I call it? I'm talking about the artifacts clearly visible on the left side patch above.
I see no issues with Olifaunt's picture, perhaps you could be more specific? The display chain - application/OS/drivers/video board/connection/monitor cannot be fully trusted either. For example, one can get interesting effects just by increasing the monitor's sharpening.
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +8 more
James Bligh Senior Member • Posts: 2,354
Re: GR lll Review
Alex
Alex
I have dug into what cross hatching is.
https://en.wikipedia.org/wiki/Hatching
https://www.wikihow.com/Cross-Hatch
https://www.youtube.com/watch?v=G-279TvNv1A
Now I know what crosshatch is.
What I have seen in your sample and Olifaunt’s picture seems to be vertical and horizontal lines of pixels of monitor* which are easily seen especially in bright color patches such as cyan and yellow.
* They are real crosshatches. Aren’t they?
I think what I have seen so far is the crosshatching in monitor screen, not an artifact which looks like crosshatch in picture but I can’t imagine it is not a real thing when dpreview has said the following.
(quote)
As that ISO value climbs even higher, we begin to clearly see evidence of this noise reduction on the GR III's Raw files (it's that sort of 'cross-hatching' pattern).
(unquote)
You really want you a pound of flesh, don't you?
-- Mallory to Miller in the movie 'The Guns of Navarone'
SwedishPhoto Regular Member • Posts: 424
Re: GR lll Review
illd3fined wrote:
yup fair except for not noting the existence of anti-glare screen protectors
The review isn’t, and shouldn’t be, for third party accessories, especially accessories that fixes any kind of issues.
So you can’t really fault the review for that 👀
 SwedishPhoto's gear list:SwedishPhoto's gear list
Fujifilm X100F Canon EOS M Sony a7 II Sony a7 III Sony FE 70-200 F4 +7 more
Andrew Mitchell Senior Member • Posts: 1,810
Re: GR lll Review
Ken Bates wrote:
Hi All. Just read the review for the GR.lll and all seems fair enough.
The only thing I would add is that I can handhold at 1/4 sec. with about 80% critical sharpness rate. ( double that time for macro )
It's not cheap. I would have liked to have keep the GR ll flash.
But I must say, I love this camera.
Thanks all.
Strange they didn’t mention the camera being crippled (for some of us) by the lack of common aspect ratios. Which other camera makers seem to have no difficulty having.
For me, the aspect ratios, lack of flash, and very poor focusing in low light are totally unacceptable in a camera in this price bracket. And I was soooo looking forward to it. Bummer!
Andrew (Brit expat in Taipei, Taiwan since 1985)
Color of GR3 RAW
There's no unusual color desaturation as ISO climbs up. On the contrary, the GR III is quite good at keeping the color.
Alex
Premature color desaturation of GR3 RAW
Here is a sample at ISO 800 but color desaturation in RAW is noted even in base ISO or from ISO 200. It is subtle but it is there.
https://www.dpreview.com/reviews/image-comparison/fullscreen?attr18=daylight&attr13_0=ricoh_griii&attr13_1=nikon_d7200&attr13_2=nikon_d610&attr13_3=nikon_d800&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=800&attr16_1=800&attr16_2=800&attr16_3=800&normalization=full&widget=673&x=0.3425143380301338&y=0.23260128517394898
Re: Color of GR3 RAW
Alex
I strongly disagree with your assessment.
First, you're using the comparison widget which doesn't work properly. But let's ignore that for now.
Second - and most important - your selection is not meant to show color desaturation. Some things to note:
- if you compare the GR III at ISO 100 and ISO 800 (and higher) you'd notice how well it keeps the color. There's no noticeable desaturation; just the extra noise.
- you instead are comparing different cameras, with different processing profiles (and a software that didn't yet support the GR III).
- even more, you are trying to be unfair by including full frame cameras.
What you're describing is basically the Loch Ness monster - you say it's there but it just can't be seen.
Alex
teemodk Senior Member • Posts: 1,261
Alex Sarbu wrote:
Alex
Alex
I came to same conclusion, comparing GRIII raw samples at 100, 800 and 3200. I did not notice any shift in colors. Was actually going to compare in darktable with real values from the eyedropper, but will pass for now, seeing your post.
What we are seeing in the Nikon comparison is just wrong interpretations of the raw files from ACR.
I was l playing with these raw files yesterday in darktable. I do get color variance "patterns",  as noted by olifaunt and others, in the colors of the color checker when reading the file without any kind of filtering. But processing with a tiny bit of raw denoising, will clean it up without removing important detail. There is a fair amount of colors that needs to be removed in the old BW picture, but that's expected.
 teemodk's gear list:teemodk's gear list
Oppo R7 Plus
Another issue to note with the dpr comparison it's the very dark processing of the GRIII files. Mostly due to the missing vignetting correction, but generalize I think the images are too dark.
I made a quick profile for darktable and like what I so far. It's by no means perfect, but shows good potential.
Oppo R7 Plus
Alex Sarbu wrote:
Alex
That's why I said premature color desaturation of GR3 RAW. And correct wording may be 'There seems to be no further noticeable desaturation; just the extra noise.'
I included Nikon D7200 which has same APS-C sensor with same MP count as that of GR3, same 24 MP but FF D610 and 36 MP FF D800. So GR3 vs. D7200 is a peer comparison and D610 for same MP count but to compare APS-C with FF and D800 for 24 MP APS-C vs. 36 MP FF. I think all meaningful comparisons they are, interesting comparisons at least.
The truth may be we differ in interpretation of fact. The fact is standing like a mountain. When you are blindfolded of course you cannot see whatever there is.
Alex
James Bligh wrote:
Alex Sarbu wrote:
Alex
Your "premature color desaturation" simply means that you don't have a base line. It simply means you cannot show any color degradation as ISO increases - because there isn't any.
Same? Are you sure about that? Does it have the same Bayer color filter array? Does Adobe process the RAW files in exactly the same way?
Only to the point that you still fail to show this supposed issue, despite such an unfair and incorrect comparison.
Curiously, when you are blindfolded you might see what isn't there.
Alex
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
When you compare GR3 RAW with its peer (for example D7200) RAW and GR3 RAW shows color desaturation at each ISO does it not mean anything?
Don't make things complex. It is a common sense to make things as simple as possible when you make an argument. Making things complex only makes things complicated and unsolvable.
Supposed issue? If you do not admit an issue I do not have to argue with you. It's a waste of time.
I wear glasses not a blindfold. Isn’t it a paranoia to worry about something which is not real?
Alex
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
Oh, but you never compared the RAW files - but converted RAWs, their displayable interpretation by some processing software or another.
And any color difference can means many things. I would rather suspect processing differences and/or Bayer CFA differences, than make up theories about noise reduction uniformly desaturating the colors at every ISO.
Would you rather have me not ask the obvious question, and go with prejudice instead?
Yes, supposed issue, because you were unable to demonstrate it.
I honestly don't care what it is, but your anti-GR III tirade is tiresome. I'm here to learn about a still unfamiliar brand, not to hear about imaginary faults of my camera.
Alex
Olifaunt Contributing Member • Posts: 770
Hi James, no, the comparison really doesn't mean anything. You are comparing apples to oranges. RAW files really don't have any specific color interpretation - the exact same raw file can be rendered to look like manhy different kinds of color film, for example. I would recommend that you look into what an ICC color profile is if you don't know already. That is where the color interpretation of a RAW file comes from, and the profiles are different for each sensor, each camera manufacturer, each RAW editor, etc.
illd3fined Regular Member • Posts: 454
Olifaunt wrote:
Hi James, no, the comparison really doesn't mean anything. You are comparing apples to oranges. RAW files really don't have any specific color interpretation - the exact same raw file can be rendered to look like manhy different kinds of color film, for example. I would recommend that you look into what an ICC color profile is if you don't know already. That is where the color interpretation of a RAW file comes from, and they are different for each sensor, each camera manufacturer, each RAW editor, etc.
this exactly James
what precisely is your problem with moving a default jpeg setting or RAW slider +2 to the right? more importantly, is it worth all the dark misery you hold deep inside you and want to spread outward? there's already so much real world negativity to deal with
 illd3fined's gear list:illd3fined's gear list
Sony RX100 II Ricoh GR III Apple iPhone XS
One could look at the non-interpreted binary values, using a tool like Raw Digger - but even then, there are many more plausible explanations (like a different CFA).
There are people way more knowledgeable on this subject than me - Iliah Borg for example - but I'd say, the fact that the color is consistent even as you increase the ISO means James' theory is completely bogus.
Besides, AFAIK the accelerator doesn't remove noise at base ISO.
Alex
John Gellings Veteran Member • Posts: 5,262
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
  • if you compare the GR III at ISO 100 and ISO 800 (and higher) you'd notice how well it keeps the color. There's no noticeable desaturation; just the extra noise.
  • you instead are comparing different cameras, with different processing profiles (and a software that didn't yet support the GR III).
  • even more, you are trying to be unfair by including full frame cameras.
Alex
I’m not sure how I can even use this camera anymore ... I mean, it’s got so many problems that non users have Found that us users haven’t. Let’s hear it for the non users everyone!
 John Gellings's gear list:John Gellings's gear list
Ricoh GR III Sony a7R II Fujifilm X-Pro2 Fujifilm X-E3 Fujifilm XF 27mm F2.8 +5 more
John Gellings wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
Alex
Only remember GR3 RAW files are desaturated whatever the cause may be. Knowing this may give you a sailing tip at the very least.
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
Alex
James, I don’t need the tip. I’ve been using it and the colors are not desaturated in any meaningful way to me. In fact they are more saturated than my Fuji files. I can base my information off of hundreds of photos I have made, not from a few random photos on the internet.
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
Alex
Remember this too. There is a huge difference between 'in any meaningful way to me' and 'in any way'. The former has two conditions attached; those are 'meaningful' and 'you'.
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
James Bligh wrote:
Alex Sarbu wrote:
Alex
Alex
True, but my opinion is based on actual use. Yours is based on you being upset at Ricoh for not making the perfect camera for you.
