High megapixel crop mode
Started 1 month ago | Discussions
Doug Larvey Regular Member • Posts: 332
The future of all cameras will result in extremely high megapixal sensors , full frame.
The need for long bulky heavy zooms will be of days past.
Attached will be a lens with fixed focal length of 28mm at F1.2 or 1.4
Take the photo of the distant bird. Simlly crop out 50 mpixels your left with 25 to spare.
You want to zoom in on the beak?
Keep croppin.
Down to 10 Megapixels.
Proceed to print a poster of a birds beak.
The future my photographic friends.
FingerPainter Senior Member • Posts: 7,610
Re: High megapixel crop mode
Keep croppin.
Do that and you will get an unsharp, noisy image with very shallow DoF.
Chaplain Mark
Chaplain Mark Senior Member • Posts: 4,826
I really doubt it.
Cropping from a high mpx count will not replace the resolving power of first-rate glass.
Those of us who combine said resolving power with the insane resolution of high mpx sensors will continue to forgive the bulk and weight of long lenses.
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
In pursuit of photographic excellence.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III +2 more
OP Doug Larvey Regular Member • Posts: 332
Hi Fingerpointer.
The shallow depth of field yes.
The noisy photo. Nope
sybersitizen Forum Pro • Posts: 12,635
9
It's really great to have seers into the future to help us understand our complex and ever-changing world. And I'm so looking forward to having every telephoto shot use only a tiny fraction of the sensor, completely ruining any hopes of high resolution, subject Isolation, DOF control, and light gathering area. Let's celebrate!
nevada5
nevada5 Forum Pro • Posts: 13,297
And - that extra metering mode
You know, the Teensy-Weensy super-small-like-a-pin-head metering mode.
Hey, that's a catchy name for it.
Stay thirsty, my friends.
I'll try to be nicer if you'll try to be smarter.
It's fun being me -- Denny Crane.
 nevada5's gear list:nevada5's gear list
Canon PowerShot S120 Panasonic LX100 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
Adrian Tung
Adrian Tung Veteran Member • Posts: 3,679
I'd like to see the 9000 lines/mm MTF chart of this mythical lens first.
 Adrian Tung's gear list:Adrian Tung's gear list
Sony RX100 III Olympus Stylus Tough TG-870 Sony RX100 VI Olympus PEN-F Panasonic Lumix DC-G9 +12 more
6
Doug Larvey wrote:
Hi Fingerpointer.
Doug,
The noisiness of a photo depends primarily on the amount of light captured in it. If you are cropping to any significant extent, you will have thrown away most of the captured light. What remains will be noisier than the uncropped photo.
If you crop so the width and height of the crop are only 1/4 the width and height of the full image, the crop will only have about 1/4 the SNR of the uncropped image.
How noisy an image looks depends on its Signal to Noise Ratio (SNR). The higher the SNR, the less noisy the image appears. The amount of noise in light (shot noise) is equal to the square root of the signal (the amount of light). This means that the SNR is also equal to the square root of the amount of light. Capture more light and the SNR goes up. The image will look less noisy.
You are aware that cameras with smaller sensors produce noisier images, at the same exposure, aren't you? That's because the same exposure means the same amount of light per square mm of the sensor, and a larger sensor has more square mm so it captures more light.
Perhaps this analogy will help you understand.
Imagine a choir in which a number of singers equal to the square root of the total number of members in the choir sing off key. All the other choir member sing on key.
If the choir only has four member, 2 singers will be off-key. You will hear that for sure. If the choir has 16 members, four of the sixteen singers will be off key. There's still a pretty good chance you will notice them. Now imagine if you got 324 members of the Mormon Tabernacle Choir together and 18 of them sang off key. You almost certainly would not notice. They be drowned out by the other 306 voices. Even though more choristers are singing the wrong notes in the 324-voice choir than in the four--voice choir, the much greater number of voices singing the correct notes makes it harder to detect the variation.
That's how noisiness works in a digital image. When you crop an image down to a small part of the original, it is like picking a four-voice choir out of the mass choir - you are going to hear the wrong notes (see the noise) much more readily.
DeathArrow Senior Member • Posts: 1,051
I doubt that. If the glass can't resolve those megapixels, they're useless. Maybe the high resolution will come from SR or Pixel Shift like in Pentax, Olympus and Panasonic cameras.
 DeathArrow's gear list:DeathArrow's gear list
Nikon D750 Nikon AF Nikkor 50mm f/1.4D Tamron SP AF 90mm F/2.8 Di Macro Sigma 85mm F1.4 EX DG HSM Tamron SP 24-70mm F2.8 Di VC USD +3 more
AwesomeIan Senior Member • Posts: 2,087
Keep croppin.
It doesn't work that way. People would already be done this with a 50mm lens on a D850 if it worked. The problem is far away objects wont retain the same amount of detail as they would if you use a telephoto lens. Another thing to consider is bokeh. You would always end up with exactly ZERO is you use a wide lens and crop to a birds beak.
 AwesomeIan's gear list:AwesomeIan's gear list
Nikon D500 Pentax K-1 Pentax smc D-FA 100mm F2.8 Macro WR Tamron SP 150-600mm F/5-6.3 Di VC USD HD Pentax D FA 24-70mm F2.8 ED SDM WR +7 more
Tuloom Veteran Member • Posts: 3,128
Keep croppin.
And flying cars, don't forget about the flying cars.
tbcass
tbcass Forum Pro • Posts: 41,724
Doug Larvey wrote:
The future of all cameras will result in extremely high megapixel sensors , full frame.
For some people yes but no matter how much resolution a camera has long telephotos will allow you to get even closer. For that reason the need for long bulky heavy zooms will always be there.
Tom
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM +10 more
Zabalint Regular Member • Posts: 189
Ok, then what about using a 600 mm lens on the same high megapixel sensor, and then I will crop that picture to 10 megapixels?
 Zabalint's gear list:Zabalint's gear list
Panasonic Lumix DMC-ZS50
tkbslc Forum Pro • Posts: 13,126
Maybe once we have 5+ gigapixel sensors?
Keep croppin.
I would say the minimum telephoto you'd need to shoot "distant bird" would be 500mm equivalent.    To crop a 28mm lens to 500mm equivalent would reduce the resolution by 99.7%.  (17.3x crop and then 17.3^2 to calculate area lost)
To be left with 25MP, you'd have to start with 8300MP or 8.3 gigapixels.
Cropping reduces megapixels rapidly becuase while cropping is a linear dimension, megapixels is an areal dimension.  Which means the equation is exponential.
A 2x crop reduces area to only 25%.  You've already lost 75% of the pixels with just this first "small" crop.  Still taking having 12.5MP out of 50MP still leaves you with a lot of room.
3x crop means 1/9 the original pixels.  50MP is down to 5.6MP.   Getting a bit dicey, but still usable for small to medium prints.
4x crop and we are down to 1/16.  Already a 50MP sensor is down to just 3.1MP.
5x crop is 1/25.   50MP sensor becomes 2MP.
10x crop  is 1/100.  You'd need a gigapixel sensor to end up with 10MP.
Maybe software will get better to compensate for the loss, but I don't see going beyond 3-4x with a crop, even with sensors beyond 100MP.
Hi again
Wonderful analogy using the choir. Noise seems to be a problem.
Too bad.
Schrodingers_cat Senior Member • Posts: 2,247
It will also be the size of an aspirin tablet and implanted into your forehead
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 13,409
Hmmmm...
40 mm lens equivalent
Keep croppin.
63 mm equivalent
Don’t bird photographers use 500 or 800 mm lenses?
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
John Sheehy Forum Pro • Posts: 21,569
Keep croppin.
There may be some value to having enough pixels to crop from more heavily (and I am a big fan of high pixel density), but you are a bit over-optimistic about the other limiting factors, and your math is a bit off. Pixels drop off *much* faster than you are implying; a 10x digital zoom loses 99% of the original pixel count, and a 10x digital zoom from a FF with 28mm is still very wide for a small bird, and it would be a very sharp, expensive 28/1.2 lens indeed to deliver those measly MPs with desired sharpness, which is precious with low pixel counts.
Re: Hmmmm...
In most real-world photography of small birds like sparrows, warblers and vireos, I still have to crop from 800mm on a 1.6x APS-C sensor, even when the birds are closer than normal.  Only on rare extra-close occasions or with much larger birds, is the FOV too narrow.
stevo23 Forum Pro • Posts: 21,125
Keep croppin.
Don't know if it's really going to work that way.
The megapixel wars are slowing down, there are practical limits to pixel density. And the big, heavy bulky zooms are just the ones that will be required to get beyond the limits of your cropping ability.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
