So I have the RP .. and I shoot (mostly) RAW .. but I do want to get an excellent looking picture directly OOC. It's like I want the OOC JPEGs to look as good as possible and as close to the end-result as I like to see it. So I shoot in Fine Detail (5,2,4,0,1,0)
My workflow is shoot RAW, import in DPP, and export/convert ( almost without editing ) the images into JPEG. DPP 'takes' all the in camera settings, so this is for me a very efficient workflow. In case I do not edit in DPP, the JPEG from DPP is identical to the OOC JPEG, so the below is hopefully also useful for JPEG shooters. In case I do want to or need to edit, I can do it stating from RAW.
I was looking for the best picture style setting for a range of shooting conditions, including landscape, nature, street, architecture, some macro and people pictures.
I know that for each shot you can set an "optimal" picture style, but I was looking for a "2 size fit's all" solution:
- one for ALL my pics where people / portraits are the main focus and
- one setup for ALL others.
This first thread is about " the picture style I use for ALL others.
I found not too much info on this topic on WWW, so I decided to share my findings with all of you.
Each Canon picture style has a unique combination of sharpness, contrast, saturation and color tone. You can see in camera the possible sections for sharpness, etc, but for each color profile the individual colours are 'boosted'/'saturated' to a different level. This info is very hard to get. But as an example in picture style Landscape, the greens and blues are extra "boosted/saturated'. These specific differences are less easy to identify in other picture styles.
On my old 1100D I always liked landscape best, but that was typically less optimal when 'other than green / blue' was present, so I started to look for something "better" and I found, with some small modifications, Fine Detail to be the most of my liking.
I actually shot in most of them, but will not share the entire journey - that would use up too many pages here on the forum.
As of now, for landscape, building, macro, street, my setting is: Fine Detail, Sharpness set the same as for the Landscape profile ( so 5,2,4, because this gives clean, crisp, sharp images, the in camera Fine detail settings are more for high resolution sensors ) and Saturation set to +1 ( because when set to the default '0" the images are too flat. The contrast and Color Tone I leave at 0. So the full set it: 5,2,4,0,1,0.
It's also much better to shoot people pics with Fine Detail than landscape. Shooting people with Landscape always makes them look a bit green. But I need more time to find the optimal people picture profile.
Some sample pictures with some explanations.
This is my preferred "look and feel" for nature - this is the standard Landscape profile, but for pictures with more and additional color - Landscape does not render those nicely.
Fine detail (5,2,4,0,1,0) - this comes VERY close to the standard "landscape" look I like. Nice greens, nice blues and a nice level of "pop" but not overdone. Image is nice and sharp, also in the horizon.
Fine Detail (5,2,4,0,1,0) - nice brownish and whitish tints on the skin. Shot the cows also with "Landscape" but they look a lot "flatter" and "plain white" in that case. ( The cows were walking towards me - so sorry for the slight back focus) ( When I pulled my eye from the view finder I realised .. Objects do look bigger in real life .. )
Standard. Shot indoor, with a mix of daylight and led lamps. Notice how the fruit is almost subdued in the wooden bench.
Landscape. I like this already better than Standard.
Fine Detail (5,2,4,0,1,0) Slightly warmer on the wood when compared to Landscape. The white wall becomes a bit "coloured" which adds to the warmth of the picture.
Standard picture style. Actually this is quite realistic from color point of view - but also a bit "boring".
Fine Detail (5,2,4,0,1,0) The fruit stand out, the brown tints of the wood are warmer and the whole is not overly cooked. The reds are much more "red" as when compared to Landscape and Standard.
So what picture style do you use for your general purpose pictures ?
I still need to check which settings I like best for people - it's probably going to be "Picture Snapshot" which you can download from the Canon website. I will go test it out and report out later. Any other suggestions ?
