Is there an affordabe glass tube for a6500?
Started May 13, 2019 | Discussions
DigiPainter Regular Member • Posts: 301
I like my 4k and my lenses and APSC seems plenty bright enough as I freedive mostly on top water. But the seafrogs is plastic for the wide angle lens.
Can another tube be put on it?
Sony a6500
Barmaglot_07 Contributing Member • Posts: 633
Re: Is there an affordabe glass tube for a6500?
You mean an optical glass dome as opposed to an acrylic one? No, all the domes sold by SeaFrogs are acrylic, and to the best of my knowledge, there are no adapters for other port systems (Zen, Sea & Sea, etc). If you really want all glass elements, consider using a Nauticam WWL-1 wet wide lens with the short macro port and 16-50mm lens.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
OP DigiPainter Regular Member • Posts: 301
Thanks for that. I just figure no point using a good lens if shooting through plastic.
That's not really accurate. As far as image quality is concerned, there is little difference between acrylic and glass, aside from glass domes' higher propensity to flaring. Acrylic domes are easier to scratch if you aren't careful, but they're also easier to polish - glass domes are nearly impossible to fix if you do manage to scratch one. The layer of murky water between port and subject will have a far more pronounced effect on image quality than the difference between glass and acrylic, as will misalignments between dome's nodal point and lens entry pupil.
Thank you for that. I am as you can tell, very new to this.
So for example, with an Acrylic dome, my 35mm f1.8 will be noticeably better IQ than the 18-55 kit lens, providing the Viz in the water is good obviously?
It seems the sea frogs salted line is just incredible value for the a6000 series?
I will move to FF once I have the money together to move the canon R series and new lenses.
You have to remember that the cardinal rule of underwater photography is to get close, and if you think you're close enough, get closer still. With that in mind, 18-55mm has the potential to get considerably better shots, because 18mm will let you shoot the same subject from half the distance of 35mm - for example, a 50cm subject will fill the frame from 40cm at 18mm, and 80cm at 35mm. You can also use the 55mm end with an add-on wet diopter as a macro solution. There are, however, some nuances:
  • SeaFrogs does not have a port and zoom gear solution for the 18-55mm lens; only for the newer 16-50mm. If you want to use 18-55mm, you will need a different, more expensive housing such as Nauticam.
  • 18mm (or 16mm, for that matter) on APS-C is not generally considered sufficiently wide for underwater shots on its own; such lenses are often augmented by wet wide lenses like Inon UWL-H100, Kraken KRL-01 or Nauticam WWL-1 in order to extend their field of view to 100-130 degrees diagonal.
  • On subjects that won't let you get close (e.g. sharks), the 35mm focal length might come into play, but any differences in IQ between lenses (already minute because you're likely to be shooting stopped down around f/8) will be lost in the noise introduced by the layer of water between lens and subject.
Regarding full-frame in general and Canon EOS R in particular, you need to keep in mind that underwater, full frame is often more trouble than it's worth. The light-gathering advantage doesn't come into play much because most of the time, you're shooting stopped-down with strobes, and the thin depth of field doesn't play well with dome ports, requiring huge, heavy, unwieldy and expensive domes. Likewise for macro - in most situations, you want as deep a DoF as you can get, which does not exactly play into full-frame's strengths. If you want 45-50MPx sensors for printing and cropping then you don't really have an alternative, but there are many people who shoot DX/APS-C, M43 and even 1" because of the problems with large sensors underwater.
Another point which is often ignored early on is that strobes, while expensive, provide possibly the best bang for your buck in terms of image quality improvement. Aside from the shallowest of depths, the best full-frame camera with the best lenses and the best ports using ambient light will lose miserably to a cheap P&S with a decent pair of strobes.
