Fuji X-t100 AF vs Nikon D5300's
Started May 13, 2019 | Discussions
D Longhi New Member • Posts: 5
Hello,
I have just bought a Fuji X-t100, after comprehensively reading about it online. I am a hobbyst street photographer, with interest in portraits and doc-photography.
I had a Nikon D5300. Although it worked fine, I was a little bothered with its colours and its size. Since I strive for the candid shot, it didnt help the buldgy camera making me look like a creep spy lurking around.
I chose the xt100 for its size, price (am Brazilian, and the difference to a X-t20 would be around a thousand brazilian bucks [reais, ahem], which is considerable) colours and overall fuji quality. Also bought a fuji 35mm f2 to go with it.
My question is: having read about its slow AF, how slow is it exactly, comparing to the D5300? Although being into street-ph, I never feel the need to capture fast-moving objects such as moving cars, bikers, and such. I practice a more contemplative kind of photography, if I may say so.
So, in a nutshell: AF-wise, was it a step back?
Thank you all in advance for your contributions!
Fujifilm X-T100 Fujifilm X-T20 Nikon D5300
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Re: Fuji X-t100 AF vs Nikon D5300's
D Longhi wrote:
Hello,
If you now have the camera you can see for yourself the af is excellent, don’t worry about what others say x-t100 is top class, it’s sensor is one of the best, at any price, enjoy 😊
OP D Longhi New Member • Posts: 5
Advent1sam wrote:
D Longhi wrote:
Hello,
Thanks for your answer!
I bought it online, it is yet to arrive. Hope you're right! I've noticed you are quite the X-T100 enthusiast.
Advent1sam
D Longhi wrote:
Advent1sam wrote:
D Longhi wrote:
Hello,
Lets put it this way, I wish my x-h1 had the x-t100 sensor and some of the functionality too, pasm dial for one!
jjz2 Veteran Member • Posts: 4,396
I had a D5300 years ago in like 2014, don't have XT100, but will say the X E2 is a step back in AF from the Nikon. I like the files and using the Fuji better though.
I've used D5300 on a safari and it tracked lions and zebras at night, the X E2 would def struggle in that kind of condition. It had 39 point AF and same autofocus as it's flagship Crop DSLR of the time, just in a smaller cheapish plastic body with no in body AF motor.
Note I also had the small Canon SL1... this was also back when I couldn't afford Fuji's lenses, but prices are way down for Fuji with many more options.
For a camera, Fuji is for sure the better experience IMO to either of those smallish Canikon DSLRs.
For street with the 35 f2, why not just prefocus? That lens is pretty snappy anyway I'm told.
Welcome to shooting Fuji..
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
Desperadude Regular Member • Posts: 121
I had the d5300, and now x-a5 which has the same sensor than xt100
The xa5 AF is for sure slower, but you won’t notice it until you shoot action. On a scale of 10 if the d5300 is 7 then the xa5 is around 5. Also in low light the d5300 definitely focus much better
My eval is based on latest FW for xa5
(unknown member) Forum Pro • Posts: 16,732
D Longhi wrote:
Hello,
It will easily cope with anything you find on the street. May not be as good as some DSLRs for sport, but it has the sensor from the XT2, so it should not be that bad.
Moreover, it will focus more accurately than any DSLR across all its focus points, and no focus tuning is ever required.
I notice folks have mentioned XE2 and XA2. The X-T100 has a later gen sensor. I can shoot sport just fine with my Xpro2.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
Rmcp20 Senior Member • Posts: 1,518
57even wrote:
D Longhi wrote:
Hello,
AF speed depends a lot on the processor, and the X-T100 processor is not the one on the X-T2, X-T20 or X-Pro2. Its definitly not a camera for action. In AF-S, quick enough.
 Rmcp20's gear list:Rmcp20's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm 50-230mm II Tamron 100-400mm F4.5-6.3 +3 more
Threaded Veteran Member • Posts: 4,180
57even wrote:
D Longhi wrote:
Hello,
Neither the XT100 sensor or processor is the same as the XT2 (Adventsam would spit at the idea!)
The sensor is a 24mp Bayer chip with some different properties to anything X-Trans (including a very slow read rate apparently). The processor is an unnamed chip that is a bit of a mystery but certainly considerably slower than the XT2 generation and perhaps even the generation before that.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
Sal Baker Forum Pro • Posts: 11,553
Threaded wrote:
57even wrote:
D Longhi wrote:
Hello,
Whatever the X-T100 has under the hood it's slightly faster than my X-E2.  IQ is several leaps ahead of the old X-Trans IMO.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Fujifilm X-E2 Fujifilm X-T100 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Set it to high-performance mode and just toss another battery in your pocket.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Thank you all for your response!
All in all, I gather I'll have a beautiful little machine on hand, not the fastest, but more than enough for my uses.
And, to stay on topic, even if it is slightly slower than my trusty D5300, I think I'll have an all-around update on my photography experience.
Make sure you have the latest FW.  You will love your xt100 more with time.
I am yet to have the camera with me. How does the FW download works?
Just google “download fujifilm x-t100 firmware” and go from there. Super easy
Rmcp20 wrote:
57even wrote:
D Longhi wrote:
Hello,
True, but is has on-sensor PDAF points, so it is a lot better than an XE2 at capturing single frames of moving subjects.
57even wrote:
Rmcp20 wrote:
57even wrote:
D Longhi wrote:
Hello,
Without getting into the whole is-it-better-or-not-than-an-XE2 argument, the XE2 also has on-sensor PDAF points.
As mentioned previously neither the sensor or processor in the XT100 are directly comparable with any previous X-Trans camera, for better or worse.
