Help: T7i won't take Bracketed Pics only a single pic
Started May 13, 2019 | Discussions
GNATIONAL Regular Member • Posts: 272
I was on vacation and for the life of me I could not get my new T7i to take bracketed photos and instead it would only take a single photo instead of the three different exposures so I need some help to figure out why. I used to use it on my T1i no problem but this T7i is being a PITA.
Camera settings:
AV mode (also tried Manual Mode)
Single Shot (also tried continuous shooting)
Set the bracketed settings in the Menu and the +/- values indicate that they are saved in the viewfinder but it still only takes a single pic instead of three.
Thoughts?
Kevin
Update: NEVER MIND.. I just discovered that I didn't have it set in the correct "Continuous" mode. It now works in slow speed continuous (I thought I tried this setting but apparently not) instead of hi speed continuous.
Too bad the manual doesn't outline this info I could have taken the desired photos.
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3) Canon EOS Rebel T7i / EOS 800D / Kiss X9i
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Help: T7i won't take Bracketed Pics only a single pic
GNATIONAL wrote:
... Update: NEVER MIND.. I just discovered that I didn't have it set in the correct "Continuous" mode. It now works in slow speed continuous (I thought I tried this setting but apparently not) instead of hi speed continuous.
? p. 198
Single press (and hold down) of the shutter button works with drive set to either high or low continuous.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
