How many megapixels do you want in an M?
Started May 11, 2019 | Polls
HaroldC3
HaroldC3 Veteran Member • Posts: 3,067
Canon may have a 28MP or a 32MP APS-C sensor coming so let's pose the question.  If everything else was constant (DR, ISO performance, detail, etc) how many megapixels do you want in an M camera?
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M6 Nikon Z7 Canon EF-M 22mm f/2 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Nikon Z 14-30mm F4 +3 more
POLL
Greater than 32 megapixels
13.4% 16  votes
32 megapixels
28.6% 34  votes
28 megapixels
8.4% 10  votes
24 megapixels
45.4% 54  votes
Less than 24 megapixels
4.2% 5  votes
  Show results
Raanani Regular Member • Posts: 225
Re: How many megapixels do you want in an M?
24 is enough. Larger pixel count I'd prefer in a heavier body to balance heavier glass.
 Raanani's gear list:Raanani's gear list
Sigma DP1 Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS M6
Asla
Asla Senior Member • Posts: 1,100
Hi!
18 or 24.
A s l a
MyM6II Senior Member • Posts: 2,424
24 is enough. (18 would be nice, too. Because of larger pixels.)
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
thunder storm Forum Pro • Posts: 10,139
I think i have some lenses being able to handle 32Mp. I might need shorter shutterspeeds with 32Mp, so IBIS will be even more important with such a high pixel density.
If your facts are different we could save the peace just by calling it copy to copy variation.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
paleodawg
paleodawg Regular Member • Posts: 150
Plebs want low pixel count and large pixels.
The patrician choice is Canon's 120mp sensor.
Microprism Contributing Member • Posts: 865
24 is fine. I would prefer improvements in the other areas rather than more megapixels.
 Microprism's gear list:Microprism's gear list
Canon EOS 5D Canon EOS 7D Canon EOS M6 Canon EOS M6 II Canon EF 50mm F1.4 USM +22 more
(unknown member) Contributing Member • Posts: 975
They should use a 40 or 48 megapixel sensor with optional pixel binning for 10 or 12 megapixel photos. It shouldn't be a Quad Bayer sensor as this could lead to demosaicing issues like Fuji's X-Trans sensor. And they need to offer a dng/CR3 file with consistent multi frame noise reduction. Of course they need to release sharp lenses.
Why 24 megapixels is not enough:
-In a few years smartphones will give you high quality photos/dng files with a (much) higher resolution than 12 megapixels.
-a high resolution is useful for tele, macro and landscape photography
-a high resolution + crop lets you use a wide angle lens as a normal lens (so it's like having more lenses), so for example the Ef-m 32mm f/1.4 could be "transformed" into a lens that is equivalent to an Ef-m 64mm f/2.8 macro lens (though it would be noisier than a real 64mm f/2.8 lens at base Iso).
Lemming51
Lemming51 Forum Pro • Posts: 15,277
How many ya' got?
If everything else is constant, why just 32mp?  Why not 60mp or 600mp?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
whakapu Senior Member • Posts: 1,051
If detail is constant there's no point in a higher pixel count. If 6mp captured the same detail as 32 then we could go back to 4gb memory cards. The whole idea of more pixels is to add detail, as much as possible without sacrificing too much of those other factors.
Nigge Regular Member • Posts: 223
That would be ideal but nobody seems to know how to make a sensor that allows binning.
 Nigge's gear list:Nigge's gear list
Canon EOS 5D Mark II Canon EOS 80D Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM Canon EF 70-200mm F2.8L IS II USM +6 more
akustykmagmanetpl Senior Member • Posts: 1,361
I'm perfectly OK with the 24MP on the M5. it's the functional (photographic) side where this body is "underdeveloped" (or to put it bluntly: made for Powershot folks, not DSLR users) not the sensor. sensor is better than 90% of its users, especially those fighting reality with their DXO charts or whatever :-}
 akustykmagmanetpl's gear list:akustykmagmanetpl's gear list
Canon EOS 10D Canon EOS 80D Canon 6D Mark II Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM +9 more
ByronP Contributing Member • Posts: 878
I much prefer much better low noise at much higher iso and secondarily much better tracking for such things as birds in flight.
Maybe I have to switch to a Sony A9 and get use to its terrible human interface.  If I want tracking and mirrorless the A9 is really the only game in town.
Bp
 ByronP's gear list:ByronP's gear list
Canon EOS 7D Mark II Canon EOS 80D Canon EOS M5 Sony a7 III Sony a9 II
paleodawg
The shallow mindedness in this thread...
Why not a 120mp or 400mp sensor?
Think DR will suck? There is a workaround: smartphones allow 4 sensor sites to work together as a single pixel to improve DR. In effect a 48mp sensor can also work as a 12mp camera with larger pixels.
Such a sensor is flexible in that it has more mp with more light.
Oldwino Regular Member • Posts: 415
5
I think 24-28 is just fine. Denser sensors just produce larger files. without a huge gain anywhere else.
I would love to see the option of using DNG for raw files.
 Oldwino's gear list:Oldwino's gear list
Nikon Coolpix P7800 Ricoh GR III Fujifilm X100V Ricoh GR IIIx Nikon Df +29 more
Bp
But then are you sure you're looking in the right place (Canon M and EFM lenses for the features of birding system)???
Re: How many ya' got?
Because there are other factors which can't keep up with 60Mp.
- aperture large enough to avoid diffraction
- AF precise enough for the amount of detail AND the thin DOF of the large aperture needed to avoid diffraction
- signal2noise ratio needed for higher ISO's needed for higher shutter speeds needed to keep up with the high pixel density.
The ef-m 32mm f/1.4 would benefit from 32Mp compared to 24Mp. It might be the only ef-m lens, maybe the 22mm and 28mm would benefit a little.
600Mp is useless for sure.
paleodawg
OzarkAggie Senior Member • Posts: 2,153
I'm already contemplating a new build for my desktop.  That can be a real issue depending on the processing you do.  So I'll probably stick with 24 MP for the foreseeable future - even if I upgrade my computer.
24 MP actually offers more than I can print - 12x18 @ 300 ppi.  This is also part of my consideration because I print a lot.
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
Bobolinkage
Bobolinkage Forum Member • Posts: 68
One scenario for having a big benefit for higher megapixels is wildlife photographers who crop frequently. I would want as many megapixels as possible without compromising noise too much.
 Bobolinkage's gear list:Bobolinkage's gear list
Canon EOS 600D Canon EOS M6 II Canon EF-S 18-55mm f/3.5-5.6 IS II Sigma 18-300 F3.5-6.3 DC Macro OS | C Sigma 150-600mm F5-6.3 | C +1 more
