Two important camera features Canon PowerShot Talk
Started May 7, 2019 | Discussions
oseo84 New Member • Posts: 3
1-The DIGIC 5 processor has plenty of juice remaining to power Canon’s new Multi-Area White Balance system. Instead of reading the average light on an image, this system reviews more than one segment of an image and modifies the white balance for each separately.
2-The sensor and processor in the Canon PowerShot SX40 HS also puts wow in your moviemaking. You have the choice of 1080p Full-HD video with stereo sound at 24fps or 720p HD video at 30fp
CMCM Veteran Member • Posts: 5,995
Re: Two important camera features Canon PowerShot Talk
I've really wondered what the difference might be between Digic 5, 6, 7 and 8.  I've had the impression that Digic 8 is needed for 4K video, but to tell the truth, I haven't come across a discussion of the various Digic versions and what they do.
 CMCM's gear list:CMCM's gear list
Fujifilm X30 Nikon D500 Canon G7 X II Nikon Coolpix P950 Nikon D700 +17 more
RLight Senior Member • Posts: 4,428
https://snapshot.canon-asia.com/article/en/5-things-made-possible-with-digic-image-processor
Smarter cameras are better cameras...
AWB (How smart... Accurate, it makes a determination. Also, newer DIGIC7 and all DIGIC8's support the newer AWB-W btw)
FPS (the ability to digest what the camera can drive anyways)
AF (speed and accuracy)
Eye AF
Low Light AF (part of it, the other half being the sensor / how much light the lens mounted is drawing in)
Noise reduction improvements (DIGIC6 was "the big one". Moving to DIGIC6 or newer from anything before it, is a huge difference in SOOC JPEG noise)
Metering (the newer DIGIC8 is a lot better here, and it was already good before DIGIC8)
4K (yup)
In-camera corrections, including your SOOC JPEGs, not just in-camera RAW
Picture profiles including improved sharpness algorithms
JPEG color response (they tweak things from time to time which gets bundled with the DIGIC processor software at the time the camera ships)
Automatic detection of scene type (if using Auto)
Dual IS which is merely the sensor now acts as a datapooint for the gyro sensors in-lens giving IS systems better accuracy. Think small, but added benefit to IS
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
DonA2
DonA2 Veteran Member • Posts: 3,720
A very good analysis of the Digic engine improvements. Software is the main item in upgrades. The hardware is getting bigger and in some cases that improves usability in others it's simply a detriment. Overall, improvements in IQ comes via software. And that comes very slowly indeed.
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +2 more
sueanne
sueanne Forum Pro • Posts: 21,078
Nice   I m going to NY to check out the B@H store with Daves overhold truck "Z_
 sueanne's gear list:sueanne's gear list
Canon PowerShot A510 Canon PowerShot A650 IS Canon PowerShot SD880 IS Canon PowerShot S3 IS Canon PowerShot S110 +3 more
Thanks for the detailed response! Very useful.
I had wondered about the differences between the G7Xii and G5x.  They appear to have the same lens and many other similar features  (ignoring the viewfinder difference for the moment), but the G5X has an older Digic version than the G7Xii, and perhaps the Digic 7 in the G7Xii explains some of the improved functions in it compared to the G5X.
As such the G7X II is superior, except for lacking an EVF vs a G5X, yes.
GeraldW Veteran Member • Posts: 8,872
If you go to the DPReview comparator and compare the G7X II against the G7X and G5X, you'll see a big difference in contrast and the resolution of fine detail.  On either side of center in the comparator there are a pair of black and white cards with black and white dots of all sizes.  Click on one of those and you'll see a huge difference in favor of the G7X II.  The Canon engineers stated in an interview that DIGIC 7 has 14 times the processing power of DIGIC 6.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
That's nice to know....I'd been wondering what kind of difference the DIGIC 7 made.
