Multiple photo programs - explain sidecars?
Started 8 months ago | Discussions
Bbawt1 Forum Member • Posts: 63
Think this is a pretty basic question, but I couldn't find the answer anywhere.
I currently use LR CC and want to try out a few other programs. I'm used to the catalog function for storing edits in LR so not too familiar how sidecars work.
Some of the programs I want to test use sidecar xmp files.  What happens when Program A writes the sidecar and then Program B opens the raw file and also writes a sidecar - does it overwrite the existing file? Does a second sidecar get written? I don't want to lose edits from one program by using another program.
Thanks.
 Bbawt1's gear list:Bbawt1's gear list
Fujifilm X-T20
Dan Marchant Veteran Member • Posts: 3,228
Re: Multiple photo programs - explain sidecars?
I don't know. Also different packages may be different so one might overwrite while the other uses a different naming structure.
Why don't you do a test and report back?
Dan
f/2.8 is a smaller number than f/22 in the same way that 100 is a smaller number than 20.
Street Photography danmarchant.com street photography
Street Photos Flickr street album
Instagram (mostly street stuff) dan_marchant
Instagram (sports stuff) sporting852
 Dan Marchant's gear list:Dan Marchant's gear list
Canon EOS 5D Mark III Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +1 more
Digital Nigel Veteran Member • Posts: 9,854
They use different file extensions, so program A's sidecars are stored separately from program B's. They won't overwrite each other, but normally, one program can't read another's sidecars, so you can't transfer edits from one to another.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +18 more
myotisone Senior Member • Posts: 1,970
"XMP" side car files work across programs to share metadata.
Some programs, but possibly only Lightroom writes some processing data to XMP sidecars, which should be LR specific and ignored by other programs.  Unless the other program specifically says that it shares LR processing data.
Other programs such as DXO store processing data in sidecar files, but these are *.dop files not XMP sidecar files. Capture One (C1) stores processing data in *.cop sidecar files.  And these files are only used by DXO and C1 respectively.
However, C1 (and probably DXO) also write "metadata" changes to XMP sidecar files, allowing these changes to be shared across programs.
C1 does not write any processing data to the XMP sidecar files. Nor do they read any of the processing data that LR writes to XMP side car files.  Except, when importing LR catalogues into a C1 catalogue when they try and read the LR processing data as a one one off during import to try and match edits between the two programs.
So, this shouldn't be an issue, but I would still check and see exactly how the programs you are referring to work.
Graham
MisterBG Veteran Member • Posts: 6,863
I think it's true to say that .xmp sidecars contain things like keywords and star ratings that can be read by any program that understands the .xmp protocols.
Other sidecars (.cop, .dop) contain information (usually develop settings) that are known only to the program that wrote them. On1 PhotoRAW also generates it's own (.on1) sidecars containing it's own information.
 MisterBG's gear list:MisterBG's gear list
Sony RX100 Sony a6000 Olympus PEN-F Canon EOS 80D Canon EOS 5D Mark IV +14 more
Pieloe
Pieloe Forum Member • Posts: 72
YES some programs share keywords, GPS tagging and star ratings with .xmp sidecars. Others informations in these xmp files are exclusive to Lr.
Pascal
OP Bbawt1 Forum Member • Posts: 63
Thanks everyone for your help. Darktable and LR can both write .xmp but each writes their own - so I have 2 .xmp files alongside the .raf raws. Each has their own naming protocol so easy to tell which belongs to which program.  DNGs (which I get using X-Transformer) have the data baked in so no sidecars.  DT, RawTherapp and LR all kept their own develop info straight.  The other commercial software must too.
Fujifilm X-T20
