New Birding Lens Feels Great
Started May 3, 2019 | Discussions
Po Sen Tsui Regular Member • Posts: 289
17
Just got my Panasonic 100-300 Mk II, tested it with my EM-1 Mk II in a local park. The OIS is so useful on this lens and the results are great.
hmmmmm........what is this guy up to
Day 285 undercover, these stupid flamingos still hasn't notice me yet
 Po Sen Tsui's gear list:Po Sen Tsui's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-100mm F4.0 Venus Laowa 7.5mm F2 MFT Olympus 100-400mm F5.0-6.3 IS
Dave Andrade Contributing Member • Posts: 587
Re: New Birding Lens Feels Great
I was already "sold" on this lens, but you've sold me even more. Thank you
 Dave Andrade's gear list:Dave Andrade's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 85mm F1.8
HRC2016 Veteran Member • Posts: 6,874
The Best Birding Lens (and Oly 75-300)
Great pictures with great equipment.
I think this and the Oly 75-300 are the best birdinh lenses out there. Longer focal length can help but if you've got the skills you don't need to carry more gear!
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
OP Po Sen Tsui Regular Member • Posts: 289
Re: The Best Birding Lens (and Oly 75-300)
I actually owned a 75-300 II before, optically it is a good lens and quite sharp. However, my problem with it is that with 600mm FF focal length but no lens stabilization, it is hard to use (I was using an EM10 Mk II body back then, the IBIS is good but 600mm is just too much for it). So I did end up selling it. The Panasonic 100-300 II on the other hand solve this problem with OIS and it is a little bit faster too, the only down side is I can't use the ProCapture mode with it because it is not an Oly lens.
The PanaLeica 100-400 is suppose to be much better than these two, however, it is much more expensive and I don't want to hike with that thing (1kg). So yeah, I agree with you that the Oly 75-300 and Panasonic 100-300 are actually great birding lens given their relatively low price, light weight and high quality.
Seth B Contributing Member • Posts: 538
Pro Capture High on the Em1mkii (with the latest 2.3 firmware) works with the Pana Leica 50-200mm. I am currently testing this combo.  In theory the Em1mkii should work with the 100-300. BTW, only ProCapture H works the Pana lens, not PC-L.  I am not sure which Olympus body you are referring to in your statement.  HTH
Seth
'Momma don't take my Kodachrome away'
 Seth B's gear list:Seth B's gear list
Panasonic Lumix DMC-GM1 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +4 more
katastrofa Senior Member • Posts: 1,034
I did hike with the PL100-400. It's OK. I wouldn't want to hike with the Olympus 300mm F/4 though, too large and a bit too heavy for that.
 katastrofa's gear list:katastrofa's gear list
PowerShot SX700 Olympus E-M1 II OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +4 more
Oh, thanks for the info, maybe I should try to use the ProCapture Mode with P 100300 II to see if it works. I was referring to the EM1 Mk II body. Thanks!
It is actually quite light compare to FF 800mm lens, but maybe I am just lazy LOL
PL100-400 is compact enough that I don't have to worry about hitting it against a tree or a rock. Bigger lenses, bigger problems.
