X-E3 as a backup for an X-Pro2?
Started May 2, 2019 | Discussions
HeavyDuty Veteran Member • Posts: 3,035
I'm currently using an X-M1 as a backup body for my XP2.  I’m thinking it’s time to move up to an X-E3 for that purpose, and also as a secondary body in general.
I’m finding that my aging eyes are starting to prefer an EVF over an OVF, and even the XP2 is getting used in EVF mode more and more.  An X-E3 seems to make logical sense - the control set is very similar to my XP2.  And, it would be a good host for my 14 when I’m shooting using two bodies.
I’ll be using it with my Fuji primes, I doubt I’ll ever adapt anything else to it and I don’t own any Fuji zooms.  My Fuji kit is what I carry when I’m going light.
Is there any reason I wouldn’t want to pick up an X-E3 at this point?
Ken in Illinois
Railroad Action: http://www.pbase.com/kjford
Candids: http://www.pbase.com/kjford/other
 HeavyDuty's gear list:HeavyDuty's gear list
Nikon Z9 Nikon Z 24-70mm F2.8 Nikon Z 70-200 F2.8 VR Nikon Z 14-24mm F2.8 Nikon Z 50mm F1.2 +15 more
Fujifilm X-E3 Fujifilm X-M1 Fujifilm X-Pro2
OP HeavyDuty Veteran Member • Posts: 3,035
Re: X-E3 as a backup for an X-Pro2?
I should mention that I prefer the rangefinderesque form factor of the X-Pro2, so I’m not considering the X-T series cameras.
Ken in Illinois
Len-O Senior Member • Posts: 1,637
My backup body for my X-T3, and X-T2 before that is an X-E3. It is a great camera which is a perfect lightweight travel option. I prefer the RF type body, otherwise I would recommend going with the X-T30.
Schiphol late at night
...and it works well as a second body as a WA prime mount at events such as airshows.
A different take on an A-10
 Len-O's gear list:Len-O's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +8 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Based on your eyes, go for an X-T2 or X-H1.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
(unknown member) Forum Pro • Posts: 16,732
Still using a XE2 as my backup to an Xpro2. I think the XE3 would be even better.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
BrianOdell Forum Member • Posts: 96
Own an XT3 and I’m wanting a smaller 2nd body. I’m torn between the XT30 (newer tech) or the XE3...
Thanks, but see my second post...
Ken in Illinois
I tried to look at one today after work, but the store only had a sealed one and none on display.  I’m only tire kicking right now, so I didn’t press the issue.  I’ll keep looking for one to  check out.
Ken in Illinois
I do to, but if your eyesight is starting to be a challenge you might just want the big beautiful EVFs in X-T2 or X-H1.
jhorse Veteran Member • Posts: 5,913
5
Hi, if this helps, I have a XE3 and it delivers great images with the primes, is fast and easy to use (once set up and once familiar - like any camera), and is light, small and unobtrusive. I tend to use it with either a 23/f2 (when I carry my trio of the 16/f2.8 and 50/f2), or as a single unit with the 27/f2.8.
The XE3 was intended to back up my XT3, but it gets equal use to the latter as it is such fun to use.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
a_c_skinner Forum Pro • Posts: 13,047
The X-E3 is a good addition to a bigger camera.  I use mine not as backup (though it is), but when I want a smaller, lighter body.  The EVF is an improvement in bright light and as presbyopia sets in I use it to review shots as it has my prescription is dialled in but the rear LCD needs reading glasses.  I went from X-E2 to X-E3 mainly to avoid doubts about taking a 24 Mp or a 16 Mp camera.  In point of fact it isn't easy to see a difference in output, I did some careful comparisons before trading.  USB charging is good as my brain is heading the same way as my eyes and forgetting the charger is all too common.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
I’ll try to do a direct comparison between an X-T2 and a X-E3 EVF.  Thanks!
Ken in Illinois
MrALLCAPS
MrALLCAPS Senior Member • Posts: 2,089
The X-E3 is my backup to my Nikon Z6.
-Even though I use my X-E3 much more than the Z6.
So maybe the Z6 is the backup to my X-E3.
Three cameras I had pure joy shooting:
GF2, GX7 and the X-E2. Getting the X-E3 was an easy choice. I still look at the GX7 MkIII every time I'm in Adorama or B&H... I tend to take better and more pics with a camera I feel comfortable with.
 MrALLCAPS's gear list:MrALLCAPS's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-E3 Fujifilm X-H1 Nikon Z6
KFo
KFo Contributing Member • Posts: 534
I think the XE series are fantastic!  My first Fuji was the X-E1 and I shot the heck out of it for years.  Today I’m shooting the X100F and XPRO2 having sold my X-E3.
The XEs are very compact which makes them a primo choice as a 2nd body.  I found the controls differences between the XE3 and X100F (strange as it may seem my primary Fuji body) to be distracting enough that I swapped to the XPRO2.  You might want to look at how you’ve setup your XPRO to  make sure that you can either replicate the controls on the XE or that the differences between the two are immaterial to your style.
Unconcerned but not indifferent.
Sharpness is a bourgeoisie concept.
Opted into the Fuji X system big time. Like to travel light and shot quick; that's why I also have a Ricoh GR....
INSTAGRAM https://www.instagram.com/streeteatsyou/
BLOG http://streeteatsyou.com/category/photography/
 KFo's gear list:KFo's gear list
Ricoh GR II Fujifilm X100F Leica M10-P Leica Summicron-M 28mm f/2 ASPH Leica Elmarit-M 28mm f/2.8 ASPH +5 more
Remcodb
Remcodb Regular Member • Posts: 133
I bought the XE3 a couple of weeks ago as a 2nd body to my XT3, and I love it! I give it a lot of time lately to get used to. I like it when the camera body becomes an extension of yourself. I may well end up using this as much as the XT3 because of the size and form factor.
PROs: Smaller size, nice RF form-factor (am now getting used to right-eye framing), beautiful lines, very similar to XT3 controls.
NEGs for me: EVF of XT3 is noticeably better, no flip screen, no ISO dial (but I have a work around for that by putting that on the front dial).
When I bought it I immediately set it up the same as my XT3 in terms of customisations. I use it with the 35 f/2 or 23 f/2 mainly, which are beautifully small and powerful combos. Should work fine with the other primes too.
My idea for a 2-body outing would be the standard/tele on the XE3, taking shots from eye level, and the wide angle on the XT3, taking low angle with the flip screen.
XE3 with 35 f/2
www.remcodenboer.com
Best regards,
Remco
 Remcodb's gear list:Remcodb's gear list
Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +6 more
markusw Senior Member • Posts: 1,705
For me, I would get another XP2 as backup. Same usability, same settings, same feel. So, it would make no difference at all if I am going with the backup body or the main body, I can use them in parallel without spending a single thought which camera is in my hands.
winc06 New Member • Posts: 13
I was willing to put up with the significantly smaller image and was interested in that camera too, but I have seen comments by two trusted reviewers that there is very long lag, maybe a second or two, for the evf to turn on with the X-E3 and one comment that the proximity sensor switch just does not work very well if you wear glasses. I could not put up with that.
jslade797 Regular Member • Posts: 326
Glasses-wearing X-E3 owner here - happy to confirm that I have not experienced either of those issues. EVF startup very snappy on mine - maybe it was fixed by firmware?
Instagram - @jontyslade
 jslade797's gear list:jslade797's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R
Hi, nor me, never experienced any lag, including on a beach walk this afternoon.
If you leave it on and it gees to sleep, then like all Fuji-s, my XT3 included, there is a second from half pressing the shutter button until everything is ready. But, as I say, this happens on the XT3 too. I just press the shutter button as I lift the camera to my eye and the EVF is on and ready to goes by the time my eye is looking through it.
unclebrudy
unclebrudy Contributing Member • Posts: 576
This is the big one for me and I’m inclined to agree. Everyone has different dexterity and muscle memory, but I went double X-T3 because originally using an X-T3 in tandem with an X-T2 was an exercise in frustration. They are *just* different enough that it slowed me down immensely.
Fuji X. Formerly just a Maxxum, an Alpha, and crossed fingers.
 unclebrudy's gear list:unclebrudy's gear list
Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-T3 GoPro Hero6 Black Fujifilm XF 18mm F2 R +6 more
