Great range, cheap build
Started May 2, 2019 | User reviews
NorCalAl
NorCalAl Forum Member • Posts: 78
The Mad Prophet - philosopher, cyclist, and photographer
 NorCalAl's gear list:NorCalAl's gear list
Nikon Coolpix 8700 Nikon D40 Nikon D5300 Nikon D500 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II +8 more
Canon EF-S 17-55mm f/2.8 IS USM
Zoom lens • Canon EF-S • 1242B002
Announced: Feb 21, 2006
NorCalAl's score
3.0
Average community score
3.6
mkphoto79 Regular Member • Posts: 450
Re: Great range, cheap build
Outstanding review
-Mike
 mkphoto79's gear list:mkphoto79's gear list
Canon PowerShot A590 IS Canon EOS 1200D Canon EF 300mm f/4.0L IS USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +5 more
jvc1 Senior Member • Posts: 2,202
According to your gear list, you no longer own a Canon body. What did you put this lens on to do such an extensive review?
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
BlueRay2 Forum Pro • Posts: 14,816
i agree, horrible construction and average IQ. it is built like a dust vacuum and the body joints are cheaply put together. to its credit, it has a very usable range FL for daily and casual use, too bad it won't fit on a FF camera.
if everything seems under control, you're not going fast enough! "Mario Andretti"
ed rader Veteran Member • Posts: 9,068
when the 17-55 was released it produced IQ better than any medium range zoom made by or for Canon FF
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
jp4 Senior Member • Posts: 1,202
Mine was a dog, sold it.
 jp4's gear list:jp4's gear list
Canon PowerShot G5 X Canon EOS 80D Tokina AT-X Pro 11-16mm f/2.8 DX II Canon EF 100-400mm F4.5-5.6L IS II Canon EF-S 18-135mm F3.5-5.6 IS USM
could have been a bad copy or a number of other things.  I know mine was very sharp even wide open, sharper in fact than the 24-70L I (brick) wide open.
"Prior to receiving my 17-55 IS, I stated that I expected its image quality to match or nearly match that of Canon's L Series Lenses as it shares the L-Series UD lens elements. As it turns out, my 17-55 matches or exceeds the optical performance of my L-Series zooms in this similar focal length range ...
This lens is sharp! Wide open and from edge to edge. Unless the distance is close that is - I'm finding that close subjects do not produce the same image sharpness as normal distance subjects. The ISO 12233 chart test results indicate this as well. The 17-55 IS shows slight sharpness improvement at f/4, but performance at f/2.8 is very good."
https://www.the-digital-picture.com/Reviews/Canon-EF-S-17-55mm-f-2.8-IS-USM-Lens-Review.aspx
i have never owned an EF-S lens but i did use a friend's 17-55 for a few days, i didn't see anything extraordinary about it except on par with non-"L" EF lens! if i had a choice between 24-105 and 17-55, the choice is clear, i'd go for 24-105, no question there. but we all have different experience with this lens. one thing is for sure, this lens has a terrible construction, the joints' gap is visible, hence the dust issue! but for someone who has tight budget for getting "L" lenses, this is an excellent choice!
Dale Garman Senior Member • Posts: 1,025
I used this lens for some time with a 7D and a 7D MKII.  I came from a 17-40 and found the image quality a significant improvement, but agree that the build quality is lousy.  It has interior dust that drives you nuts although doesn't seem to affect pictures.  It also has zoom creep which was very distracting when doing events.  So I don't use this lens anymore, but the IQ was good even though the build quality was not.  I always thought the price would justify a much better build quality.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
my 5d (original) had to be sent to canon because the mirror fell off. I had a friend's wedding I said I would shoot. I needed a fast medium range zoom for my back-up camera -- canon 20d. I bought a used 17-55 (and sold it afterwards). I've owned the 24-105L at least a half dozen times over the years and was an early adopter when it was first released. as a landscape shooter the distortion at 24mm makes the lens highly undesirable to me, as well as the mediocre performance throughout the range and softness at 105.
bottom line is at the time the 17-55 was the only lens that would work for me.
at the time the 17-55 was revolutionary.  the only medium range zoom that offered f2.8 was from sigma -- the 18-50 I believe -- and it could not focus.  so canon could get away with the price back then.
