Is this level of noise normal for a7iii at iso 2000?
Started Apr 29, 2019 | Questions
andrei_says Junior Member • Posts: 29
Shot with a7iii and Sony 35mm 1.4 at f1.6, 1/100sec, iso2000, on Manual setting, in RAW.
I recently moved from Canon to Sony for size, weight, low light performance and autofocus.
However, I am seeing a lot of black grain at even iso 2000 -- is this normal for this camera? The photos in this forum definitely look cleaner than mine -- is noise reduction required in post?
Images: https://imgur.com/a/I1Hdbie
Images have been pushed 1 stop and curve adjusted in Lightroom.
I did look at the DPreview test image and do not see suchlevel of grain even at 3200.
https://www.dpreview.com/reviews/sony-a7-iii-review/5
I am concerned because my 5d3, an older generation camera, seems to produce lower level (black) noise in similar conditions. It does produce noise, but not so contrast-y.
So after reading about the great low light perfromance of the a7iii, I am wondering if there's something wrong with my a7iii body.
GrapeJam
GrapeJam Senior Member • Posts: 3,555
Re: Is this level of noise normal for a7iii at iso 2000?
10
The adjustment that you make to the photo actually makes it closer to ISO 8000.
 GrapeJam's gear list:GrapeJam's gear list
Canon EOS R Canon EF 24-70mm F2.8L II USM Canon EF 85mm F1.2L II USM Canon EF 50mm f/1.2L USM
audiosupernova Junior Member • Posts: 38
5
Wanted to chime in to agree. You boosted exposure a full stop, doubling noise to equivalent ISO 4000. You boosted shadows a full stop, doubling shadow noise to equivalent ISO 8000. You also raised the black level....boosting equivalent noise even further.
 audiosupernova's gear list:audiosupernova's gear list
Sony a7 III Sony FE 85mm F1.8 Sony FE 55mm F1.8 Tamron 28-200mm F2.8-5.6
Magnar W
Magnar W Veteran Member • Posts: 5,461
8
ISO is all about exposure, not the ISO setting.
Try do do such pushing with a Canon file!
You are fooling yourself here.
Classic: User error.
 Magnar W's gear list:Magnar W's gear list
Sony a7R III Sony a7 Zeiss Loxia 21mm F2.8 Zeiss Loxia 35 Zeiss Loxia 85mm F2.4 +2 more
OP andrei_says Junior Member • Posts: 29
9
Way to go dismissing my experience of shooting for 4+ years with the 5d3. Your reply is not constructive and is disrespectful. I see you have thousands of posts here, hopefully you're not a representative of this community which I usually find accepting and helpful.
"The person who is brutally honest enjoys the brutality quite as much as the honesty. Possibly more." -- Richard J. Needham
Magnar W
If you expect a correct exposed file at a given ISO value to show the same noise level as an underexposed and pushed file, what should one then say?
Thank you, this makes sense. So I should expect this level of noise to be normal when I push 1-2 stops?
The chroma noise is comparable to the Canon, but the black noise is something I have not experienced with another camera.
Looking at the DPReview image quality scene, I do not see the black noise present even at ISO 12800.
I often need to crop my images and so the noise becomes more prominent. It is more noticeable than what I've experienced with my older generation DSLRs.
12
Thank you for asking!
How about:
"It is possible that pushing the file 1 stop brought up this unusually high level of noise. Are you certain you use the same process with your 5d3? I'd imagine you'd get worse results with the canon, as the Sony has a newer sensor. Would you provide some tests?"
To which I would reply:
This is my usual process, I push the Canon RAWs 1.5-2 stops all the time and do not experience such (black) noise. Some chroma noise but much lower contrast. But you're right I should do a test.
Can we agree that this exchange is a bit more constructive than a witty backhanded insult attempt like "user error"? It may make one feel superior for 5 seconds but does not contribute.
bob13bob Contributing Member • Posts: 954
yes, normal. when using the comparison tool, u need to look at the shadows of hte picture when comparing higher iso shooting.
use the tool with the lights off looking at the shadows.
https://www.dpreview.com/reviews/image-comparison?attr18=lowlight&attr13_0=oly_em10iii&attr13_1=sony_a7iii&attr13_2=canon_eos5dmkiii&attr13_3=sony_a7riii&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=1600&attr16_1=1600&attr16_2=1600&attr16_3=1600&attr171_1=1&normalization=full&widget=1&x=-0.8364947089947089&y=-0.1646839052207256
the a73 is better than 5dm3 to my eyes in the above link, but not by much.
try capture one, i think it has better processing than lightroom for sony cameras.
also, be weary of iso cheating or iso arbitrarily set.  To really do a comparison, shoot the same fstop and shutter speed.  a73 is very good at not iso hacking.  it's a 1/3 stop better than a7r3.
my equipment: a7iii. NATIVE: sony 50 1.8. samyang 35 2.8. ADAPTED: sigma mc11 adapter. canon 85mm 1.8. sigma (canon) 12-24 4-5.6. canon 70-300mm f/4-5.6 is ii.
dkeller Senior Member • Posts: 1,550
Could you have even pushed the dark areas that far and gotten an image with your other cameras?
 dkeller's gear list:dkeller's gear list
Sony SLT-A68 Sony a7 II Sony FE 28-70mm F3.5-5.6 OSS Tamron 18-270mm F/3.5-6.3 Di II VC PZD Sony FE 24-105mm F4 +4 more
11
I saw nothing insulting about his remarks.  They were just to the point on each area.
1 stop exposure and a bit in the shadows? Absolutely. I often push Canon RAWs 2+ stops.
Got the Sony because 5d3 has a hard time focusing on moving objects in low light and I shoot wide open so I need the AF advantage.
I will however make a comparison with identical iso aperture and shutter speed.
I think I found the culprit!
Lightroom seems to apply sharpening to all images upon import. Removing that reduced the amount of the black noise. (And of course made the image less sharp).
https://imgur.com/a/fWWgVks
What do people use for sharpening with this camera?
jptsr1
jptsr1 Regular Member • Posts: 194
Not dismissing your experience but I owned a 5D3 for many years and when I pushed files 2 stops what I would end up with was garbage most of the time. I still love my Canons and often still shoot with my 6D2 that I still own but neither it or my 5D3 allowed the latitude that my A7III does. I think something else has to be at play here.
"Yes yes yes, but I shoot Canon so it is what it is." -Me
 jptsr1's gear list:jptsr1's gear list
Canon PowerShot S100 Canon EOS 5D Mark II Canon EOS 50D Canon EOS M Canon EOS M3 +20 more
GrapeJam
Dunno, I actually disable sharpening most of the times, I feel the image looks more organic with sharpening disabled.
I will do a test with both cameras to verify behavior in similar conditions. I’m also curious about it.
Lightshow
Lightshow Veteran Member • Posts: 7,439
Since you do a lot of shadow lifting, try this, use the histogram and expose to the right side of the histogram, this will or can reduce the amount of noise.
https://www.cambridgeincolour.com/tutorials/digital-exposure-techniques.htm
https://en.wikipedia.org/wiki/Exposing_to_the_right
https://www.dpreview.com/articles/6641165460/ettr-exposed
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
https://c1.staticflickr.com/1/447/31518420576_7916966b11_b.jpg
https://c2.staticflickr.com/2/1962/31024497798_85526ac8ca_b.jpg
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram https://c1.staticflickr.com/1/602/20236258313_c604dd9522_n.jpg
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Voigtlander 15mm F4.5 Super Wide Heliar Leica APO-Summicron-M 90mm f/2 ASPH Leica Elmarit-M 24mm f/2.8 ASPH +20 more
the better twin
the better twin Regular Member • Posts: 129
Make sure to use masking so you dont sharpen shadows. Hold down alt when moving the masking slider to see what you are sharpening.
@andrew.morgans
 the better twin's gear list:the better twin's gear list
Sony a6300 Sony a7 III Sony E 35mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Samyang 12mm F2.0 NCS CS +3 more
splashy
splashy Veteran Member • Posts: 3,554
When they say 'ISO is all about exposure, not the ISO setting.' try to understand WHAT it means.
You cannot make noisefree pictures in/of unlit objects by raising the ISO high, this whole high ISO seems to be a misunderstanding by camera users.
But you could have posted the original, so we could see why it went wrong.
I adjusted the Sspeed and shadows to original, actually the camera did a very good job.
I did denoise it.
 splashy's gear list:splashy's gear list
Sony a7R III Sony FE 55mm F1.8 Tamron 28-200mm F2.8-5.6 Sony FE 20mm F1.8G +1 more
Thank you so much for this. Also love your signature mirrorless + peaking redefines the manual focus game.
