Looking for a Range Finder to compliment my E-M1 II
Started Apr 29, 2019 | Discussions
Tom899 Senior Member • Posts: 1,241
I'm thinking I should stay with Olympus so I don't have to learn/remember two menu systems? Maybe it doesn't matter? I mostly want it for my primes. I've been thinking about a Pen-F for a long time. I was so hoping a new Pen-F was coming out, but guess not. I'm looking for a nudge or push in the right direction. I started my M4/3 venture with a GX7, I remember liking it. Now I just don't know what to do?
-Tom
 Tom899's gear list:Tom899's gear list
OM-1 Sony RX100 VII Panasonic Lumix G Fisheye 8mm F3.5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +18 more
Olympus E-M1 Olympus PEN-F Panasonic Lumix DMC-GX7
addlightness Veteran Member • Posts: 3,641
Re: Looking for a Range Finder to compliment my E-M1 II
RF choices (with EVF) are quite limited TBH - PEN-F and GX85/9 (or older GX8).
I have the PEN-F and GX85 but for very difference purposes.  GX85 almost exclusively for 4k video/photo mode and PEN-F for everything else.
I prefer primes - 15/1.7, 25/1.8, 30/1.4, 45/1.8 and 75/1.8.  However, when traveling, I'd skip the 30/1.4 and 75/1.8 due to size and weight.  The only travel zoom I take is the 9-18mm.
I like PEN-F with 15/1.7 or 25/1.8 as with a prime it forces me to be more deliberate with my compositions which usually take a more leisure pace, allowing me to enjoy the scenes a few seconds more than if I was using a zoom.  My wife doesn't like waiting though, so if you're traveling with family on a tight schedule(i.e. spray and pray), some times a cellphone works better
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
pdk42
pdk42 Senior Member • Posts: 1,299
Leica: "Hello E-M1, you're looking very cute tonight with that little 12mm prime fitted "
E-M1: Why thank you Mr Leica, that is very kind of you to compliment me like that".
Sorry,  couldn't resist   If you're looking for something to complement your E-M1 then I can definitely recommend the Pen F. UI is very similar and results are identical. That's the combo I have.
 pdk42's gear list:pdk42's gear list
Olympus PEN-F Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 +1 more
BruceRH Veteran Member • Posts: 3,087
+1 I too have the same combination. You really can’t go wrong with the Pen-F, the JPEG’s are excellent if you don’t want to do much in the way of PP or if you do, shoot RAW+JPEG. I find the controls of the Pen-F perfect. I love the location of the exposure compensation dial and I don’t get wound up about the front dial which I use only occasionally. The size and build quality is also excellent IMHO. Don’t overthink it, just get it
 BruceRH's gear list:BruceRH's gear list
Sony RX100 III Ricoh GR III Leica Q2 Olympus TG-6 Olympus PEN-F +44 more
Skeeterbytes Forum Pro • Posts: 23,182
I'd get a Pen F before they vanish. IMO the "prettiest" m4/3 body by a large margin, and has the 20MP sensor.
If I didn't have a GM5 I'd get the Pen. Agree that sometimes the E-M1ii is more than I wish to tote.
Rick
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Note, if you go with the Panasonic range finder cameras that have an electronic viewfinder, be sure to try it out in person.   A frequent complaint is that the Panasonic range finder bodies use a field sequential display, which unlike a normal LCD or OLED display uses one beam to show the 3 different colors, relying on your brain to merge them together via persistence of vision.  However some people are sensitive to such displays, and they see a rainbow effect, particularly when the camera is moved.
Also, the VF is rather tiny.  I don't see the rainbow effect, but for me, the VF is too small to use for extended shooting.
On the other hand, the Pen F uses an OLED display (compared to the TFT LCD display in your E-m1 mark II).  Now, because I need to wear polarized sunglasses all of the time when I'm outdoors in sunlight, I prefer the OLED display because it doesn't have polarization effects.  The Olympus OLED displays in the E-m10 mark II/III and Pen-F don't have as high of a refresh rate that the E-m1 and E-m5 cameras have with the TFT LCD display.  Some people will get headaches with due to the lower refresh rate.
I have both Olympus and Panasonic cameras.  I've been using Olympus since 2002, so I tend to have the Olympus menu system burned into my finger's muscle memory.  I find when I'm using Panasonic, I have to remember the differences between the two.  In particular, I find Panasonic cameras to be more sensitive to burning out the highlights, so I find I have to dial in exposure compensation more often on the Panasonic cameras.  I also find the Panasonic noise handling in JPG files to not be as effective as Olympus, so I tend to just use the Panasonic in situations where I'm not shooting at high ISO.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
john isaacs Veteran Member • Posts: 8,442
I use my E-M5.2 with prime lenses.  And I prefer it for low light; the noise is more "pleasant" in my opinion.
OP Tom899 Senior Member • Posts: 1,241
A lot of  positives, I know I'll end up with a Pen-F.
Thanks!
-Tom
sounfanz Regular Member • Posts: 175
I purchased a Pen F recently to compliment my EM 1 MK II.
I got it primarily for its size, capabilities, and my intention to use it as my "street stuff" camera. I couldn't be happier, love using the monochrome mode too.
 sounfanz's gear list:sounfanz's gear list
Olympus 45mm F1.2 Pro Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro +5 more
inlawbiker Senior Member • Posts: 2,066
I was thinking along the same lines, something smaller to use along with my E-M1 mark 1. I switched from an E-M10 II.
Here's the thing - the E-M1 is small enough that I don't need another camera. It's basically the same size as a GX, except the viewfinder sits atop and isn't integrated into the body. I also had a GX7 briefly. I would rather just use the Olympus.
The only tiny camera I really miss is the old E-PM2. It would be hard to deal without a viewfinder again though.
Greg
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
It depends why it is that you want a second body. But since you say rangefinder, I assume you mainly want something smaller for travel, that still can share your lenses, and double as your backup camera.
The Pen-F would be ideal for that. Similar menu system, and almost the same sensor. And should you for whatever reason not like it, very easy to sell at minimal write off as it is sought after and keeps its value incredibly well.
If your reasons are biased mostly towards small size/weight and less towards a powerful backup camera, a used GM5 may suit you better. The GM is truly pocketable with a small pancake lens, the Pen is not. Expect it to cost half of what a new Pen-F costs, as the GM5 too is very much sought after.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
peppermonkey Veteran Member • Posts: 5,204
Except for the GX8
With its OLED EVF, is arguably the best EVF on rangefinder styled MFT bodies by a wide, wide margin. Simply one of the best EVF's on a MFT camera.
Hubert
My non-digital gear: Agfa Isolette, Ricohflex VII, Bessa R, Bessa L, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
