Chromatic Aberration in RAW files vs SOOC JPEGs - Lumix G9
Started Apr 28, 2019 | Questions
damage98 Forum Member • Posts: 78
Hi reviewers,
Quick question about this. I was comparing SOOC JPEG v RW2 (Lumix RAW) in Lightroom Classic CC and noticed that the jpeg processed in camera handles CA better than LR.
Camera is Lumix G9 shooting RAW +JPEG with a 100-300mm v2 lens, at 300mm, 1000s at f5.6 (wide open) ISO250.
Can someone check this short video I made and comment?
https://www.loom.com/share/9743b1e1d9594ac68508a4e4170c8baf
TIA
Brandon
 damage98's gear list:damage98's gear list
Leica Q Sony a7R IV Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Zeiss Batis 85mm F1.8 Zeiss Batis 40mm F2 CF +1 more
Panasonic 100-300mm F4-5.6 II Panasonic Lumix DC-G9
Keit ll Veteran Member • Posts: 5,172
Re: Chromatic Aberration in RAW files vs SOOC JPEGs - Lumix G9
Have you set LR to cancel CA?  The amount shown should be easy to deal with.
ToxicTabasco
ToxicTabasco Senior Member • Posts: 2,549
damage98 wrote:
Hi reviewers,
TIA
Brandon
I get, similar performance with JPG and raw.  I set the camera up for straight out the camera MP4 4K and photos.  Thus, the 4K video quality and JPGs do look a lot better than the raw files.
The JPG processing does a good job for NR, CA, lens correction like vignetting and distortion.  Thus, for most stuff I shoot JPG and MP4 4K.  The only time I use raw is for bracket exposures, and any landscapes I plan huge changes to exposure and color.
With 100-300, I've never had any problems with CA.  Sharpness at 300mm wide open is usually my challenge  with the lens.  At 250 it's performance is great, and for 4K it does work great for wildlife out to 300mm.  But, tripod or monopod is needed for the best panning shots.
 ToxicTabasco's gear list:ToxicTabasco's gear list
Nikon D5500 Nikon D7200 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
JosephScha Veteran Member • Posts: 7,249
It's not that Raw introduced CA, it's that the camera's JPEG engine does a great job at removing it.
In your video, when you checked the box to remove CA nothing happened. I'm going to guess that Lightroom doesn't have a profile of that lens.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
evan ts Forum Member • Posts: 65
You can remove the lateral CA with the lens profile in Lightroom. However, it is longitudinal CA at the helmet edge. Longitudinal CA is not include in the lens profile. Try the Defringe Control.
http://blogs.adobe.com/lightroomjournal/2012/04/new-color-fringe-correction-controls.html
 evan ts's gear list:evan ts's gear list
Canon EOS M Fujifilm X70 Olympus PEN E-P5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 +8 more
