Panasonic GX7 - exposure compensation in manual mode
Started Apr 24, 2019 | Questions
matthewcole9 New Member • Posts: 2
Long time reader of the forum. This issue has irritated me so much I’ve had to register to ask for help.
I can’t for the life of me figure out how to take control of Exposure Compensation on M mode.
I have full control over Aperture and SS, have the ISO set to a value (i.e. not auto). I’ve tried with both auto WB and not auto WB. No matter what combo of settings I get, the camera always seems to automatically increase (or more often) decrease Exposure Compensation. I can’t change the value in the menus and pushing in the back dial doesn’t work either (this usually allows me to change this in AP and SP modes).
Please can someone point out where I’m going wrong?
Panasonic Lumix DMC-GX7
Barry Twycross Veteran Member • Posts: 4,778
Re: Panasonic GX7 - exposure compensation in manual mode
Are you sure what you're trying to do is change the exposure compensation? because changing it in fully manual mode, makes no sense. You are setting the exposure, so you don't need to compensate for the meter's failings.
What exactly do you mean by "exposure compensation" in this circumstance? A phone picture of the back of the camera might help. It sounds like you're trying to change the meter reading.
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
Mark9473 Veteran Member • Posts: 6,428
No exposure compensation in M for the older Panasonic cameras.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Richard Butler
Richard Butler dpreview Admin • Posts: 2,911
Exposure compensation in manual mode is impossible
matthewcole9 wrote:
I have full control over Aperture and SS, have the ISO set to a value (i.e. not auto). No matter what combo of settings I get, the camera always seems to automatically increase (or more often) decrease Exposure Compensation. I can’t change the value in the menus and pushing in the back dial doesn’t work either (this usually allows me to change this in AP and SP modes).
You've run out of parameters to change.
Exposure compensation tells the camera to produce a brighter or darker image than its light meter/assessment of the scene proposes.
In fully auto mode the camera will make use of combinations of shutter speed, aperture value and ISO to produce an image with the brightness you're requesting.
Once you've taken manual control over shutter speed, aperture value and ISO, you've taken away all the tools the camera might use to adjust the output brightness, so trying to apply exposure compensation doesn't do anything.
Richard - dpreview.com
larsbc Forum Pro • Posts: 18,282
The camera isn't changing the exposure compensation; it doesn't provide exposure compensation at all in M mode.  When in M mode, the exposure compensation meter or bar becomes a meter that tells you whether the camera thinks your chosen settings (ISO, aperture, shutter speed) are correct or over- or -under-exposing.
JakeJY Veteran Member • Posts: 5,442
Yep, this is the correct explanation. It's a bit confusing because they use the same spot on the screen/EVF to show it.
See page 95 section about "Manual Exposure Assistance"
ftp://ftp.panasonic.com/camera/om/dmc-gx7_en_adv_om.pdf
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
richj20 Forum Pro • Posts: 10,181
Three Variables
Exposure Compensation (EC) -- increasing/decreasing brightness -- is controlled by adjusting one or more of three settings:
  • Aperture
  • Shutter Speed
  • ISO
In Aperture Priority Mode, the dial you have configured for EC is really a Shutter Speed control dial. Move that dial and your Shutter Speed will change and the Exposure Guide will change accordingly, indicating the change in brightness.
In Shutter Priority Mode, your EC dial is really an Aperture control dial. Move that dial and your Aperture will change and the Exposure Guide will change accordingly, indicating the change in brightness.
In Manual Mode, the camera assigns Aperture to one dial, Shutter Speed to the other. When you set your Aperture and Shutter Speed, the only way to adjust brightness is to change the ISO, the 3rd variable.
Example:
1. I set an aperture of 7.1 and Shutter Speed of 400. Camera indicates correct exposure.
2. I swing the camera around to focus on the mailbox, and the camera indicates underexposure at these Aperture/Shutter Speed settings.
m
3. I increase ISO which increases brightness and the camera indicates correct exposure on the mailbox at these Aperture/Shutter Speed settings.
A feature lacking on the GX7 is Auto ISO in Manual Mode, available on newer camera models. This adjusts the ISO automatically at your configured Aperture/Shutter Speed settings to compensate for scenes with different brightness.
Of course, this is no longer a completely Manual Mode!
- Richard
alcelc
alcelc Forum Pro • Posts: 19,003
M is Manual
was adopted by Panny on older models including GX7.
In M, there is no Auto ISO support. Therefore when all 3 parameters are on manual operation, Exposure Compensation does not available. So, instead of use Auto ISO and EC, we change ISO manually to the same effect but slightly slower in operation sometimes.
On GX85, there is auto ISO option in M mode, but no Exposure Compensation hence becomes another full automatic shooting mode like iA/iA+/P.
On GX9, it allows Auto ISO in M and Exposure Compensation making shooter over ride possible. So becomes a new semi-auto shooting mode like A/S.
Albert
Re: M is Manual
Fully automatic where you set aperture and shutter speed, is not fully automatic at all.
Mark
alcelc
Re: M is Manual
Sorry I should not classify M + Auto ISO without EC together with P because shooter still be allowed to over ride camera setting by EC in P.
When I say Full Automatic, mean that the camera has full control on total brightness of the output (instead of exposure to avoid unnecessary side track here on the traditional idea of the factors of exposure: so not to touch on Triangle of Exposure 😣) that shooter cannot over ride it no matter how the aperture or shutter speed be used.
Please forgive me if I have use a poor term to describe it.
Albert
OP matthewcole9 New Member • Posts: 2
Re: Three Variables
Well, that’s a lot of very helpful replies. Thanks everyone!! Sounds like in M, the EC reading at the bottom of screenshot #2 below isn’t saying ‘the camera will automatically reduce exposure’ but rather ‘using the current settings, the image will be underexposed’
Thanks for the guidance everyone, very much appreciated
  • Aperture
  • Shutter Speed
  • ISO
Example:
m
- Richard
FourthHorse
FourthHorse Regular Member • Posts: 437
Re: Exposure compensation in manual mode is impossible
For some Canon models, at least, it will change the power settings of the flash if in use.
For some Nikons, at least, doesn't it bias the light meter more or less for scenes that ares consistently too light or too dark?
Myself I'd rather achieve the same by picking one of the ISO, speed or aperture parameter to play with and leave the other two where I want them.
Fourth Horse
Erri De Luca said that humans live as long as three horses and then goes on displaying his wisdom. I'm well past both.
 FourthHorse's gear list:FourthHorse's gear list
Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +6 more
