How to properly clean a glass out of a lens
Started Apr 23, 2019 | Discussions
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,905
My old and beloved Nikon 300/4 which I got as a present long time ago developed fungus, sent it to Nikon in Italy to fix and after a huge amount of money it developed fungus again, I bought the tool to remove the securing ring off the lens as to disassemble it, not too big of a deal (fungus at this moment only on the back of the front lens) but I need the proper liquid to clean it before I reinstall into the lens body, what should I look for onto Amazon (to mention one...)?
Thank you
Giovanni - 70% GAS affected
http://www.flickr.com/photos/giovanniaprea/
Nikon D800 - Nikon D2Xs - Fuji X-Pro1 - Fuji S5Pro - Panasonic DMC-L1 - Nikon F - Nikon F3
J.A. Michell Gyrodec - AR SP-9 - Aeron AP-890 - JBL4311B
JN70CN - 14.14.30E 40.32.40N
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon Z6 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED +20 more
petrochemist Veteran Member • Posts: 3,619
Re: How to properly clean a glass out of a lens
Iso-propanol (also known as propan-2-ol, or 2-propanol) is generally considered to be highly suitable. You'll want a high purity grade to prevent muck being left on the lens afterwards).
It sounds like you need to invest in a system for keeping the humidity down in the area you store your lenses. Fungus only grows when the humidity is high enough. A drying cabinet might be the ultimate solution, but a bag with silica gel pouches can be sufficient IF you dry them frequently.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
Giovanni_1968
OP Giovanni_1968 Veteran Member • Posts: 3,905
Thank you so much for your prompt reply, I will look up for it, am pretty sure AmaZZon might have it
The lens was probably store in a dump environment, it was a present I got in the late 90s if I recall correct, none of the other lenses I own, fortunately, developed any.
Grazie!
