Managing images in bulk, how to add metadata to thousands of images
denverdonate
denverdonate Forum Member • Posts: 54
When I throw an image in photoshop I usually add additional exif data before saving but I need to manage a few thousand images and I wanted to add 1 thing to the exif of these thousands of images. Is there a tool to bulk/instantly add a piece of metadata to all of the images at once without having to run a batch script in Photoshop?
richardplondon
richardplondon Forum Pro • Posts: 10,880
Re: Managing images in bulk, how to add metadata to thousands of images
Yes: Exiftool
 richardplondon's gear list:richardplondon's gear list
Pentax K-5 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc DA 35mm F2.8 Macro Limited +6 more
Dale Garman Contributing Member • Posts: 923
You can also do that in LR.  In the Library module, you add the piece of data to a single picture, and then anchor on that picture and select as many additional ones as you like.  At the bottom right you will get Sync Metadata which then opens up screen so you can pick which piece of metadata it is that you want to sync to all of the images.
It is really the mirror to the process in the Develop module for syncing various adj to multiple pictures (like white balance, sharpening, noise reduction etc.).  But when you start in Library instead of Develop it syncs metadata.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm f/1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
