Some quick NX Mini questions...
Started Apr 21, 2019 | Discussions
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
OK - so I just found a brand new NX Mini (green version) with 9-27 lens for only $349. It is an excellent ebay vendor that I've purchased several cameras and lenses from in the past. I've been mulling an NX Mini purchase for over a year now, but some of the prices I've seen are ridiculous.
Question number 1 is - in the event that the camera may still have the original FW that came when the camera was first released, is updating the firmware to FW versopm 1.10 fairly easy to do manually?
Or better yet, is the iLauncher software still capable of updating the Mini? I've downloaded the FW file already manually from this site:
http://samsungnx.herokuapp.com
If the FW updates are no longer stored on the Samsung website, then I imagine the iLauncher software will be worthless and it will have to be done manually.
OK - so some of you will be wondering why in the hell I even thought about the Mini. Quite simply - I've seen some outstanding imagery coming from that camera. Sure you would argue that the current crop of 1" sensor models from Canon and Panasonic will probably be better (and faster). But it's not a Samsung and I prefer the way colors are rendered by the Samsung - not to mention the svelte design of the Mini.
Question number 2 is - Any hints on how to attach a lens hood? Otherwise, I'll do what I always do - that is, if the lens accept a filter (which is does at 39 MM), I can add a step-up ring to place a lens hood on the lens an avoid vignetting.
Life can be good - if you allow it!
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Samsung NX mini
Massao Senior Member • Posts: 2,580
Re: Some quick NX Mini questions...
I don’t have  NX mini, so can’t answer specific questions related to that.
Regarding updating the software: as long as it is similar to NX series, it shouldn’t be a problem.
Regarding iLauncher: yes, it still works, and updates software without any problems. I updated a NX3300 few days ago without any issues.
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
Ben Herrmann
OP Ben Herrmann Forum Pro • Posts: 21,163
Thanks...
I appreciate the response and clarification.
Ogard New Member • Posts: 12
Re: Thanks...
I have been using this lens cap on my mini zoom lens, works fine after years of use.
https://www.amazon.com/JJC-ALC-NXM927-Samsung-Camera-9-27mm/dp/B00MYFJN8E
 Ogard's gear list:Ogard's gear list
Samsung NX mini Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 85mm F1.4 ED SSA +8 more
Ben Herrmann
Will give that one a try...
It's cheap and although Amazon doesn't mention it, the delivery time frame indicates that its coming from China, so it should get here in two weeks or so.
Foto_Dude_1 Forum Member • Posts: 63
That's somewhat high price. A year ago I bought NX mini, 9mm lens, 9-27mm lens, external flash with case, half camera case/strap, 16gb card, and box for 215-225$.
It's a solid camera for 1" sensor but as it only has 3 lenses(1 of which is tough to find) and smart adapter is hard to find and expensive to NX samsung lenses, I would see what else is out there.
I bought a dumb adapter on ebay for 36$ to use C lenses but quality is hit and miss. It does allow you to use lenses like Angenieux or Navitar 25mm/0.95 on it. I have gotten some solid pictures with a double adapter like NX mini to C and C to Nikon F. There's a 2.7x crop factor to focal length and depth of field but a lens like 50mm/1.4 non-AI/AI lens produces sharp pictures.
Image quality is close to many MFT however you're investing in a dead system. I have both this and Nikon 1 J5 and this has better image quality unfortunately you can't use the flash with dumb adapters.
This one was with Navitar 25mm/0.95
These were done with double adapter and Nikon 50/1.4 lens. First one had 3 C extender rings.
Ben Herrmann
Well, the used ones are obviously going for far less....
But finding one new - with the stock kit lens - the prices are higher obviously.
Kinger
Kinger Contributing Member • Posts: 549
I like the mini a lot. I got some great photos out of it on a Hawaii trip. In the end the kit zoom failed on my which is pretty common. There is a tutorial on how to fix it. Also, it is an odd animal because it is small but still too think to slide into jeans pockets with anything other than the lens coverless 9mm. I ended up switching to a Sony RX100 iii as my compact camera. The mini produces beautiful photos like all Samsung camera that are mostly superior to the Sony RX100. The 17mm is a real gem too if you can find one. The 9mm is worthless outdoors as it is a mess of lens flare.
enjoy it and have fun!
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
Ben Herrmann
Got a link to that tutorial on how to fix the 9-27?
That link would be good to have just in case.
Kinger
Re: Got a link to that tutorial on how to fix the 9-27?
Here is the thread I started a few years ago. Ppgflyer responds a ways down with the fix. Others report that it worked. Hopefully you don’t have an issue.
https://www.dpreview.com/forums/post/57564844
Ben Herrmann
You mentioned "a video," or was that a slip of the tongue...
A video would be so much better as I'm a visual learner.  Or is this thread what you were talking about?
Kinger
Re: You mentioned "a video," or was that a slip of the tongue...
This is all I have, although I know I remember seeing other threads. Not sure where. But who knows how  spread this was. I’d just enjoy it and if things go bad, worry about it then! 😀 maybe it was isolated to a single build lot.
armin304 Contributing Member • Posts: 740
I can't agree with this statement. If the lens is clean, I don't have trouble with flares. With fingerprints and dust it looks bad, but it's not like my Nikon P900, which flares badly at the short end, especially when the lens is dirty.
Actually I bought my NX Mini four years ago as a cheap demonstrator with the 9mm. It had fingerprints on the frontlens, the rear lens and the sensor. The first images I took did look really bad.
 armin304's gear list:armin304's gear list
Nikon Coolpix P900 Sony a7 II Panasonic Lumix DC-GX9 Nikon Z6
M_digicapt Veteran Member • Posts: 3,289
Did the 9-27mm came with a cap? Bought mine used and always wondered about that.
I bought a Chinese kit that came with cap, hood and filters. The 39mm pinch cap didn't fit the lens  well and kept falling.
The hood is a Leica vented type, but I don't use it because I fear it might strain the unlocking mechanism.
The camera is so small the I can cup the left hand over the lens if necessary, but flare hasn't been much of a problem.
The cap solution was getting a 39-49mm step filter to use with a 49mm pinch cap which is about the width of the lens.
It's a great camera. I'm thinking of selling it though, because haven't seen much use since I got the Panasonic 14mm f2.5.
Regards
Ben Herrmann
Well, I purchased it new...
It was a new kit, so I imagine it will come with a cap.  It should be here within the next week.
I've already positioned what I need to do.  I have a box of step-up rings along with various miniature wide-angle hoods.  I've got 39 MM filters.
Before I purchase any camera system, in particular these smaller ones, the first thing I look at are filter sizes, will it require a hood (I always put hoods on my lenses, even if I have to customize being able to do so with step-up rings, etc.
Of course, as is the case with any "new" kit of a camera that has been out of circulation for awhile, it's all a gamble.  So far I've been fortunate.  If this was another brand camera, I would not have done it.  However, since I'm so enamored with various Samsung cameras, I had to jump on this NX Mini.
Re: Well, I purchased it new...
I bought mine so cheap that I didn't care it's out of production.
The original owner said that it didn't bring a cap, that's why I ask. It's probably not a regular cap because the filter thread is very shallow.
The 9-27mm's IS works really well allowing for very good IQ, at the wider end, in low light with static subjects.
Even found an extra original charger and battery for us$10. The same battery model was used for a galaxy S phone. BtW , the battery life is very good. I've never needed more than one charge per day.
Regards
Ben Herrmann
One more question about the NX Mini....
Hey gang...just one more question here.
I'm looking at this NX Mini, have read tons of info about it, and yet nowhere does it mention anything about a dustbuster or sensor cleaning device.  Does the NX Mini have a built-in sensor cleaner as all contemporary cameras do?  I know that in the regular NX line, you have an option in the menu structure to have the sensor cleaning begin either on turn-on, or on turn-off, or both.
Have a great day...
Re: One more question about the NX Mini....
No, the Mini hasn't a sensor cleanig mode. I don't see the need in the NX Mini, with the easily reachable hardened glas in front of the sensor.
But I can definitely state, the NX Mini mount isn't dust proof. After a little accident with my bicycle, my NX Mini not only has some nice scratches on the display, it was also covered with dust inside (rear lens and sensor, but the 9mm was still mounted) and out. I just blew the dust away with my rocket blower, brushed the remaining dust away with a soft brush and gave it an additional wet clean, to flush the remainder away. As easy as getting rid the fingerprints on the sensor after I bought the Mini.
