Lumix model differences
Started Apr 21, 2019 | Discussions
SFfPhoto Regular Member • Posts: 199
Hello there, other than 16 or 20mp sensors (all having similar rating at DXO Mark) how do these series differ from each other?
1) GX_ series i.e. GX7,8,9
2) GX80/85
3) GX850
4) I believe the GM5 would also be comparable however is much smaller and one does not see many used offers.
Thanks in advance!
Panasonic GX850 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX7
Danielvr Veteran Member • Posts: 6,863
Re: Lumix model differences
6
Are you familiar with the camera compare feature on this site?
https://www.dpreview.com/products/compare/cameras
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
brentbrent Veteran Member • Posts: 5,766
Though the model numbers support how you categorized them, in actuality it is different:
1. GX7, GX85, GX9 are really one series, and in fact in Japan the latter two are named GX7 mkII and GX7 mkIII. They are all about the same size, and all share the same viewfinder (though it does not tilt on the GX85). They all have a tilt LCD. The GX85 had some improvements over the GX7, but it also had some cuts in features to hit a lower price point. I have a GX7 and I was not tempted by the GX85. The GX9 is a clear upgrade over either the GX7 or GX85. In its favor, there are some amazing two-lens kit deals with the GX85.
2. GX8. This camera should really be considered a one-off, at least so far. It has a bigger body, bigger, beautiful EVF, and is weather resistant. It was the first camera with Dual IS. Though its four-axis IBIS isn't as good as the later five-axis IBIS in the GX85, G85, GX9, etc., it does OK. It seems to be becoming a bit of a cult classic, as it appears Panasonic may never release a true successor (the GX9 is a successor to the GX85, as mentioned above).
3. GX850 - a rebranding of the GF line. A smaller camera than the others, no EVF. I don't know as much about this one. It has its fans but never appealed to me.
4. GM5 - a little gem, supremely well built, with a tiny but usable EVF. To make it this small, they had to build a totally new shutter mechanism that is electronic shutter only once you go faster than 1/500. I think the GX850 uses that same shutter.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Tom Axford Forum Pro • Posts: 10,095
The GX800 (or GX850) is based on the GM1 with the addition of a tilting screen and other updates.  It uses the same 16Mp sensor and the same almost silent shutter.  I like it a lot for its compact size/weight and virtually silent shutter.
OP SFfPhoto Regular Member • Posts: 199
Thanks everyone!
Did not know about the compare feature here, just used same.
GX7,9 & gx80/85 seem almost identical - not sure why Panny produced both & LARGE price difference.
I suspect the IS in both work fine w/ manual legacy lenses?
GM5 looks great for a pocket camera even w/ tiny finder and no IS.
You kinda have to understand the history of Panasonic's "range-finder-style" MFT cameras.  In order:
GF1, 2009 - first MFT RF-style camera, 12MP, no built-in EVF (there was a poor, low-resolution add-on EVF available).  This was an enthusiast's camera, with lots of controls.  It was followed by GF2, GF3, etc., which were considered "let-downs" by many because more novice-oriented.  The GF1 was my first MFT camera
GX1, 2011 - the true successor to the GF1, enough controls for enthusiasts, now with 16MP sensor, and a better add-on EVF. I bought one to replace my GF1.
GX7, 2013 - for its time, it was a stunning tour-de-force RF-style camera, in my opinion.  In about the same size as the GX1, Panasonic added a built-in, tilting EVF (the first MFT RF-style camera with built-in EVF), a tilting LCD, a better 16MP sensor, two control dials, 1/8000 shutter speed, 1/320 flash sync with the built-in, tilting flash, focus peaking, two-axis image stabilization (a first for Panasonic), and more.  This was a premium MFT camera, and it was released with a price of $1,100 with 14-42 lens.  Some people complained, though, that the EVF was too small, and the IBIS wasn't good enough.
GX8, 2015 - a bigger camera than the others, as I've said above.  It had to be bigger to include the big, beautiful EVF.  It also was the first camera with Dual image stabilization.  It had the 20MP sensor and was weather-resistant.  I think it was designed to address complaints against the GX7, and to leapfrog it in features and image quality.  But some people complained that it was too big, wanting a GX7-sized successor to the GX7, and DPR's review was harsh (overly so, many of us think) in complaining about it having a shutter shock problem.  $1,200 body only.  It apparently did not sell as well as Panasonic hoped.
GX85, 2016 - apparently deciding that there wasn't a sufficient market for high-priced RF-style cameras, Panasonic released the GX85, $800 with the 12-32 lens.  It had some improvements over the GX7 (5-axis IBIS), but some reductions in features in order to meet that lower price point.  No tilting EVF, plastic body, no mic jack, lower max shutter speed, etc.
GX9, 2018 - This is a true and unqualified upgrade to the GX7.  20MP sensor, tilting EVF returns, etc.  $1,000 release price with 12-60 lens.
The price differential now between the GX85 and GX9 reflects the fact that the former is three years old, and the latter has a lot of improvements.  The great deals available on the GX85 make it a more difficult decision whether to choose it or the GX9.  Presumably Panasonic manufactured a bunch of them, and they want to sell all of them.
Brent
alcelc
alcelc Forum Pro • Posts: 19,003
Excellent info on Panny GXs...
Might I add:
The first of all Panny MILCs to have IBIS, although very primitive... Had e-shutter that GX1 doesn't which making it was prone to shutter shock at its time... Also P/S/A/M video vs the full auto video of GX1... So GX7 was a great and excited (first to have IBIS) mid range model of Panny at that time which nursed the idea of a higher spec GX8 later.
GX85 was the first, more like a test bed, to use a new hardware standard. A floating sensor to offer 5 axis IBIS for still and video (a standard used by all subsequent models from G85, GH5, G9 and now G90), a more quite electromagnetic controlled m-shutter to reduce shutter shock, adoption of DFD from GX8, no AA filter for sharper OOC output, 4K video and still etc. All are very essential upgrade to my GX7.
IMHO, 20mp sensor, all the goodies of GX85 plus M mode + Auto ISO & EC, the more convenience My Menu etc. A great model for GX7 or earlier models owners or new RF buyers but more incremental for GX85.
Brent
Albert
MOD Tom Caldwell Forum Pro • Posts: 46,352
I have one of each - I agree that the GX85 is hardly a major advance on the GX7 (which was an outstanding camera when introduced).  The GX7 remains competitive today and it is one of those cameras I would find it hard ever to part with.  The GX9 is a very good camera but is somewhat feature stripped compared to the G9.  Panasonic made a major mistake in my opinion in the area of the on/off switch, the smaller mode dial and the “useless” mechanical wheel for EV control.  A mechanical EV control is useless “retro” frippery in my opinion as it is so easy to switch and change EV once the camera is switched on - in fact I change EV often and it is usually in A mode with eye to evf and the regular front wheel changes EV easily and can be seen in the evf.  Furthermore it is easy to try and twirl the rear wheel and find that you are actually moving the EV wheel above it instead.  As a result I have switched it off - it is just an “ornament” for me and I have to put up with the smaller mode adjuster and more awkward on/off switch placement for some frippery that I do not need or wish to use.
Accidental turning of the GX9 EV wheel is compounded when regularly switching between the GX9 and the GX7 and GX85 with the regular and well placed front and back wheels.
The GX9 is a great camera slightly marred by Panasonic’s own goal with a mechanical EV wheel which surely is more about style than substance.  Please Mr Panasonic - give it a miss on future models ....
The only issue with the flip up evf is that it tends to get hooked up in a camera bag.  (The fixed evf of the GX85 does not protrude as much and therefore does not seem to get snagged). Use the flip evf? Only twice on the GX7 and never on the GX9 - some seem to like it - I never seem to need to use it and when I tried it feels awkward.  On the GX7 is was a handy place to hide the dioptre wheel for easy access and adjustment - but it does not even do that on the GX9.
Tilt evf and tilt lcd seems overkill to me.
As far as I know the GF7-GX950 series uses the basic works of the GM1/5 series but in a larger body and “only” a tilt lcd.  The GF7 has progressed to the GX950 (the latter not available everywhere) by annual updates and has had some passed in improvements over the GM1/5.  But unfortunately the GF7, etc has been marketed to more entry level users - hence the flip up lcd and promotion of “jump shot” etc.  The GM1/5 was a more expensive build type and with the built in evf in the GM5 it is a more serious camera than its tiny size gets it credit for.  I think that the more commonly available GX850 is probably quite a useful camera but it has never attracted me and I have a few GM1/5 bodies instead.
Tom Caldwell
Thanks to Danielvr - I now have this chart (all comments here though are great and many thanks!):
https://www.dpreview.com/products/compare/side-by-side?products=panasonic_dmcgx7&products=panasonic_dcgx9&products=panasonic_dmcgx85&products=panasonic_dmcgm5&sortDir=ascending
>in response Albert wrote
:>IMHO, 20mp sensor, all the goodies of GX85 plus M mode + Auto ISO & EC, the more convenience My Menu etc.
The above chart indicates all have M mode along with P, A etc.
If MY Menu is like Oly's Super Control Panel then that is helpful.
Is it true than only the GX9 has auto ISO?
Of concern to me is that the GX7 has 1/320 sync and the others are slower, the GM5 only 1/50.
I have found though on non Lumix cameras I have used that if using an off camera non-TTL flash one can have a slightly higher sync speed.
Do any of these offer a multi aspect sensor ala LX7 and LX100?
All have auto ISO in A and S modes, but the GX7 does not have the ability to shoot in Manual mode and use auto ISO at the same time (Panasonic used to think that "Manual" means "Manual" with no auto aspect allowed).  I think GM5 can shoot manual with auto ISO.
Then there is a further enhancement of being able to shoot in Manual mode, use auto ISO, AND dial in some exposure compensation, AND set minimum shutter speed (at which point ISO goes up)  Not sure where the GX85 and GX9 fall.  I think the G9 can do all of that, so perhaps the GX9 can as well.
No.
Brent
alcelc
Brentbrent had the right answer.
GX7 allows Manual ISO in M only. 100% Manual mode. GX85 allows Auto ISO in M but no Exposure Compensation, so another 100% full auto mode. GX9 allows Auto ISO in M and can do Exposure Compensation, i.e., shooter can over ride the setting of the camera, to become the 3rd semi automatic mode in addition to A and S. It is recently quite a popular shooting mode for some who need to control aperture and shutter speed but can fine tune the ISO suggested by the camera for a faster operation.
Panny has a "Shooting Info Display" similar to the SCP of Olympus, allowing shooter to select and change the per fixed shooting parameters on LCD. Unlike SCP of Oly, it is controlled by the DISP key and as it is one of the displays in sequence, very often we have to navigate through various pages before arrive there. No direct key can reach the page (if you are not there last time using the SID page).
However, most Panny models (except the entry class GX850 a.k.a. GF9 or GF10) has a lot of customizable fn keys and Q.Menu (for GX7/85/9, should have 9 fn keys, 15 items in Q.Menu, and better for GX85, not sure GX9, 2 more customizable controls to the 2 dials making the SID not essential at all. Still more, each C mode (5 for GX7, 3 for GX85 etc) can have their own set of fn keys/Q.Menu, it usually can give more control than SID. On GXs, shooter has an option to disable the SID for a more simple LCD display system.
I have SID disable on my Pannys.
See above.
When external flash gun be mounted, if it is fully compatible to M43, usually I can shoot with much higher shutter speed without issue. IIRC, 1/500"~1/1000" is safe using Godox TT350O on GX7 and GX85 on non HSS mode.
The syn speed is for the integrated flash only.
See above.
No, only the older GH does.
Albert
Thanks again to you all. Terrific information that charts alone can not provide.
Derek Bach Contributing Member • Posts: 866
Tom Cardwell is one of my m4/3 heroes who is never wrong - well usually not!.
Having just swapped my GX7 for a GX9 I love the mechanical LV wheel. So I can see at a glance that it is off "0" or not. However Tom, I still have and love my GM5 and am waiting a true up-date - perhaps it will have LV wheel.
Derek
 Derek Bach's gear list:Derek Bach's gear list
Ricoh GR Panasonic ZS100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +5 more
