kingston memory
Started Apr 20, 2019 | Discussions
Laksh Junior Member • Posts: 47
kingston memory
I use a canon t6 and is kingston SD memory good quality. I am seeing lot of options from sandisk. there is thread on that in open talk, need  your opinion on kingston memory it is much cheaper here,
laksh
Canon EOS Rebel T6 (EOS 1300D)
Ray UK Contributing Member • Posts: 977
Re: kingston memory
Kingston SD cards are OK, I have used them before with no problems. If you are buying them because they are cheap then you have to be careful that you are not buying a fake card. Buy only from a reputable camera dealer.
Il Mostro Regular Member • Posts: 344
Re: kingston memory
Genuine Kingston cards are fine in terms of functionality and reliability. I have, however, found them to have slower speeds than comparably spec'd SanDisc products.
 Il Mostro's gear list:Il Mostro's gear list
Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Canon EOS 5D Fujifilm X-E1 Canon EOS 6D +39 more
OP Laksh Junior Member • Posts: 47
Re: kingston memory
would there be any use of using a faster card in slow camera which does not go beyond class 10. Would a class 10 card be enough for full HD video or do we need faster speed.
laksh
R2D2 Forum Pro • Posts: 26,551
Re: kingston memory
Recommend using Sandisk Extreme Pro cards for everything.  Cards are very inexpensive nowadays.  The Sandisk Extreme Pro is the best.
R2
Oldpanda Forum Member • Posts: 96
Re: kingston memory
laksh
I have an older class 10 card that will not do 1080P video in my SL2. I use it in my PowerShot G11. My advice is to check your owner's manual about cards including class, IHS and V rating and make that the MINIMUM specs you buy.
Certainly these cards would work:
Kingston Canvas React 32GB SDHC Class 10 SD Memory Card UHS-I 100MB/s R Flash Memory High Speed SD Card (SDR/32GB)
SanDisk 32GB Extreme SDHC UHS-I Memory Card - 90MB/s, C10, U3, V30, 4K UHD, SD Card - SDSDXVE-032G-GNCIN
(Couldn't get links to work)
I use the SanDisk and it has worked fine in my SL1 and the SL2 I replaced it with.
They are between 11 and 13 dollars on Amazon.  SD cards have really gotten inexpensive through the years.
Hope this helps.
Glenn
 Oldpanda's gear list:Oldpanda's gear list
Canon PowerShot G11 Canon EOS Rebel SL2 Canon EOS Rebel T8i (EOS 850D) Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +4 more
