Focus question and advice please!
JimKasson
JimKasson Forum Pro • Posts: 25,087
Re: The DOF Jedi!
Greg7579 wrote:
That is very well said Jim.
You mean Rick?
Jim
Posted as a regular forum member.
https://blog.kasson.com
 JimKasson's gear list:JimKasson's gear list
Nikon D5 Fujifilm GFX 50S Sony a9 Sony a7R III Sony a7 III +5 more
Greg7579
Greg7579 Senior Member • Posts: 6,696
Re: The DOF Jedi!
JimKasson wrote:
You mean Rick?
Jim
Dammit -- that was Rick?  OK.  Props to Rick. That was a good post.  Thought it was Jim.  I'm traveling, and check with the phone when I get Wi-Fi.  I have been known to not know what thread I am on or who I am talking to in these situations.
You, Rick, Erik, Chris, Left Eye and others are all pretty good at this whole focus point DOF MF thing.
Greg Johnson, San Antonio, Texas
https://www.flickr.com/photos/139148982@N02/albums
 Greg7579's gear list:Greg7579's gear list
Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 16mm F1.4 R WR XF 90mm Fujifilm X100F +13 more
Macro guy
Macro guy Veteran Member • Posts: 3,972
Re: The DOF Jedi!
Greg7579 wrote:
JimKasson wrote:
You mean Rick?
Jim
Seems that your Circle of Confusion was too great and you had inadvertently focused on Jim.  And THAT is why you need a depth of field calculator! ^^
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm f/1.8 II +5 more
OP mtakeda Regular Member • Posts: 337
Re: Focus question and advice please!
Jim, I am having difficulty in downloading the app you recommend here. I want to have your comments on the app by the name of Setmycamera.
JimKasson
I can’t tell enough by looking at the description. As I said earlier, the calculator I recommended is not an app. It’s a website.
Thank you. Any recommendation from apps?
JimKasson
Yes.
https://itunes.apple.com/us/app/truedof-pro-dof-calculator/id517481814?mt=8
Jim
Thank you very much.
Ok I purchased the app you mentioned. For my GFX50R CoC is 38micron according to the software and is this reasonable? In the past you mention to input 1micron then I can not raise the aperture beyond f4. Confused.
fcracer Contributing Member • Posts: 936
If I read Jim’s note in the thread, he said 10-15, not 1.
Fujifilm GFX50R review: https://fcracer.com/fujifilm-gfx-50r-first-impressions/
Medium format travel camera: https://fcracer.com/medium-format-travel-camera/
Travel and photography blog: https://fcracer.com
 fcracer's gear list:fcracer's gear list
Fujifilm X-T10 Fujifilm X-Pro2 Fujifilm X-T2 Leica M10 Fujifilm GFX 50R +14 more
Thank you. I think you are right. He said 10. But when I input 10 to DoF pro it sets the max aperture at f5.
pro
JimKasson
If you like blur.
I don't think I said anything of the kind. 10 um is acceptable blur for critical work, but many scenes, like the one you posted, will need a larger blur circle if diffraction is included.
Jim
JimKasson
See this:
https://blog.kasson.com/the-last-word/choosing-f-stops-and-focus-distance-for-landscapes/
You can find links to all the other posts in that series by scrolling down to the bottom of the page — below the comments — and looking at the pingbacks.
Jim
Erik Kaffehr
Erik Kaffehr Senior Member • Posts: 2,822
Hi Jim,
The stuff you are sharing is very good. But, it is based on a basic understanding of basic principles of photographic imaging.
Back in 1913, when Oscar Barnack developed the first Leica he counted what kind of resolution was needed to achieve the quality of a printed postcard of that time. He arrived at about 1/1500 of the image diagonal. The original Leica had 24x36 mm image size with a 43 mm diagonal. 43 / 1500 -> 0.028, or something like 0.030 mm, this is the magic number that DoF calculators use.
So, that essentially says that if we photograph a star image, a spot on the sensor 0.03 mm wide would be perceived as sharp.
Now, digital cameras have pixels. Pixels are mostly rectangular. So how large would that pixel be?
Let's calculate the area of the 0.03 mm spot, that would be Pi * (0.03 / 2) ^2 -> 0.000707 square mm.
How large would a pixel be that had the same area? sqrt (0.000707) -> 26.6 microns.
So a 24x36 mm sensor with 27 micron pitch would match Oskar Barnacks criterion.
How many megapixels would that be? The answer is:
24 / 0.027 * 36 / 0.027 / 1e6 -> 1.2 MP. So, we need like 1.2 MP for a postcard size image. That was true in Oskar Barnack's time and it is true in our time.
So, what is different now? Some things, but not much.
If we look at a 'Bluray' movie, it has a resolution of 1920 x 1080 pixels. That is around 2.1 megapixels twice the information Oskar Barnack found 'good enough' back in 1913.
Just to say, most viewers find 24" full HD screens sharp enough. If we judge sharpness on a 24" monitor we see around 2MP. Oskar Barnack's 1500 CoC across the diagonal shake a bit.
But, now we go 40-50 MP on 24x36 mm or 33x44 mm. The old requirements for sharpness are as valid as ever.
Except, we print (or display) large and view close. A 4K 24" monitor will be not more demanding than a full HD (2K) 24 monitor, unless we view it at half distance.
So, now we have high resolution, we need to change the way we see images to make best use of it. The recipe is to print (or display) large and view close.
Once we do it, we also need to change our criteria for good sharpness.
Best regards
Erik
Erik Kaffehr
Website: http://echophoto.dnsalias.net
Magic uses to disappear in controlled experiments…
Gallery: http://echophoto.smugmug.com
Articles: http://echophoto.dnsalias.net/ekr/index.php/photoarticles
JimKasson
Erik Kaffehr wrote:
Hi Jim,
I can't disagree with any of that.
Erik Kaffehr
JimKasson wrote:
Erik Kaffehr wrote:
Hi Jim,
Thanks Jim!
My point is that you cannot understand the future without understanding the past.
Many of the recommendations, like 0.030 mm CoC are based on the past. There is nothing wrong with that, those recommendations still serve us well.
But, even cell phones are good enough to fulfill those recommendations. I would say that cell phones are just great for 'f/8 at 1/125s and be there' kind of images.
But, if we want to deliver beyond 'f/8 at 1/125s and be there' we need to learn and understand new criteria, leading to new approaches.
Just to say, 'f/8 at 1/125s and be there' has given us a lot of great images, think David Douglas Duncan, Cornell Capa, Elliot Erwitt or Ernst Haas. Well, regarding, Ernst Haas was probably not in the f/8 at 1/125s club...
With the new camera systems, we may be in search of something else, like 'excellence'. Looking at excellence, we may need to reexamine the rules.
Playing the old f/8 at 1/125s rules on modern cameras may be suboptimal use.
Best regards
Erik
Erik Kaffehr
I am quite confused. Do you think, knowing my landscape shots, CoC 38 is happy compromise or do you different number for me? I do not think I can live with F5 which true DOF pro app sets as the max for wider DOF.
JimKasson
Baby steps
No! How many times do I have to say that?
You seem to want this whole thing spoon-fed to you. That's not the way to learn how to take pictures. Others can supply the science, but you need to figure out what you can tolerate in terms of blur.
Try this experiment.
  1. Find a scene that has a lot of subject matter at a particular distance.
  2. Using your DOF/diffraction app, take pictures with subject blur circles of 2, 5, 8, 12, 16, 20, 30, 40, and 50 um.
  3. Print crops that translate to your chosen print size. Or, what the hey, make prints in your chosen print size.
  4. Evaluate those.
  5. Than decide, situationally, what blur circle diameters you think are excessive.
Jim
Re: Baby steps
Sorry for bothering you by too many naive questions.
JimKasson
Re: Baby steps
I don’t mind naive questions at all. I do mind your seeming ignoring of my answers.
Run the test I suggested and the scales will be lifted from your eyes.
Jim
