Panasonic 100-300 lens for people shooting?
Started Apr 17, 2019 | Questions
pavel-jazz New Member • Posts: 1
Hi! I have Panasonic g85 with 14-140 f3.5-5.6 lens and 35-100 f2.8 lens
But i want more powerfull zoom.
Not for wildlife or birds shooting, but generaly for shooting in city (cars, people, etc.)
Will it be good choise or not?
 pavel-jazz's gear list:pavel-jazz's gear list
Panasonic G85 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Leica DG Summilux 15mm F1.7 ASPH
Panasonic G85 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Re: Panasonic 100-300 lens for people shooting?
Hi
To get more zoom then the 100 - 300 is certainly one of several options
If the people or subject is not moving then it will probably be easy to use.
If the subjects are moving then it's a matter of you being able t get them in frame, focus, track and shoot, which may not be easy.
I think the result of this test will answer better than anyone here could answer for  you:
Test:
  • use your 14-140 at the 140 end
  • Zoom with your feet to make a typical subject be as zoomed as you'd like
  • Try to get the shot
For example:   If doing moving cars/people, position yourself somewhere so that at 140 mm you have the cars/people filling the frame so that it appears they way you want if you had the 100-300.    See if you can get the shot.  If yes then you simply need to figure out how much more zoom you want,e.g.   the 200 mm lens, the 100-300, etc.
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
Straggler123 Regular Member • Posts: 310
Try setting your existing lens to 140mm and turn on your ex teleconverter to see how practical you think it is.
Peterd21 Regular Member • Posts: 353
Suspect you might find 100mm frustrating at the short end, especially if used to the 14-140 or 35-100. Yes, the 300mm reach is good for long shots but you may find yourself wanting to shoot wider than 100mm. Not sure how best to try this, maybe go out with the 35-100 and keep it to 100mm and see how many shots you can't get ?
 Peterd21's gear list:Peterd21's gear list
Panasonic Lumix DC-G9
Jakob Malm
Jakob Malm Regular Member • Posts: 392
Although I have some portraits that I've taken with the 100-300 mm, they're almost always at 100 mm. Even at 100 mm, faces look a bit funny because of the narrow angle.
Some samples, all taken with a GX7 and 100-300 mk I:
100 mm, f/4
100 mm, f/4
162 mm, f/4
Composition of two photos at 100 mm, f/4
Barry Twycross Veteran Member • Posts: 4,778
I just posted an example, it works for me. That is if you want to be a long way from your subject, so they don't notice you there.
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
