Sony RX10 IV vs Canon 7D mk II & 100-400 IS mk II
Started Apr 16, 2019 | Discussions
david31
david31 Regular Member • Posts: 332
Here are a few images comparing the quality of the RX10 IV vs Canon 7D with the 100-400 IS mk II, shot at Slimbridge Wetland Centre.
All shots are handheld.  I wasn't taking as much care taking the shots as I could have, so better technique might have produced better results.
Both cameras set to 400 ISO.
Virtually all of the images are at maximum focal length, i.e 600mm on the Sony and 560 mm equivalent on the Canon.
Canon aperture f/5.6, +1/3 EV
Sony aperture f/4, 0 EV
Canon jpg images sharpened 52% with 0.2 pixel.
Sony images jpgs direct from the camera.
The Sony is very sharp but has more noise.
My 100-400 IS seems to back focus sometimes  or just be a bit off.
I was shooting the Canon by mistake in mode 3 image stabilization but soon switched to mode 1 with much better results.
Obviously the birds are not perfectly stable so that will introduce some variation to the images.
I bought the RX10 IV to replace my Panasonic FZ1000 for use when hiking after being very impressed with my wife's RX100 VI.
I have seen some failure to focus on birds in flight but that my be my lack of experience or poor technique.
The focus point on the right hand Canon image was on the eye.  This clearly shows back focus.
Canon EOS 7D Panasonic FZ1000 Sony RX10 IV Sony RX100 VI
david31
OP david31 Regular Member • Posts: 332
Re: Sony RX10 IV vs Canon 7D mk II & 100-400 IS mk II
Sony RX 10 IV images on the left, Canon 100-400 IS images on the right.
david31
All images 100% crops.
david31
No comments from any one ???
Stephen Ingraham Senior Member • Posts: 1,948
Want are your conclusions?
To me the Sony seems to do better than I would have expected! I just spent 10 days shooting side by side with my Sony RX10iv and a companion’s 7D and 100-400. I have not seen her results yet, but I am happy with mine, all things considered.
 Stephen Ingraham's gear list:Stephen Ingraham's gear list
Nikon Coolpix P900 Sony RX10 III Sony RX10 IV Sony Cyber-shot DSC-HX90V Sony Alpha NEX-3N +4 more
BertIverson Veteran Member • Posts: 4,159
I'm bound to be prejudiced but the Sony seems to hold its own at 400 ISO. At ISO 100, it might even look a little better (less Noise)
Enjoyed the comparison.
Thanks,
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX10 IV +5 more
sludge21017
sludge21017 Senior Member • Posts: 2,768
Never saw it.
Haven't touched my Canon gear since using Sony.
Paul Barchilon
Paul Barchilon Forum Member • Posts: 59
Nice comparison, thanks for sharing these images.  I think the Canon looks a little better across the board, but the RX10iv  certainly holds up very well.  I looked at Canons and Nikons, and went with the Rx10iv instead.  I never did get to compare image quality like this though, so I appreciate seeing your comparisons.  The one I really wonder about is the Nikkor 200-500 on an APS-C compared to the Sony.  How would that do?  I know I am really happy with the light weight and ease of shooting with the Sony, and I probably wouldn't trade that for a much heavier rig.  This Canon comparison is certainly food for thought.  Certainly not enough to make me regret my choice though.
Brian Wadie
Brian Wadie Forum Pro • Posts: 10,489
I'm not surprised
for me the RX10-4 is my go to camera for focus accuracy, speed and sharpness
If I want better IQ however (for producing prints for sale etc) I will now use my Olympus EM-1 mk2 (my canon 7Dmk2 and 5D mk2 went some years ago)
The RX10-4 is probably the most satisfying camera I have used to consistently capture the images I want with my subject range (bugs, bees and butterflies, wildlife and birding and high speed action water sport)
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Sony RX10 IV Canon EOS M6 II Canon EOS R6 Sigma 105mm F2.8 EX DG OS HSM Canon EF 100-400mm F4.5-5.6L IS II +1 more
nigelbb Contributing Member • Posts: 674
Re: I'm not surprised
The big advantages of the RX10M4 are that enormous 24-600mm FF equivalent zoom & never having to change lenses as you always have the correct lens on the camera.
 nigelbb's gear list:nigelbb's gear list
Sony RX100 VI Olympus E-M1 II Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G +3 more
Brian Wadie
rather important for me when shooting off the beach in the middle of a storm with sand, seaweed, rain and salt-spray lashing about everywhere
When I shot weddings in common with so many other wedding photographers I would have two FF cameras round my neck the first with a 24-70mm F/2.8 & the other with a 70-200mm F/2.8.
Rodger1943
Rodger1943 Forum Pro • Posts: 16,093
I missed you original past as well. Thanks for doing all that work and comparisons. There is a huge amount of work involved in doing that. I wonder how things might have looked, if you hadn't sharpened the Canon images. It seems that by doing that, you remove the level playing field. The other factor is that the two shots in each case aren't identical. That is something it would be impossible to get without some specialised equipment and maybe not even then. I have tried bird comparisons and its nearly impossible to get exactly the same each time and also very frustrating.
I have been out with a Canon 7 mk2 shooter on a couple of occasions, but he uses the Tamron 150-600mm lens. Sometimes we have had near identical shots and mostly mine are sharper. He gets variable results, so I wouldn't want to put too much emphasis on that aspect, as he gets some sharper ones as well. Operator error is always a factor. At least with your comparison, its all done by the same operator. My point here is that the Sony is matching everything he puts out. I will say that this is in reasonable light. The Canon should win in a lower light comparison.
Below is an image I am particularly pleased with in its details. Would the Canon do better? I can't say for sure, but this one looks pretty good to me.
Once again thanks for the big effort in comparing all those shots.
Panasonic FZ1000 FZ200 SOny RX10 iv
 Rodger1943's gear list:Rodger1943's gear list
Panasonic Lumix DMC-FZ200 Panasonic FZ1000 Sony RX10 IV +2 more
Digital Nigel Forum Pro • Posts: 13,727
Not quite. I also often carry my a6500 with 10-18 (15-27 equiv lens) alongside either my RX10M3 or RX100M6. For example, here's a few pictures I took on my recent visit to Delphi, site of the Oracle, in Greece, which needed both cameras:
The whole ancient site is on a very steep hillside
The theatre (which, amazingly, seated up to 5000)
Polygonal dry stone wall with curved joints, to resist earthquakes, under the Temple of Apollo
View down to Itea and the Gulf of Corinth
More in
https://www.flickr.com/photos/recliner/albums/72157690994184393
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +19 more
edform
edform Veteran Member • Posts: 7,738
I've just swum against the tide in this respect, in that I've sold off my RX10-iv and bought a FF Nikon Z6 with 300mm F4 and 1.4x teleconverter for long work. Yesterday I carried this rig about all day at our local zoo - it is soooooooo heavy.
Ed Form
 edform's gear list:edform's gear list
Sony Cyber-shot DSC-RX10
evan47
evan47 Senior Member • Posts: 1,636
I have both the RX10iv and a Nikon D500 and 200-500vr and find image quality to be comparable, sometimes with the edge to the sony in sharpness as long as I work within its limitations, ie; not overcropping.
The main advantage of the Sony is its portability can be quite liberating.
 evan47's gear list:evan47's gear list
Sony RX10 IV
Horacecoker Veteran Member • Posts: 3,391
To me your comparison is flawed. Shooting both cameras wide open with the same shutter speed, the R10iv would have been using 200 ISO and  consequently the image quality would have been even better. So you have failed to take advantage of the F4 maximum aperture of the RX10iv as opposed to the F5.6 of the Canon. Never compare like for like ISOs with different sized sensors, the bigger sensor camera will always start with an advantage. Although having said that, the RX10iv still holds up well in your comparisons.
David
 Horacecoker's gear list:Horacecoker's gear list
Sony RX100 III Sony RX10 IV Sony a6600 Sony E 16-55mm F2.8 G
Bassy Forum Pro • Posts: 11,125
ed last week i traded in my sigma 150mm-600mm lens and bought the rx 10 1v
now my shoulders and neck can take a rest
Rodger1943
You're right about how heavy the DSLR plus lens rig is, but if it gives you the results you want, then its worth it.
Rodger1943
David
I agree with you, David. Its not like for like and as I mentioned in my post above, he has applied extra sharpening to the Canon images, which also adds an advantage to the Canon results.
