New G7 owner, struggling with EVF
Started Apr 16, 2019 | Discussions
FindJerry
FindJerry New Member • Posts: 13
HI all, 8m an experienced photographer who recently purchased a G7. I have been shooting with Nikon for over 30 years.
The EVF on the G7 is taking a bit to accustomed to. Is there a way to turn of the feature where the EVF adjusts to the exposure settings? While I’m sue helpful at some point, it’s current throwing me off.
Thanks,
Panasonic Lumix DMC-G7
Felice62 Veteran Member • Posts: 5,079
Re: New G7 owner, struggling with EVF
I am sure there must be the equivalent funcion of Olympus 'OVF (optical viewfinder) simulation, where the adjustments made to the exposure do not reflect in brightening or darkening of the view through the EVF.
I cook with wine, sometimes I even add it to the food.
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
brentbrent Veteran Member • Posts: 5,768
It sounds like that may be the "Constant Preview" function turned to "on," though I think it only applies when shooting in manual exposure mode.
Have you downloaded the full manual for the camera? ftp://ftp.panasonic.com/camera/om/dmc-g7_adv_en_om.pdf
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
pannumon Veteran Member • Posts: 4,130
Yes.
In M-mode, when "Constant Preview" is ON, the screen responds to F-value, shutter speed and ISO.
In M-mode, when "Constant Preview" is OFF, the screen does not react to anything.
In other modes than M, the screen/EVF only responds to exposure compensation (within +/- 3 EV IIRC), regardless of the "Constant Preview" setting.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
FindJerry
OP FindJerry New Member • Posts: 13
I do have the full manual, but the terminology is less familiar to me than with Nikon's. I'll take a look based on your comment. Thanks!
Pete Berry Veteran Member • Posts: 4,322
I assume you have the Exp. Comp. display on in the EVF. There's a setting in the menu that re-sets EC to "0" after turning cam. off in all Panny bodies I've had - if this is what you mean - that it starts up with EC not zeroed.
It's hard for me to imaging that you would NOT want to see the effect of exposure changes on the EVF and live histogram...as would see shooting in live view in your Nikons...which is the game-changing attribute of the mirrorless revolution.
Pete
FindJerry
pannumon wrote:
Yes.
Thank you! The terminology of “constant preview” was throwing me off.
I really appreciate the help
IanYorke Veteran Member • Posts: 5,266
Thanks,
Just to clarify as it is a strange question on this forum How is the viewfinder showing whether your shot is correctly, under or overexposed throwing you off?
Ian
FindJerry
Thanks,
Ian
It’s no where near accurate to the actual image that’s captured. Now that I know how to turn it off I should be fine. Plus I’m pretty old school, so even if it was accurate I would find it annoying.
(unknown member) Forum Pro • Posts: 19,317
FindJerry wrote:
Thanks,
Ian
If you want the vf accurate to the scene you can adjust the vf brightness and probably  the colours as well to suite your self.
Don
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Are you really suggesting to read the manual???? Heresy!
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
ToxicTabasco
ToxicTabasco Senior Member • Posts: 2,549
Much like a DSLR, there should be a little exposure meter in the EVF or Liveview on the bottom of the screen, showing the exposure with the little tick marks and the + or - and a number.  It can be referred to for exposure like a DSLR.
 ToxicTabasco's gear list:ToxicTabasco's gear list
Nikon D5500 Nikon D7200 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
FindJerry wrote:
Thanks,
Ian
Interesting because having owned a lot of Panasonic cameras I have always found it very close to my expectations.  I won't say accurate because I can't see anyway how you can compare what you saw through the viewfinder when you took the picture with the finished picture.  Surely it can only be perception and just the process of using a viewfinder will no doubt make your brain function differently to say looking at finished article on a big screen.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
It's easy to compare how the image looks before and after releasing the shutter by using the "auto review" functionality. Sometimes with some cameras there is a clear difference, sometimes not. And of course it will always look different on a computer screen or printed.
