mujana
Re: Sony 90mm G Macro vs Voigtlander 110mm Macro APO
thank you macrouser!
macrouser wrote:
I did my first macro shots in 1969 with a 58 mm Minolta lens and extension tubes. It is exciting but hard to do.
The features that I find are the most important are:
1. focus length/working distance
same here...important! I once used a 50mm zuiko lens on my Olympus and I found it too much of an exercise to get good images...working distance way too short. Don’t want that anymore. Voigtlander seems to have a little longer working distance than the Sony 90.
2. resolution
very important indeed. In a graphic I saw, the Voigtlander on an A7RIV was there with only the very best GM lenses.
https://www.sonyalpharumors.com/here-are-the-best-lenses-for-your-a7riv/amp/
3. focus features such as a. internal focus. if you have a lens that extends, never try to use any lighting that attaches to the extending part. It will destroy the lens.
Good that you say this. I didn’t realize that. At the same time, I would like to shoot with natural light as much as possible. Except for slide copying, where I plan to use a light plate anyway.
b. you need a focus ring that give very good control of manual focus.
I think that the Voigtlander has a very nice soft dampened focus (from comments I read).......and a very long focus throw (maybe too long?). Some say the focus throw of the Sony is a bit too short .
c. Auto focus can be a big help in the wind ( there is always wind outdoors ). I set my auto focus control to AF only. That way I can hold the focus button/shutter button down until the camera gets a focus lock. The camera will not take a picture till it is focused.
Good idea!
That works best with a subject that is not too close. At very close distances, auto focus hardly ever focuses on the point that I want.
So then it’s MF anyway. I wonder if focus tracking would work in 1:1 (on my A7RIV).
I just got a Sony A7Rm3. adapted lenses never give all the features that the camera has.
Correct, but I certainly would like some communication between lens and camera (unlike the attractive Laowa macro). I think I could work with the Voigtlander (does communicate (f/stop/focus peaking), but obviously no AF. In this regard the Sony is better (but...how much will I use AF in macro?).
I have received my FE 50 mm macro lens. I am waiting on shipment of my FE 90 mm macro lens. My nephew has had his for over 6 years and loves it. I am now waiting for my FE 70-300 mm Zoom to arrive. I picked that one because it is a native lens that will focus down to 90 cm.
in general, I prefer native lenses as well. For macro, I can’t seem to make a decision.
If I need extreme macro pictures, I can use my A mount Sigma 150 mm macro by itself or I can add my 1.4 X tele converter or the 2X converter. On top of that I have a set of extension tubes that I can add.
I was thinking more of a Marumi achromat filter.
Have a look at my gallery .
I’ll look later. Cannot access your gallery from my iPhone.
thnx again!
