Older X-T10 or a newer X-T100? Help decide please
Started Apr 13, 2019 | Discussions
MichalM New Member • Posts: 4
Hello, after a long hesitation, I decided to write and ask for advice.
I would like to know your opinions whether to buy an older X-T10 with a classic 18-55mm f2.8-4 lens or a newer X-T100 with XC 15-45 and what will be the difference in quality. I'm not a novice, I sold old photo equipment, but I'm planning a trip around Europe and looking for something to go.
I am especially interested in image quality in jpeg output. I don't want to edit the raw format anymore - it takes time and disk space. I would rather use the kit lens for such a normal photo shoot. I'd like to take Samyang 12mm F2 and also use some older M42 optics. I wonder your opinion about the image output with them. Is there a noticeable difference in old and new sensors? Which one is "more tolerant" to these optics? I also don't and I won't buy a modern computer. My Intel® HD 4000 and i5 core is enough, but I don't think there's going to be a big difference in processing 24mp or 16mp?
In the past, I took photos of documentary, street and reportage. I have never used continual focus, even though I am shooting action shots. I'm shooting with one center af point and I'm not interested in the video. I've always done with an average camera. Olympus 410 with pancake 25mm, Sigma SD15 with Sigma 18-125, some nikons, canons and pentax ... I stayed at home with only fujifilm x10. I think I will use the camera overall to take pictures of static objects. Mainly landscapes and architecture. I don't want to invest much in the camera, I'd rather buy another lens. Your opinion? X-T10 vs X-T100? Does the older M42 with 24mp sensor make sense? Opinion on Samyang with him?
Thank you, Michal
Fujifilm X10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T100 Fujifilm X-T20 Sigma SD15
markgv Regular Member • Posts: 391
Re: Older X-T10 or a newer X-T100? Help decide please
I can't speak to the X-T10, but I do have the X-T100 and the 15-45mm lens. It's been a great combination. (HERE is a report of a recent trip I took using that combo with pics and links to galleries.) I also took along the Rokinon 12mm, and it too is an excellent lens that is fun to use.
I also use Pentax gear, so I have a bunch of M42 lenses. A few things to note:
  • There are two types of adapters for M42 to Fuji X. There's a cheap (~$5 on ebay) one that works fine. You can also get a ~$25 one that has a "Macro Focusing Helicoid" which allows for more flexibility in focusing distances.
  • Neither the X-T10 or X-T100 have in-body stabilization. Without a tripod, I'm good to shoot up to 75mm or so under decent conditions.
  • With that in mind, it's a lot of fun to shoot with those tasty old M42 lenses.
The JPG output on the X-T100 is indeed excellent, and you do have the option of some different film simulations. You may want to tweak things to your preference. I am able to get better results using the RAF files and processing them in Lightroom, but the JPGs should be more than sufficient.
 markgv's gear list:markgv's gear list
Pentax K-30 Pentax K-3 Pentax KP Fujifilm X-T100 Sigma 10-20mm F4-5.6 EX DC HSM +20 more
rainydiary Regular Member • Posts: 431
I would recommend X-T100 because X-T10 has issue with the play button.
https://www.dpreview.com/forums/thread/3989209
Smallpox
Smallpox Contributing Member • Posts: 510
Thank you, Michal
XT100 without a shadow of a doubt
Only drummers can travel in time
 Smallpox's gear list:Smallpox's gear list
Fujifilm X-A5
horizont Forum Member • Posts: 77
24 MP isn't too much for vintage lenses.
If you decide for X-T100, buy a fast SD UHC card because X-T100 has a bug in manual focus assist magnification in the viewfinder - magnification doesn't work while images are being written to the SD card. On the LCD screen it works thou. This slows you down when using MF lenses.
 horizont's gear list:horizont's gear list
Fujifilm X-T100 Fujifilm XF 35mm F1.4 R Fujifilm 16-50mm F3.5-5.6 II Fujifilm XF 23mm F2 R WR Nikon D7000 +4 more
Pixel8888 Contributing Member • Posts: 979
Thank you, Michal
The XT10 does not have all the jpg film emulations the newer Fuji's have.
I definitely would go with the X-T100. There is also a XC16-50 II kit lens, that's a fine lens. The XC 15-45 should be ok too. In Europe's medieval narrow streets a 15mm lens becomes handy. The free Capture One for Fuji should run fine on an i5 processor. Even if you don't shoots raws.
Here is a comparison X-T100 vs X-T20. The XT10 is a generation older.
https://mirrorlesscomparison.com/fujifilm-vs-fujifilm/xt100-vs-xt20/
24mp is no problem for most older lenses. You only use the cherry center part of the lens anyway. It is a lot of fun shooting older lenses.
And one point the Fuj's have the option of in body raw conversion. You can always produce a Velvia or Classic Chrome or whatever you like jpg in camera later, when you made the shot in raw, something to consider.
You can also bracket your favorite film simulations in camera.
https://www.youtube.com/watch?v=ZsILbhio4Rw
... or you buy an now old XT20, as the XT30 is out now. The XT20's should drop in price.
 Pixel8888's gear list:Pixel8888's gear list
Fujifilm X-T2 Voigtlander 35mm F2.5 Color Skopar Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm 16-50mm F3.5-5.6 II +6 more
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Thank you, Michal
x-t100 every time
OP MichalM New Member • Posts: 4
Thanks for the knowledge, I myself lean towards x-t100 just because it's just newer. I understand the differences in both the old X-T10 and the newer X-T20 (I clearly read all reviews, opinions and specifications of these models) and the differences in image processing (bayer vs x-trans). I just want to confirm that I'm doing right. For traveling, it is very interesting for me to be able to charge the X-T100 with a USB cable and bluetooth that certainly does not take the much needed energy for a digital nomad. Yes for sharing photos I can use wifi, PC and power converter in my car but why not use bluetooth, phone and power bank.
I looked at examples of photos from older 16mp sensors (eg here on DPReview) and I don't know why but they all seem to me more grim than the newer 24mp X-T100. As if they were (as opposed to 24mp) all shot under the cloud. They simply don't have as much color, contrast, range dynamics, and maybe even sharpness. And as I say it's just a "nice" jpeg output from the camera that interests me.
Thanks also for the opinion on Samyang / Rokinon - I think this is a reasonable choice and sufficient for travel photography. What worries me a bit is the choice of a set lens. I'd like one autofocus lens to have. Probably I will avoid 18-55 in the case of X-T100. I'd have to buy it separately and use it and I'm a little worried about a bad copy. It is clear to me that these will be full of ebay. On 15-45 I like his wide range, but he's bad on his second range. Zoom Motor Movement - I remember it once on an old minolta lens. It will not be a problem to shoot static objects. And there is an XC16-50 with a very reasonable price (eg at auction) ...
Even for M42 adapters. I think "any" on fuji will be better than some for nikon with special "inner lens" for infinity focusing. I probably didn't get lucky for a good piece, but it always reduced my lens quality...
The Fat Fish
The Fat Fish Senior Member • Posts: 1,265
The sensor in the X-T100 is great and the best APS-C sensor Fuji uses. Ultimately image quality matters and the X-T100 is Fuji's best so far (excluding medium format).
If you're a fan of mediocre landscape photography, check out mine:
https://www.flickr.com/photos/alexwedlake/
 The Fat Fish's gear list:The Fat Fish's gear list
Canon EOS 6D Canon EF 16-35mm F4L IS USM
Thank you, Michal
Thanks for the link to the nice review "Fujifilm X-T100 vs X-T20 - The complete comparison"
Advent1sam
Thank you, Michal
It is a decent review but I did quiz Matthieu on his c-af tests as they did not "mirror" my results, pardon the pun, also as he doesn't provide higher res images so its difficult to see exactly some of the specifics he comments on.  One thing that is very hard to understand is the way the x-t100 meters compared to xtrans bodies, the whole evf/metering and the ability to control exposure with the top ev dial is a dream come true for jpg shooters imo, it always feels far more hit and miss on xtrans bodies, go figure! Also make sure the performance mode, battery setting, is on, then the camera is very responsive all round.
I think it's decided to buy the X-T100 probably with the XC 15-45 kit lens. In bayer vs x-trans I don't see any advantage or disadvantage for me. I know that X-trans is good at high iso, but I'm not going to shoot too much in poor lighting, and if I think I'll remember it, shoot RAW and later edit it in some decent editor. Apparently, the new 24mp is clearly better, even with the bayer filter. Of course, after some test photos, I may adjust some of the camera settings, but I think that in case of decent exposure bracketing for some images on a tripod, it will be possible to get the most out of this sensor. (with not much effort ...)
And out of nostalgia, I remembered that I once owned FinePix S2 Pro. I always liked technology like foveon on sigma or super CCD on this fuji.
It is really the XC15-45 lens so bad at its higher focal lengths of 30mm+ ?
Advent1sam
No, lens is great at all lengths, it is a bit soft in corners and needs stopping down a touch, I will be very surprised if you are not totally satisfied with this combo, it is a great tool offering tons of variety😀
Capture One for Fuji is free on Phase One's website. It's more than decent, and it runs fine on a i5 processor. Great tool to tweak colors.
Sal Baker Forum Pro • Posts: 11,553
Thank you, Michal
The X-T100 for sure.  IMO, the best APS-C IQ Fuji has to offer at this time.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Fujifilm X-E2 Fujifilm X-T100 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Smallpox
My version was great edge to edge at all focals. But I ordered 4x times! No other kitzoom or brand can beat it if you get a good one.  In my opinion, the XT100 is the best Fuji.
Fujifilm X-A5
kickoff3pm
kickoff3pm Regular Member • Posts: 351
I use my X-T10 almost exclusively on vintage lenses. I wouldn't upgrade for anything but an X-T3. Here are some images with vintage £5 lenses
Look forward to more great days in the future. We owe that much to those no longer able to share our great days !
 kickoff3pm's gear list:kickoff3pm's gear list
Panasonic Lumix DMC-FZ28 Canon EOS 60D Fujifilm X-T10 +15 more
Threaded Veteran Member • Posts: 4,180
If it has to be between these two, I would go with the XT100 because the XT10 has some issues, as an older camera its AF will be slower, and it suffers from a common problem with X-Trans II cameras of having over aggressive JPEG noise reduction on skintones at ISOs over 1600, and you did say JPEGs were important to you.  The play button fault is also well known.
That said, personally I don't like the XT100 either - I'd save and look elsewhere in the current range. XT20s will be getting more affordable now. The XT100 although "newer" was built down to a price and has a sub-par processor inside, and while there are those (here) that like to vehemently disagree whenever this is mentioned, the overwhelming view of reviewers is that it doesn't perform well. They might all be wrong of course, but they probably aren't.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
NextShowForSure Contributing Member • Posts: 765
The X-T100 is not the fastest thing on earth but the reviewers are constantly dropping down from high end kit and are always going to find a camera like the X-T100 frustrating which is priced down on reduced processing clout with no compromise on image quality.
In the current trend a processor that was fine 2 years ago will be sub-par now so you can chase the curve but will never catch up with it as in 2 years time it is all sub par again.
I had an X-T10 and certainly would not swap my X-T100 for one. I also have a X-A3 which works OK and considering some reviews think the improved X-A5 is almost unusable I take these reviews with a pinch of salt. Not having to buy the camera themselves takes a big lump out of the equation. Nikon Zee not Zed mirrorless at £2,000 entry level. No problem.
The X-T100 was not built down to a price but built at a price. It works fine for what it is but the modern constant kit comparison fever always muddies the water on the particular merits of any kit in its own right. A lower cost camera being 'crippled' is also a popular term in the assessment of affordable stuff.
I doubt anyone is vehement, but it's been mentioned that the initial reviews were before the FW update.  My only point of comparison is with my X-E2.  With current FW and performance mode the X-T100 is a decisive upgrade in every way, and the IQ from the Bayer CFA is at the top of Fuji's offerings.  If someone finds the X-E2 (with updated FW) to be unusable for photography then they would be better off with Fuji's more pricey models.
Sal
