NIKON WP-N3 HOUSING O-RING
Started Apr 11, 2019 | Discussions
BillD7000 Senior Member • Posts: 1,082
I've purchased a Nikon WP-N3 U/W Housing for a J4.
I'm looking for an extra O-Ring (Same one as fits the WP-N2).  Part# is: WP-O1100
Can't find one anywhere.  Help would be MUCH appreciated.
www.billkeane.zenfolio.com
 BillD7000's gear list:BillD7000's gear list
Nikon D500 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Sigma 8-16mm F4.5-5.6 DC HSM Nikon 85mm F1.8G Nikkor AF-S 300mm f/4E PF ED VR +1 more
Nikon 1 J4
daveco2
daveco2 Contributing Member • Posts: 953
Re: NIKON WP-N3 HOUSING O-RING
What I do when replacing an O-ring unavailable from the equipment supplier is to measure the ring cross-section diameter and its major diameter then visit O-ring supplier sites and get a match. Look for a low durometer material. It’s an easy process, but you may need to borrow dial calipers. O-rings come in only a few cross-sections. Silicone is a good material.
The easiest way way to measure major diameter is to measure total length and divide by pi.
show the dimensions here and I can help find a seller.
 daveco2's gear list:daveco2's gear list
Sony RX100 Sony a7R II Sony a7R III
OP BillD7000 Senior Member • Posts: 1,082
I'll have to get the calipers...  But THANKS for the help!  Nikon keeps sending me to dead links and saying my question has been answered.  I have place an order with two entities, but I'm not sure it'll ever be available.
Life_of_ky New Member • Posts: 1
We’re you able to find an o-ring that worked? I am having the same problem now.
drew-ha New Member • Posts: 2
has anyone found a solution to the Nikon Housing? I am also looking for an o-ring replacement. Does anyone know the size of the o ring? TIA
