How to completely erase personal stuff from a computer, without formatting and reinstalling Windows?
Started 4 months ago | Questions
Levantinian Regular Member • Posts: 153
Can't be done
DMKAlex wrote:
How to completely erase personal stuff from a computer, without formatting and reinstalling Windows? Windows 10.
There are various methods, some outlined above, but you have only hope, not guarantee that your goal has been achieved. If you need to be certain, reformatting, erasing and reinstalling is the only way.
Johann Kruger Senior Member • Posts: 1,287
Re-Imaging is all you can do, really ...
Re-imaging s the only solution. We re-image all Mac and Win Barf computers each day or anytime our internal IT scripts detect a Mac of Win Barf computer is detected on our company network.
woodyggg Contributing Member • Posts: 891
Re: Re-Imaging is all you can do, really ...
win barf?
 woodyggg's gear list:woodyggg's gear list
Sony a7R III Canon TS-E 90mm f/2.8 Sony 50mm F2.8 Macro Canon TS-E 24mm f/3.5L II Sony FE 55mm F1.8 +5 more
Thank you - excellent post
afterburn wrote:
Go into settings to reset the pc and select include personal files. It will be just as fresh as a new install. Want more, log in again and follow this guide :https://www.howtogeek.com/137108/how-securely-overwrite-free-space-in-windows/ and nobody will be able to recover anything either.
Suggestions to reinstall above also require that guide if you are worried about recovery as not even a regular format and reinstall will render files unrecoverable perse.
It is the quickest and easiest method. Don't buy into the aluminum hats.
Thank you.... worked great. Excellent solution!
Dr_Jon Veteran Member • Posts: 6,033
Re: KillDisk
RealCereal wrote:
You can delete all the personal files and then do a wipe of just the free space.
This is essentially the same thing, but with Windows intact.
I recommend using Active @Kill-Disk and select Wipe Free Space once you delete your personal files
Unless you nuke stuff in the registry it won't be good...
 Dr_Jon's gear list:Dr_Jon's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +29 more
I did this for an ex-GF (who wanted to sell their Laptop) but it's a huge pain running around making sure everything was gone, then going through the registry with a fine tooth-comb... Plus there's protected storage and other crap... Flash cookies...
Deleting the user accounts they use is a good starting point, as loads of stuff goes south.
Don't forget to wipe the free space at the end. I used "Hard Disk Scrubber".
A J Fresnel Forum Member • Posts: 78
Re: How to completely erase personal stuff from a computer,... [subject too long]
Completely? This might help.
Other than that, Factory reset seems like the best option.
 A J Fresnel's gear list:A J Fresnel's gear list
Sony a6000 Sigma 30mm F1.4 for Sony E Sony E 18-135mm F3.5-5.6 OSS +1 more
