Z6 flickering when using N-Log?
Started 11 months ago | Discussions
Nefilim Regular Member • Posts: 475
Just noticed this tonight on a dark gradient background. The footage is being recorded to an Atomos Ninja V but I can see the flickering on the camera screen also.
4k24p (23.976)
1/50
f4
ISO 1250 (not auto ISO)
manual focus
Flickering control set to Auto or 60hz, no difference.
The only light on is an Aputure 120d MarkII - I've swapped out with other LED panels and LED lights, thing, it's definitely not the 120d (as expected).
When I switch off N-Log it disappears? I don't know it's by virtue of the falloff in the gradient is much quicker, I don't think so but I can't see any flicker in the second clip.
Does anyone know what's going on here?
https://www.youtube.com/watch?v=o4HQ4JDKaVc&feature=youtu.be
Peter
Nikon Z6
willduncanphoto New Member • Posts: 2
Re: Z6 flickering when using N-Log?
I'm seeing the same thing too on tests shots that I did after getting my Ninja V, mine appear to only appear to happen under specific high ISO settings with the Atomos and recording N-Log.I haven't done a detailed replication of it yet.
I only found a few examples of it hunting around on Google though.  Did you ever contact Atomos or Nikon regarding the issue?
maxime_m New Member • Posts: 1
Seems to be fixed on firmware 2.10: "Fixed an issue that in rare cases resulted in “noise” in the form of fine horizontal lines appearing throughout the frame in movies and the live view display." 😀
And as far as I can tell, It dramatically changed (at least at ISO 1250, still some weird stuff happening at 6400).
