Olympus E-520 plus Underwater housing set and other accessories (used). Worth buying ?
Started Apr 8, 2019 | Questions
pitchiker New Member • Posts: 3
Hello everyone,
I am just getting into underwater photography and I am looking for an item which can help me gain some experience and knowledge in underwater photography.
I have recently come across an entire Olympus E-520 underwater camera housing set (used) and I wanted to ask this community for advice if its worth the buy. My main questions are: With the camera being almost 10 years old, how does it hold in today standards? Would I be better off investing in Gopro 5 or 6? Also, even if I see no use for the camera, will the accessories be of any value for future camera builds? The asking price is currently at 500 dollars. Any advice is greatly appreciated. (I can also provide pictures if necessary)
I will list up all the items included in the following: (I am translating the following names from Japanese)
Inon Close-up Lens UCL-165M67 x 2
Inon holder Grip set
Inon multidirectional base II
Inon multidirectional base II (long)
Athena standard zoom port 14-42 OPD-SZ14-42 Port
Athena M67 Lens adapter arm
Athena ATPF port ring arm 110
Athena Joint arm 110i M67 Lens holder set S
Athena Zoomgear 14-42 ZG
Olympus Under water housing PT-E05
Olympus E-520 Zuiko Digital 14-42mm F3.5-F.5.6
Olympus Lens Kit
Olympus E-520 (EVOLT E-520)
kelpdiver Veteran Member • Posts: 5,564
Re: Olympus E-520 plus Underwater housing set and other accessories (used). Worth buying ?
$500 is too expensive for a 10 year old platform, particularly as I do not believe the PT housings can be serviced.     Maybe half that?   The seller would surely value it higher, but none of us should.
Not sure that the 520 can use micro 4/3rd lenses either.   the 14-42 is a jack of all trades, master of none choice.   Most 4/3rds users shoot the 60mm for macro and the 8mm fisheye for wide.   The 7-14 or the 9-18 used for sharks and bigger items that don't get right to you.
For a new shooter, almost any ILC system is viable, but I'd rather spend $500 on a TG5 or a spend a little bit more on a used 4/3rds or APC setup.   Unfortunately the subsequent strobe and arms purchase is nearly as steep, though the weefine ring light is one potential savings route (still 300) for macro shooting.
The go pro route is good cheap entry.  Taking a seminar and renting gear may be another route to trying it out.
Architeuthis Regular Member • Posts: 491
Hi pitchiker,
If the set is complete and ready to be immersed, it may be a good entry into UW photography. I agree with kelpdiver, 500$ is too much, even half of it seems a lot for this equipment (Maybe 150$?). For 1000$ - 1500$you may be able to buy a decent second hand system if you look e.g. in Wetpixel classified (e.g. Oly EM1 or EM5 with Nauticam housing - this system can be expanded later with Macro- and WA lenses and ports, flashes and in the end you just acquire a new camera body with housing)....
You may be able later to use arms, lens holder, close up lens and maybe the port (but you probably will need a special adapter for the port to be used on another UW housing) - so probably you will want all items new and tailored to your new housing....
The heart of the set. i.e. camera, UW housing and lens will not be useful and it will be practically impossible to sell them later. It also would not make sense to build an entire system (with Macro and WA lenses) based on this set. So it is just an entry and in case you like UW-photography you will acquire everything again. So practically the entire system cannot be used later..
The set is no comparison to GoPro, that is something different (most people even prefer actioncams, as they are much smaller and easier to handle, while a camera system is for passionated UW-phtographers, who do not care to transport hughe amounts of equiment and drag it through the waters and, in turn, would not want GoPro).
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
OP pitchiker New Member • Posts: 3
Dear kelp diver,
Thank you so much for your advice and guidance! I decided not to buy the camera in the end. Instead, I will use my money to invest in some good strobe lights for a Gopro-set up! Hope I will gain some experience through this.
Best regards,
K
Dear Wolfgang,
Thank you for your helpful reply. I have decided not to buy the camera and opted for a go-pro route for now. Maybe going to invest in some good strobe lights for the Gopro seems like a better way to go with the money.
Have a great day and happy underwater photographing,
K
