Question about 50mm f/2 & filters
Started Apr 5, 2019 | Discussions
Snap Happy Senior Member • Posts: 1,925
Can anyone tell me please if the filter thread/lens barrel on the 50mm is nice and solid.
Reason for asking is I use filters a lot and don't like using them so much on the 60mm as the lens barrel doesn't feel particularly solid and moves during focusing.
So, I might trade the 60 for 50.
 Snap Happy's gear list:Snap Happy's gear list
Fujifilm X-T4 Fujifilm GFX 100S Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +19 more
jhorse Veteran Member • Posts: 5,913
Re: Question about 50mm f/2 & filters
Hi, I use the 50/f2. I have a Fuji Protector filter on most of the time. Occasionally, I swop it for a CircPol filter.  Never noticed or had any issues with the thread.  Hope that helps.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Kiwi in Kyushu
Kiwi in Kyushu Regular Member • Posts: 157
When I had the 50mm f/2, I was swapping infrared filters a lot and had no problem.  Although I was using a 46mm to 49mm step up filter ring as most of the time.
 Kiwi in Kyushu's gear list:Kiwi in Kyushu's gear list
Sony Cyber-shot DSC-F828 Fujifilm X100F Sony Alpha NEX-5 Carl Zeiss Touit 2.8/12 Sony FE 55mm F1.8
OP Snap Happy Senior Member • Posts: 1,925
Thanks, I was more concerned that the filter thread is on a solid part of the lens 'chassis', as it is on the 16mm f/2.8, not a 'floating' barrel that may make the lens a bit vulnerable to damage with filters attached.
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
It's not that at all - the front element and thread are solid/rigid, like the sibling Fujichron lenses.
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Great, that's what I hoped, thanks.
