Looking for feedback
Started Apr 3, 2019 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
Looking for feed-back:
Here are Parallel Gaze (top pair) and Crossed Gaze (Bottom pair)zero-base 3D conversions of original (left eye) images of:
A a close-up portrait of a barn owl,
B an infra-red summer landscape of a glacial lake (often mistaken for a winter scene),
C a close-up study of a seashell (original image courtesy of Russ Borud), and
D a NE Arizona land-and-skyscape.
Four different experimental techniques of producing image pair disparity were employed with these four image pairs.
It would be appreciated if you would score these four 3D image quad sets (top pair- parallel gaze, bottom pair - crossed gaze) according to this scale:
0 no 3D effect
2 slight 3D effect
3 moderate 3D effect
4 strong 3D effect
Also, I am interested which viewing technique (parallel or crossed) was used or which yielded the best result, if there was a difference.
Many Thanks.
Dave Graham
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
Tom Frerichs Regular Member • Posts: 298
Re: Looking for feedback
0 no 3D effect
2 slight 3D effect
4 strong 3D effect
Many Thanks.
Dave Graham
All: Parallel with a viewer.  I cannot do a cross-eyed view.
Owl - 3
Infrared lake - 4
Shell - 2
Landscape with blue sky - 4
Tom Frerichs
 Tom Frerichs's gear list:Tom Frerichs's gear list
Nikon D4 Panasonic Lumix DMC-GX7 Nikon D4S Nikon D7200 Nikon D500 +18 more
uuglypher
OP uuglypher Regular Member • Posts: 250
Tom,
many thanks for taking your time viewing the images and providing your input!
You mentioned using a viewer...what sort?
Again, many thanks,
Dave
uuglypher
Wayne Gretzky
uuglypher wrote:
Tom,
Again, many thanks,
Dave
So I don't have to print them out, a Loreo Pixie viewer.  Think of it as a paper Holmes viewer without frame and adapted for much larger images (as on a monitor).
TG Frerichs
uuglypher
Thanks for the info.
If you have a digital pad or a smartphone, they can make the images much easier to view.
B3st regards,
Dave
uuglypher
Wayne Gretzky
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
A. Moderate, but appears to me as a warped 2D flat sheet bent into 3D, and somewhat uncomfortable to view.
B. Moderate (but somewhat confusing). Most uncomfortable to view of all, particularly near the edges where details don't align well.
C. Moderate. To me, the parallel view appears more "stereo realistic" to view when crossed, and vice versa...not too uncomfortable. Probably due to the uniform background?
D. STRONG, VERY STRONG! The most comfortable to view. If the Window Violation on the left side were "corrected", I'd be pleased...
All freeviewed, crossed and parallel.  No significant difference either way.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
uuglypher
Thank you, Wayne,
Your comments are substantive and objective.
Much appreciated!
Dave
uuglypher
Wayne Gretzky
Tourlou Senior Member • Posts: 1,046
Ok, here's what I think:
1st one: no 3D effect.  Can't see much difference between the 2 shots.
2nd one:  not working.  The focal length/distance to subject is not the same which causes the brain not to be able to process.
3rd one: some depth perception, but once again I think there's something wrong about the relative dimensions of left and right images.
4th one: Good depth perception, but judging by the edges of the images, the center of sight is not the same in both images as the horizontal displacement of the camera doesn't appear to match the offsset visible to edges.  Nontheless, nice 3D effect.
Regards.
Ron
3D Gunner Senior Member • Posts: 1,031
Hi! I can see and convert 3D images in any format, so I do not have problems with viewing. The answer is the following: 2-3-3-4, but none of the images have a realistic 3D structure, so conversions can be considered unsuccessful, no matter how weak or profound the relative 3D effect.
Turbguy1
I agree. There is quite a difference between "a 3D effect" and realistic stereo views. For instance, the following crossview has a resolvable depth difference down to every twig and blade of grass. To convert one side to realistic stereo would take an EXTREME amount of effort. Not that it cannot be done, it would just be time consuming...
https://www.flickr.com/photos/turbguy/40600096883/in/photostream/lightbox/
uuglypher
Thanks,  Tourlou,
I appreciate your objective comments.
Dave
uuglypher
Wayne Gretzky
uuglypher
Hi, Gunner,
Thanks for ranking the images. Can you explain “realistic” in  more objective terms. was that comment in comparison with natural visio, or with orthostereography , or ?.. and specifically what criteria of “realism” should we aspire to capture?
I do appreciate your input.
Dave
uuglypher
Wayne Gretzky
uuglypher
Hi, Wayne,
Th@nks for your persistence.
As I asked Gunner, what more objective criteria of realistic can you offer?
One feature of orthostereography, especially with landscapes, that I try to overcome in conversions is the extinction of perceptible depth recession before it can encompass the background, leaving it with the appearance of a painted stage backdrop. To my eyes, that is not realistic, although I think I’ve seen you that we can’t discern depth differences at those distances.  The last landscape illustrate what, to my eye, is realistic depth recession.
Maybe Carl Gauss was right with his bellshaped curve...indicating that our “...mileage may vary”?
And your linked image does have impressive detail depths in the fore and middle grounds.
Thanks,
Dave
STILL LOOKIN’ FOR MORE FEEDBACK !
uuglypher
Wayne Gretzky
Turbguy1
Realism in stereoscopy INCLUDES the gradual and (expected) extinction of stereopsis as you approach distances towards "infinity".
It appears you attempt to avoid it (or emphasize it)?
BTW, that view I posted is far from "ortho".  I estimate the interaxial used as about 18".
Perhaps a better way of conveying realistic stereo depth is to include other expected depth clues? Perhaps with motion videos. For static displays, the "expected stereopsis extinction" should be an important element for realism (IMO).
The issue I have with most conversions is the lack of depth in the "small" details where stereopsis is in the range of "obvious", separating a detail 6 feet away from a detail 6 .01 feet away.
That said, keep converting!
I agree...
Your 3D example on flickr seems to be made with a single camera with position shifting.
