Random Grey Rings on my Canon Eos100D
Started Mar 31, 2019 | Questions
rahoom New Member • Posts: 1
After a year or so of using my camera, ive noticed grey rings on all my photos, ive cleaned it multiple times, took photos from different angles and still they appear.
Ive added a couple of pictures.
Ray UK Contributing Member • Posts: 977
Re: Random Grey Rings on my Canon Eos100D
Almost certainly Hairs on the sensor.
Firstly ensure that you have a fully charged battery fitted in the camera.
Remove the lens then select "manual clean" in the menu, when you press the shutter the mirror will go up and stay up, the shutter will open and by looking in from the lens mount you will see the surface of the sensor assembly, by using a bright light you should be able to see anything on the surface that shouldn't be there.
The easiest way to remove a hair from the sensor is with a very clean, soft paintbrush.
Once you have finished turn off the camera to reset the mirror/shutter.
