7D 100mm 2.8 Macro and Metz 15 MS-1
Started Mar 26, 2019 | Discussions
thedancer Regular Member • Posts: 205
Charged the batteries and did a short session of a few pictures to see if everything still works fine.
The colorfull result:
OOC jpe
I'm happy, TTL works like a charm. To bad Sony did not continue this feature on the A6xxxx series.
E.Dancer
Konica Minolta Maxxum 7D (Dynax 7D / Alpha-7 Digital)
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: 7D 100mm 2.8 Macro and Metz 15 MS-1
OOC jpe
Nice colourful shot , good detail .
I take it you operated the Metz 15 MS-1 wireless TTL ?
How do you mean Sony didn't continue this feature ?
I have the NEX 7 , and it works the same way as the a6xxx units with regards wireless TTL flash .
Only the A mount cameras control remote flashes with the on board flash for wireless TTL flash , not sure why the E-mount gear can't .
E-mount bodies can still use wireless TTL flash controlled by a suitable separate flash , so not a total loss .
See the camera specs here ;
https://www.mhohner.de/sony-minolta/onebody/ilce-6400
For a suitable flash , look at this one ;
https://www.mhohner.de/sony-minolta/oneflash/hvl-f20m
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
OP thedancer Regular Member • Posts: 205
OOC jpe
Thank you
Yes, I selected WL in the menu, with the flash up, it does TTL with the Metz Flash (channel set to all)
Until today after many try-outs I still haven't found a way to get my 6300 to work WL with the Metz, without taking advantage of a external flash like Sony HVL-f20m. The bodies flash disables WL when it is up, when adding a 5600HS with hotshoe adapter and set to WL, it does not work.
Think I have to add a hvl if I like to us ttl.
Thanks a lot for the extra info and answer
E.Dancer
neilt3
thedancer wrote:
OOC jpe
Thank you
Sony didn't change any functions of the Minolta 5600HS/D when used with a digital camera .
The Minolta 5600HS/D flash followed on from the 5400HS and 5400xi flash units that could act as a wireless flash controller on compatible film bodies like the Dynax 9 & 7 and the first two digital cameras , the Dimage RD-175 (from 1985 ) and Vectis V-mount DiMage RD-3000 ( from 1999 ) .
These still used the same metering method as film cameras TTL-OTF ( well not true OTF - Off The Film , as they have a sensor !)
When Minolta brought out later digital cameras , the A-mount Dynax 7d and the DiMage 7 series as well as from the DiMage A1 range onward's , they changed the protocols .
So although the flash guns function correctly on camera , and the cameras can control the off camera flashes TTL via the built in flashes , they can't use the 5600HS/D as the controller .
When Sony took over nothing changed .
The Minolta 5600HS/D and 3600HS/D just got re-badged for sale with the Sony a100 and later a700 to the Sony HVL-F36AM and 56AM .
When the a900 came out , without a built in flash , Sony had to come up with something .
Minolta had the "Minolta Wireless Flash Controller" that came out with the Dynax 9xi , to trigger flashes wirelessly , shame Sony didn't just update it , and that won't work with digital .
Instead the three options are the tiny Sony HVL-F20AM with the iISO hot shoe , you would need the later Sony HVL-F20M version .
They then came out with the ( much bigger ) Sony HVL-F58AM and Sony HVL-F43AM both with the iISO shoe to act as controllers .
They also have some large flashguns with the new style hot shoe ( multi interface thingymajig ) , but on an a6xxx model they would be very top heavy .
So get the Sony HVL-F20AM to use on iISO fit digital bodies from the Dynax 7d onward's , or the Sony HVL-F20M for use on cameras with the MIS shoe .
Apart from the adapter you have to mount the iIso shoe flash guns onto later MIS fit bodies , you can also get a an adapter to go the other way , so if you get the later flash gun you can still use it on earlier bodies .
Your welcome .
Thank you so much for this complete answer and solution. As I allready expected a new flash can solve the problems.
E.Dancer
borissimo86 Regular Member • Posts: 289
Nice colors!
borissimo86 wrote:
Nice colors!
Thank you But when colors are already vibrant then 7D keeps that vibrancy at a fantastic level. No need for PP.
E.Dancer
