Which photo Can survive? Over or Under-exposed photo?
Started Mar 25, 2019 | Questions
Alireza S
Alireza S New Member • Posts: 16
Hi...
Which photo has the chance to be recovered more successfully? An over-exposed photo or an under-exposed one?
Luisifer
Luisifer Contributing Member • Posts: 631
Re: Which photo Can survive? Over or Under-exposed photo?
The good one has the best chance (and it will be in critical / unrepeatable moment of both possible kinds, underexposed or overexposed).
But the best way is to work on praxe for minimizing of wrong (unwanted levels of) exposures than taking things from the wrong end and trying to rescue bad results (not only bad exposed).
(Or worse, learn taking bad exposures in general way because they are possible to rescue)
 Luisifer's gear list:Luisifer's gear list
Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
petrochemist Veteran Member • Posts: 3,619
In digital photography once data is lost by overexposure clipping there is no-way to regain that data. But if the parts concerned have no information of interest this doesn't matter.
Under exposed digital images (especially if recorded in RAW) can have a lot of information pulled out of underexposed areas.
With film it depends on the type of film. IIRC a fair bit can be done to recover highlights from over-exposed negatives & less from under-exposed ones. Slides are generally better slightly under-exposed if you can't get the exposure right. If the exposure issues are known about before processing the film a considerable degree of adjustment can be done by over or under developing as required. Some films were routinely 'pushed' by 5 stops in astrophotography.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Just to add, I've recently been very surprised at just how much image content can be recovered from grossly underexposed color slides.
Although there often appears to be no visible image content at all, HDR (high dynamic range) imaging of slides was able to recover image data that was 10 or more stops underexposed! Not saying this always works, but that it ever works is shocking.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
D Cox Forum Pro • Posts: 32,980
Yes, there's more there than you can see on a lightbox.
Even the simple 3-exposure HDR feature built into Sony cameras shows some detail in very dark shadows; I advise using it for routine digitizing of slides.
Sigma fp
MacM545 Contributing Member • Posts: 783
Underexposed is generally easier to recover
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
