Took the 50-230 for a walk today
Started Mar 25, 2019 | Photos
io_bg
io_bg Senior Member • Posts: 1,548
23
Yes,
  • it's a XC lens
  • it's slow
  • has a plastic mount
  • lacks an aperture ring
  • is cheaply built
  • can have trouble focusing in low light
  • might be a tad softer than the 55-200
But:
  • it's so cheap
  • is lightweight
  • is plenty sharp
  • its OIS is rock-solid
  • can deliver some smooth OOF areas
Some full-resolution samples for the pixel peepers out there:
Honestly, I wish I used it more often.
C&C welcome.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
Comment & critique:
Rod McD Veteran Member • Posts: 8,589
Re: Took the 50-230 for a walk today
Hi,
Thx. Some nice images there. I have Version 1 and like the output.  (I also have the 55-200, but I bought a used copy of the 50-230 for travel because it's so much lighter. These days it tends to be the 50-230 that gets slipped into the case for exactly that reason.)
To your list of positives, I would add that the 50-230 is also a nicely flare resistant lens (see below). And despite the plastic mount, they tend to keep working.....
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
SVJIM Senior Member • Posts: 1,758
Yea, I think the biggest problem with the lens is that it is slow to focus. That being said, it is quite sharp once focus is attained and OIS works quite well. So if you like me and can't afford a large zoom, this is quite a lens.
Jim
Photography should be fun
http://www.TouchingMemories.com
 SVJIM's gear list:SVJIM's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm 50-230mm II
dezinerd
dezinerd Senior Member • Posts: 1,309
Vey nice examples of what this lens might produce. My fav the last the cityscape with the long focal length compression. Thanks for posting your beautiful photos.
Dennis
 dezinerd's gear list:dezinerd's gear list
Olympus C-2100 UZ Panasonic LX100 Nikon D70s Nikon D200 Nikon D700 +8 more
poldersnapper
poldersnapper Veteran Member • Posts: 5,293
Woodpecker showing its plumage :)
Nice examples of what the 50-230 is capable of.
Very happy with my copy
André
http://mcpint.zenfolio.com
'Forever Morning'
Mr. Tony Banks
io_bg
OP io_bg Senior Member • Posts: 1,548
Rod McD wrote:
Hi,
Cheers, Rod
Yes, that's a good point about flare resistance. And nice shot, too.
kiwidad Regular Member • Posts: 423
I own the first version and its slow as a snail to focus on my X-e2 but I am stunned by how much it improved on the X-t30. As long as I don't let it drift to near focus it hit focus pretty darn quick!
 kiwidad's gear list:kiwidad's gear list
Fujifilm X100F Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm X-T3 Fujifilm XF 18mm F2 R +8 more
